Posted Tue Jun 21, 2016 5:28 AM
Posted Sat Jun 25, 2016 8:56 PM
Posted Wed Jul 6, 2016 9:29 PM
Posted Fri Jul 29, 2016 6:04 PM
Posted Sat Jul 30, 2016 2:18 PM
Posted Mon Aug 8, 2016 6:03 AM
Posted Sat Sep 3, 2016 6:34 AM
Released by Hashy Toys, this Tetris MiniCade Bank was mainly only available in Japan. Based on the same molds as the Excalibur MiniCades, the build quality is quite good. The controls work very well. The sounds can get annoying but thankfully there is a Mute button (labeled Sound) to play the game in peace .
The unit runs of 4C batteries and features a working coin slot on top! There is a small micro switch in the coin slot to detect coins. anything from a arcade token up to a quarter will activate the machine. The bank part of the machine has a very large capacity, there is a screw lock door on the back of the machine to empty out your moola!
The system auto powers down after 3 minutes. To activate it, you insert a coin and get 3 minutes to play the game. The screen is a back lit color LCD and is fairly clear and it plays the familiar "Tetris" song as well.
The gameplay is straightforward Tetris. you can select a starting level and speed then try to get the most amount of "lines" you can. The gameplay screen features a "preview" area showing what the next three pieces to fall will be. Below the preview area is a bonus multiplier (if you remove more than one line at a time the bonus multipler will increase to multiply your score by the number of lines you destroyed. There is also a line score (how many you have destoyed overall) and a timer that will beep at every minute interval. You control your Tetris piece via a joystick and rotate it with two rotate buttons on the right hand side of the control panel. Pushing down on the joystick will drop the piece faster into place.
Pros:
Cons:
Overall I really like this Minicade!. Granted its not VFD based like the Coleco Classic MiniCades, but it does the job well.
Rating: (4 out of 5 Minicades)
Arcade USA Facebook Page
Arcade USA on Youtube
Arcade USA on Twitter
Posted Sun Sep 4, 2016 12:47 PM
Posted Sun Jan 15, 2017 8:07 AM
Great channel, I like your enthusiasm. I discovered you a few weeks ago, subscribed. You show off a lot of stuff I haven't seen before.
Posted Mon Jan 16, 2017 7:31 AM
Thanks I dont post much over here (very little interaction and feedback), the main place where I post vids is Retrogamingroundup.com, Gamerster81.com and Atari.IO
Posted Thu Aug 24, 2017 10:55 AM
Posted Fri Aug 25, 2017 7:20 PM
Qbert MiniCade Give Away! Contest Ends September 9th 2017
Posted Sat Aug 26, 2017 8:38 PM
Bouncing Clown's and Poppin' Balloons in Super Circus AtariAge!
Posted Sun Sep 24, 2017 1:53 PM
Posted Sun Oct 1, 2017 6:57 PM
Posted Tue Oct 3, 2017 5:40 PM
Posted Thu Oct 5, 2017 7:09 AM
Posted Sat Oct 7, 2017 9:25 AM
Posted Sun Oct 8, 2017 2:09 PM
In this new video series i take a look at the Atari 2600 port of Asteroids! Share some thoughts and memories of the game and just have a good time
Posted Sun Oct 15, 2017 5:59 AM
Posted Thu Oct 19, 2017 7:44 PM
Posted Fri Oct 20, 2017 6:16 AM
