ColecoVision Flashback Upgrade Service
112 replies to this topic
#101 Swami OFFLINE
Swami
  • 2,701 posts
Posted Tue Jul 24, 2018 8:28 PM
doublepost.
#102 Swami OFFLINE
Swami
  • 2,701 posts
Posted Tue Jul 24, 2018 8:29 PM
Still doing it!  PM me if you want one done.
Does/can this do/does this include MSX and Amiga emulators, such as BlueMSX and FS-UAE?
#103 mr_me OFFLINE
mr_me
  • 3,949 posts
Posted Wed Jul 25, 2018 3:54 AM
Retropie supports the libretro/retroarch version of bluemsx and the pi is likely too slow for fs-uae.
https://github.com/R...-Setup/wiki/MSX
https://github.com/R...etup/wiki/Amiga
#104 Swami OFFLINE
Swami
  • 2,701 posts
Posted Wed Jul 25, 2018 10:53 AM
Does anyone know which emulators come with it? Is it the whole slew of them listed on the Retropie Wiki Home Page?
https://github.com/R...ki/Colecovision
#105 Swami OFFLINE
Swami
  • 2,701 posts
Posted Wed Jul 25, 2018 6:29 PM
Obviously larger and much more expensive, but I wonder if you could fit an Intel NUC in a vintage ColecoVision case?
#106 Flojomojo OFFLINE
Flojomojo
    I can mash potatoes
  • 15,848 posts
  • I can do the twist
Posted Wed Jul 25, 2018 6:39 PM
You could probably fit two or three NUCs in that battleship of a case. :-P
#107 Airshack OFFLINE
Airshack
    Dragonstomper
  • 962 posts
Posted Wed Jul 25, 2018 8:03 PM
The flashbacks have cheap cases that are pretty boring. Why not put a Raspberry Pi in an original ColecoVision case where the ColecoVision is broken beyond repair, but the case is in good condition?
Because immaculate 35+ year-old cases are not plentiful as are smaller shiny-new Flashback cases.
Sent from my iPhone using Tapatalk Pro
#108 Byte Knight OFFLINE
Byte Knight
  • 1,135 posts
  • Intellivision / Apple II
Posted Sun Nov 25, 2018 2:46 PM
Business is hoppin' all of a sudden for some reason...
#109 CMR OFFLINE
CMR
    Space Invader
  • 45 posts
Posted Mon Dec 10, 2018 12:42 AM
This is a pretty neat project.  You could probably do away with the Ultimate PC Interface using GPIO modules drivers for the controllers.
https://retropie.org...s/GPIO-Modules/
#110 fdr4prez OFFLINE
fdr4prez
  • 1,900 posts
Posted Mon Dec 10, 2018 4:06 PM
I use this GPIO module in my Ultimate Atari Joystick builds, so I am familiar enough with it to get it working for me.
I'd imagine that the GPIO module should work OK for the Colecovision controllers for the directions and the primary fire button.
I am not familiar enough with the Colecovision pinout (pin 5) and the GPIO driver's capability to know about the second fire button and the keypad functionality.  The GPIO module is open source, so someone could update if need be.
Unless I was on a tight budget, I would still use the Ultimate Flashback Interface Board since it is designed to mount right in the Flashback cases, or I'd use the Ultimate PC Interface or the 2600-daptor D9 if I was using a RPi in its own case.
Nothing beats their flexibility to swap between so many different controllers
#111 CMR OFFLINE
CMR
    Space Invader
  • 45 posts
Posted Mon Dec 10, 2018 5:28 PM
I realized after posting that it didn't support colecovision controllers.  That's a shame.  It would be cool if it did.  I wonder if the emulator is open source?  If it is then it might be possible to add colecovision controller support directly.
#112 fdr4prez OFFLINE
fdr4prez
  • 1,900 posts
Posted Mon Dec 10, 2018 5:40 PM
The emulator used is CoolCV
#113 ChildOfCv OFFLINE
ChildOfCv
    Moonsweeper
  • 284 posts
Posted Fri Dec 14, 2018 12:39 PM
It's pretty simple.  If you place a positive voltage on pin 6, you'll get positive voltage from pin 8 if the primary button (FIRE) is pressed, and pin 5 if the secondary button (ARM) is pressed.
Or, as the CV sees it, it puts 2.5V on all the sample pins (including 6), then pulls down pin 8 to see if pin 6 goes low for FIRE, then pulls down pin 5 to see if pin 6 goes low for ARM.
For GPIO, I'd go with the first method though.
