Further emulator development
emulator handy xhandy sdl mednafen emu source
45 replies to this topic
#1 sage OFFLINE
sage
    Dragonstomper
  • 959 posts
Posted Sat Jan 2, 2016 12:42 PM
Getting a bit annoyed by the bad situation with lynx emulators I started to patch and back port things to the handy original code.
Bad situation in the sense that it is nearly impossible to get bug-fixes or additional features into (mostly closed source) emulator code.
Nevertheless, all emulator code is derived from the original handy code, but in some emulators a lot of code changes have been applied.
But the original code is abandoned. And this is what I would like to change!
Now I have the hope that, IF we have a central place for the base code, we can advertise it and patches from there find their way to the respective emulators.
The following things are planned or already done:
* Full stereo 16 bit support (10 bit significant)
* Attenuation support (Lynx 2)
* Using second strobe as read on second bank (messed up completely in emulation)
* Use of AUDIN to switch banks (like in Alpine Games)
* lnx format extension to support AUDIN banking
* Using AUDIN + second strobe for read/write to EEPROM (save game)
* TWI EEPROMs (BLL save features)
* Everon bug-fix
* Split code base into "core" and "gui", remove windows dependencies from core
* Compile an up-to-date windows handy version
Repository will most likely be placed at github.
Comments and suggestions?
#2 karri ONLINE
karri
  • 2,504 posts
Posted Sun Jan 3, 2016 2:44 AM
Sounds great. Could the repository be bitbucket/atarilynx? It is a group repository already.
#3 sage OFFLINE
sage
    Dragonstomper
  • 959 posts
Posted Sun Jan 3, 2016 7:04 AM
as its proposed to be public, it actually doesnt matter if I use github or bitbucket.
IMO it should not be a all in one repo. I would prefer to have emulation, tools and compilers seperated to make it easier to pick what you want.
BUt, what are your arguments?
#4 TailChao OFFLINE
TailChao
    Moonsweeper
  • 451 posts
  • Bup?
Posted Sun Jan 3, 2016 10:12 AM
Everything you've listed is an improvement, especially the separation of the windows-specific portions of the emulator and proper stereo support.
However, just to be clear - will you be performing AUDIN and strobe emulation as discussed here?
The only missing improvement I can think of is a more stable framerate in Windows, especially when using DirectX. I have not looked at what Handy is exactly doing here since I started using an NTSC adapter to log video, but it constantly drops frames even on performant computers. Mednafen does not seem to have these issues.
#5 sage OFFLINE
sage
    Dragonstomper
  • 959 posts
Posted Sun Jan 3, 2016 11:43 AM
Yes. Actually the in-code dependence is not so big, as the code with only a few patches is used in SDL handy.
More or less ;-)
First I fixed the bugs in the source code (second bank could never be working with that code) and added a way to use 4 banks with two strobes and AUDIN as additional (kind of) address pin.
Problem: Seems the directx/draw/sound stuff handy was compiled against has been dropped alltogether. at least I cannot get it compiled with VS 2015.
Which means at the moment I only can test the code changes with sdl-handy. but here banking and stereo (and 16 bit stereo that is) are working fine.
#6 sage OFFLINE
sage
    Dragonstomper
  • 959 posts
Posted Sun Jan 3, 2016 11:57 AM
Just to mention that in mednafen the code has been modified to a larger extend, thus a few bugs have been fixed "by accident" there. But it makes it now harder to port back any change.
I know that there was some guy who release a "handy 0.96/7" with some fixes, but I could not find the source code. But it seems that it could at least be compiled with _some_ version of VC then.
#7 karri ONLINE
karri
  • 2,504 posts
Posted Sun Jan 3, 2016 12:42 PM
We can have a separate repository for emulation. Currently there is already compilers in lynx/tools and other stuff like KiCad files, Raspberry Pi programmer sources in lynx/contrib.
So we go with github
I also have Atari Lynx emulator sources for at least PSP and probably Android somewhere.
Edited by karri, Sun Jan 3, 2016 12:45 PM.
#8 TailChao OFFLINE
TailChao
    Moonsweeper
  • 451 posts
  • Bup?
Posted Sun Jan 3, 2016 3:19 PM
The available source for Handy will compile with Visual Studio 6. No idea what other versions it will cooperate with.
#9 obschan OFFLINE
obschan
    Chopper Commander
  • 168 posts
Posted Mon Jan 4, 2016 3:28 AM
I would like to propose libretro for the further improvements.
It is actively developed, it runs on most of the platforms with an unique emulator engine base, and the maintainers are quite keen on getting help.
The improvements will be available to all retroarch users, not only our limited subset.
And if you want to use your own ui, you can directly use the lib and not use their ui retroarch.
Edited by obschan, Mon Jan 4, 2016 4:53 AM.
#10 sage OFFLINE
sage
    Dragonstomper
  • 959 posts
Posted Sat Jan 9, 2016 4:16 AM
So, they are limiuted to ONLY retroarch users... thats exactly what I want to avaoid after my experiecnes with mednafen.
Thus your arguments are just contrary. Or I do not understand them.
