Cortex BASIC in 80 Column
83 replies to this topic
#76 jedimatt42 OFFLINE
jedimatt42
  • 1,834 posts
Posted Fri May 6, 2016 11:53 AM
Adoption would be higher, if development tools like one of the BASIC's worked with it naturally. Where by naturally I mean the language figures out when and why to bank instead of requiring the programmer to perform memory management operations, such as with RXB. TurboForth actually looks like one of the easiest ways for developers to access it without changing much about how they code. ( Except if changing how you code involves learning TurboForth )
There was some prolific Advanced Basic programmer from what I've read about the Geneve. BASIC that is naturally unshackled would be awesome.
Did the Powertran Cortex BASIC have any memory paging before it was ported over?
-M@
#77 Vorticon OFFLINE
Vorticon
  • 3,496 posts
Posted Fri May 6, 2016 12:10 PM
How fast is Cortex Basic compared to XB?
#78 Stuart OFFLINE
Stuart
    Dragonstomper
  • 817 posts
Posted Fri May 6, 2016 12:23 PM
It didn't support huge great BASIC programs stored in paged memory, but did support scanning through memory banks for what it called "extended commands". So you could introduce new commands using paged memory, but couldn't have bigger programs. You could control the memory mapper directly if you wanted store data in paged memory.
#79 Stuart OFFLINE
Stuart
    Dragonstomper
  • 817 posts
Posted Fri May 6, 2016 12:27 PM
There are some benchmarks on the forum somewhere. From memory it was around 1.5 times as fast. Everything is written in assembler - no GPL (apart from the console keyboard scanning routine that it uses).
#80 arcadeshopper ONLINE
arcadeshopper
  • 4,075 posts
Posted Fri May 6, 2016 2:23 PM
I typed in your graphic demo program at the Fest West and showed it to Richard G.  he seemed interested :)   took a long time to draw tho.
Greg
#81 Schmitzi OFFLINE
Schmitzi
  • 4,424 posts
  • ToXiC
Posted Sat Mar 3, 2018 2:52 PM
Hi,
can I use .DSKs in Cortex Basic (Classic99) or is it tape only ?
thx
#82 Stuart OFFLINE
Stuart
    Dragonstomper
  • 817 posts
Posted Sat Mar 3, 2018 4:47 PM
Should work OK.
"Loading/saving from/to disk is now supported using standard device/file names in quotes (for example, SAVE "DSK3.MYPROG" and LOAD "DSK3.MYPROG"). The auto-run feature as described in the Cortex user guide is also supported. Note though that I think the system crashes at the moment if you try to save a file with the same name as an existing file."
#83 Schmitzi OFFLINE
Schmitzi
  • 4,424 posts
  • ToXiC
Posted Sun Mar 4, 2018 3:32 AM
Should work OK.
ah super, thanks, works :thumbsup:
So I packed some oh the demos into a .DSK :)
Attached File  Cortex BASIC Programs_180K.JPG   36.33KB   1 downloads
Attached File  Cortex BASIC Programs_180K.dsk   180KB   6 downloads
#84 RXB OFFLINE
RXB
  • 3,460 posts
Posted Sun Mar 4, 2018 3:57 AM
I have never seen a demo of Cortex Basic yet on video?
