MADS bug with OPT F+?
does anybody discovered corrupted file data structur with OPT F+ in MADS?
I run into issue that files are corrupted (WUDSN hex editor, Altirra and exomizer say corrupted file (neverless Altirra starts it correctly). it has several ORGs inside...
I am using MADS 2.0.0
any advice?
it definitly bugs... many ORGs... even ascending order... but OPT F+ produces corrupt file structure... so I did a workaround... dumped memory in Altirra... loaded into superpacker and put header there + run adress and saved that exe file for exomizer...
is there any windows/dos command to add bytes to a file so my batch file could add the headers?
OPT F Works fine here. Beware of the order between ORG/OPT depending on what you want to achieve (re-base vs. fill).
opt h-
org $1000
opt f+
:255 lda #>*
org $3000
:255 lda #>*
opt f-
org $4000
opt f+
:255 lda #>*
org $6000
:255 lda #>*
opt f-