  • jum likes this
#11 LX.NET OFFLINE
LX.NET
    Dragonstomper
  • 754 posts
Posted Sat Jan 9, 2016 5:40 AM
How about creating a clean separation of the emulation core from the applications (Handy, Mednafen, etc.). Ideally there would be a standard interface that is provided or adopted from the core. One or more applications can be maintained together with the core to prove/test its functionality. We could look over compatibility and provide upgrades for others to adopt into their codebases.
BTW, I can help out with getting Handy to compile again against Visual C++ 2015 (or Visual Studio 2015). I will have a look. From memory I remember that you need to install the DirectX 9 SDK for the required libraries.
GadgetUK was the one who did some changes in the sound area, to get Gates of Zendocon sound during the spider section. It also has much cleaner sound. I have those sources and can check with him if it is okay for us to look at that and merge into the codebase if we want to.
Also, at the risk of being repetitive, there is also the cross-platform compatible .NET code in C# that I wrote. Apart from a yet unfound bug that causes STUN Runner to crash I believe there is a slightly better implementation of the emulation. It takes much of Handy's ideas, but has a more object-oriented approach. Also, it already has support for EEPROM for 93CX6 and ComLynx works from a single emulator app (up to 6 stable). I would love to hear ideas how we can use and improve that code (or choose it as our basis of further development perhaps :$ ).
I have looked at the repo you made, sage. Will start from there.
#12 obschan OFFLINE
obschan
    Chopper Commander
  • 168 posts
Posted Sat Jan 9, 2016 6:25 AM
This is what libtetro is. Retroarch is the separated ui. Libretro is an emulator engine library.
https://github.com/l.../libretro-handy
#13 sage OFFLINE
sage
    Dragonstomper
  • 959 posts
Posted Sat Jan 9, 2016 6:40 AM
You got the point.
#14 GadgetUK OFFLINE
GadgetUK
  • 1,940 posts
Posted Sat Jan 9, 2016 7:04 AM
No problems here!  I think I left that version of the code a bit messy with bits commented out etc.  And I am not sure the sound buffer sizing is still correct, I just fluffed it really to get it sounding better without really sitting down to think through whether the solution was accurate or not.  The math side of the emulation in Handy isn't 100%  there's still a bug there, perhaps regards timing on how long certain suzi operations take.  Warbirds is a good example - the background rotates further / less than it should, and I suspect its a problem with timing related to suzi.  EDIT: Also note, I added in 2 or 3 of the fixes that LX NET discovered as well - graphical bug fixes and the like.
Edited by GadgetUK, Sat Jan 9, 2016 7:06 AM.
#15 sage OFFLINE
sage
    Dragonstomper
  • 959 posts
Posted Sat Jan 9, 2016 12:24 PM
codebase looks o.k., very close to original code.
the interface is a bit more abstracted.
i will have a closer look at it later.
#16 sage OFFLINE
sage
    Dragonstomper
  • 959 posts
Posted Sat Jan 9, 2016 1:07 PM
My impression from the fixes on the sound system are mixed. Mostly a fix at one place breaks another game.
Yes, but i havent seen any update for a long time :-(
o.k.
#17 sage OFFLINE
sage
    Dragonstomper
  • 959 posts
Posted Sat Jan 9, 2016 2:42 PM
patches for libretro were straitforward... but the compile howto lacks important information.
I hate that.
#18 sage OFFLINE
sage
    Dragonstomper
  • 959 posts
Posted Sat Jan 9, 2016 3:54 PM
o.k. retroarch now has 16 bit stereo (well 2*10 bit ;-)
lets see the reaction on the pull request...
#19 LX.NET OFFLINE
LX.NET
    Dragonstomper
  • 754 posts
Posted Sun Jan 10, 2016 7:38 AM
I guess quick, because the fix has been merged. By obschan if I am not mistaken. Let's see if I can get it all to compile.
Edited by LX.NET, Sun Jan 10, 2016 7:41 AM.
#20 sage OFFLINE
sage
    Dragonstomper
  • 959 posts
Posted Sun Jan 10, 2016 10:18 AM
compile did work immediately, but it was not so clear how to set a working configuration...
#21 sage OFFLINE
sage
    Dragonstomper
  • 959 posts
Posted Sun Jan 10, 2016 12:47 PM
pull request for audin switchable ROMS.
My main problem was testing here. You have to use lynxboot.img in the correct place, the internal "replacement" for the decryption will NOT work. Took me a while to find that out.
#22 karri ONLINE
karri
  • 2,504 posts
Posted Sun Jan 10, 2016 1:07 PM
Did you make some changes for lnx headers in order to tell the emulator that AUDIN is used for addressing the roms?
#23 sage OFFLINE
sage
    Dragonstomper
  • 959 posts
Posted Sun Jan 10, 2016 1:12 PM
yes. one bit of the 40 spare bits.
-> we discussed that two(?!?) years ago here somehow.
#24 karri ONLINE
karri
  • 2,504 posts
Posted Sun Jan 10, 2016 1:14 PM
 I was obviously at sleep during the discussion.
#25 sage OFFLINE
sage
    Dragonstomper
  • 959 posts
Posted Sun Jan 10, 2016 2:06 PM
LOL
At least you participated in the discussing while asleep ;-)
http://atariage.com/...in#entry2578401
Also tagged with one or more of these keywords: emulator, handy, xhandy, sdl, mednafen, emu, source
