Difficulty running DPC+ example and other programs
dpc+
9 replies to this topic
#1 T-Friz OFFLINE
T-Friz
    Space Invader
  • 29 posts
Posted Sat Dec 12, 2015 6:00 PM
I've been trying to figure out how to use the DPC+ kernel, so I tried compiling the .bas for one of the example programs I found on Random Terrain's website. I can compile and run the code, but I am presented with a blank screen with two lines (see attached screenshot). I've been having the same problem with multisprite programs as well (same blank screen with two lines). I thought that it might be my emulator at first, but I can run the .bin version without any issues. I'm a noob so I'm out of troubleshooting ideas...does anybody know what I'm doing wrong (its probably something silly)? Thanks for the help!
#2 Random Terrain OFFLINE
Random Terrain
    Visual batari Basic User
  • 28,450 posts
  • Controlled Randomness
    Replay Value
    Nonlinear
Posted Sat Dec 12, 2015 10:51 PM
Did you do what it says here:
randomterrain.com/atari-2600-memories-batari-basic-commands.html#gettingstarted
#3 T-Friz OFFLINE
T-Friz
    Space Invader
  • 29 posts
Posted Sat Dec 12, 2015 11:31 PM
:o I am so sorry. I thought I had the most recent bB since I got it from the website...apparently I was wrong. I downloaded the updated version you linked to on your site and it works beautifully now. Thanks for your help!
#4 freshbrood OFFLINE
freshbrood
    Star Raider
  • 56 posts
Posted Thu Aug 17, 2017 1:54 AM
When I assemble my code using setromsize 32k with 8 banks, it works just fine.
But when I replace setromsize 32k with set kernel DPC+ and reduce it to 6 banks, It just gives an error and refuses to assemble.
Can someone tell me why?
#5 kdgarris OFFLINE
kdgarris
    Chopper Commander
  • 226 posts
Posted Thu Aug 17, 2017 5:01 AM
What error? Can you upload an example program that won't compile?
Also, if you are using DPC+, there is no reason to set the romsize explicitly.
#6 Tony The 2600 OFFLINE
Tony The 2600
    Moonsweeper
  • 381 posts
  • 1.19 MHz
Posted Fri Aug 18, 2017 5:44 PM
Hello, you don't need to set the ROM size with DPC+ and the kernel uses all 8 banks. So trying to change it to 6 is probably causing the error because banks 1, 7-8 contain sprite graphics, ARM code and the DPC+ kernel. If you goto the playfield tab and 'rightclick-add-new_item' you will notice an example DPC+ kernel template (assuming you have the latest version of bB).
#7 freshbrood OFFLINE
freshbrood
    Star Raider
  • 56 posts
Posted Sat Aug 19, 2017 1:51 PM
Thank you for your help.
Is is possible to use  player0pointerlo=frame60lo:player0pointerhi=frame60hi:player0height=16
in the DPC+ ? I think that may have something to do with it. If so, what position/banks do you put your data tables/graphics/playfield? Thanks again
#8 Tony The 2600 OFFLINE
Tony The 2600
    Moonsweeper
  • 381 posts
  • 1.19 MHz
Posted Sat Aug 19, 2017 6:32 PM
You can place your 'data_tables/graphics/playfield' where ever you like in banks 2-6, then on compile graphics data will be stored in the graphics bank 7 i believe. RT's basic commands DPC+ kernel
#9 freshbrood OFFLINE
freshbrood
    Star Raider
  • 56 posts
Posted Sun Aug 20, 2017 5:01 PM
I need to condense my code before I post it.. but essentially, if I set romsize 32k it works.. but if I delete this and replace it with set dpc+ it does not.
Would you please tell me what changes to make from 32k to dpc+ ?
#10 Random Terrain OFFLINE
Random Terrain
  • 28,450 posts
    Replay Value
    Nonlinear
Posted Sun Aug 20, 2017 6:49 PM
The bB page has a template:
randomterrain.com/atari-2600-memories-batari-basic-commands.html#dpc_harmony
The bB page also has working example programs that you can look at:
randomterrain.com/atari-2600-memories-batari-basic-commands.html#expro_dpc
Also tagged with one or more of these keywords: dpc+
