European power for US console?
power hardware pal
7 replies to this topic
#1 ralphb OFFLINE
ralphb
    Dragonstomper
  • 654 posts
Posted Fri Oct 23, 2015 11:39 AM
Does anyone have any long-term experience with running a US TI 99/4A with a European power supply?  Looking at the power bricks they supply slightly different voltages, but this thread deems it as safe.  That was in 2010, though, so maybe there are new insights by now.
My model that arrived in the mail today also has only two power pins in the socket -- does this make my machine a QI model?  And if so, is it still safe to use a European power supply?  (I do have a step converter, but I think it's a pain to use that.)
I also noticed that I need to do the composite video mod to get a picture.  While most European TVs handle NTSC nicely I simply have no clue how to connect those flimsy appendages that come out of the modulator.  :)
#2 Ksarul OFFLINE
Ksarul
  • 5,274 posts
Posted Fri Oct 23, 2015 11:53 AM
My former brother-in-law used his 99/4A for several years using a European power supply on a US console. So did I while I was in Germany (nearly 10 years). I've never had a problem with using them that way. . .
#3 Asmusr OFFLINE
Asmusr
  • 3,113 posts
Posted Fri Oct 23, 2015 12:22 PM
I use a US TI 99/4A with a European power supply.
#4 ralphb OFFLINE
ralphb
    Dragonstomper
  • 654 posts
Posted Fri Oct 23, 2015 1:08 PM
Alright, thanks for the confirmation -- wouldn't want to fry my new precious with the first flip of the power switch!
#5 Ksarul OFFLINE
Ksarul
  • 5,274 posts
Posted Fri Oct 23, 2015 1:19 PM
One thing to make sure of: your European power supply needs to be the version that outputs AC. Some early 99/4 power supplies output DC, and they won't work here (unless you're using them with an early release 99/4--as the later 99/4s used the same power supplies as the /4A).
#6 wyerd OFFLINE
wyerd
    Moonsweeper
  • 416 posts
Posted Sat Oct 24, 2015 7:37 AM
I have run a US PSU on a UK spec machine for over a year without any issues. I've recently change the main board to a US spec keeping the original UK AC-DC circuitry inside the console.
#7 Schmitzi OFFLINE
Schmitzi
  • 4,525 posts
  • ToXiC
Posted Sun Oct 25, 2015 2:57 AM
a video mod would be cool, but I would prefer to go to scart-output. was the best solution for me.
but Composite, at least, is much better then PAL/NTSC.
btw the US-machine shoud run at least with any 5pin-modulator on an old TV-screen/Antenna-in,
but this would be a big part of the real vintage experience :)
For the power, I had no problems on firing US-consoles with EU-power here for around one year now.
But one more interesting question for me:
i.e., If I run a TI on 220 Volts (no matter if US- or EU-console, just 220 V),
and if I connect it to a PEB which is running on 110V (by converter), do you expect any issues here ?
Isn´t there any problem like 50/60 Hertz differs inbetween the machines ?
(at the point where the flexcard plugs into the console?)
No "differences" in grounding (green/yellow cable) ?
RMSAAED
#8 Ksarul OFFLINE
Ksarul
  • 5,274 posts
Posted Sun Oct 25, 2015 11:17 AM
I've done that too, Schmitzi--for as long as ten years at a time. I never had any problems.  The Hz is derived from the frequency of the incoming power, so unless you are using an Uninterruptible Power Supply that drops the voltage to 117V and conditions the input frequency to 60 Hz, no matter what the input levels are--you should have no issues there.
Also tagged with one or more of these keywords: power, hardware, pal
