+SoulBuster Posted January 6, 2016 Share Posted January 6, 2016 I just purchased this drive from eBay. Does anyone have any information about it. A search in Google resulted in practically nothing. http://www.ebay.com/itm/MFD-1080-Disk-Drive-For-Atari-ST-/201497270118?nma=true&si=11j8hLEzgvuu1wb80q73gron%252BvU%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557 Quote Link to comment Share on other sites More sharing options...
walter_J64bit Posted January 8, 2016 Share Posted January 8, 2016 (edited) WoW, that's is inserting 3rd party hardware. I do have the IB drive 5 1/4" only if it's any thing like my drive your going to need a driver to use the 5 1/4" drive in TOS when your replace it. Edited January 8, 2016 by walter_J64bit Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted January 8, 2016 Author Share Posted January 8, 2016 That is why the post here. I cannot find much on Google about this drive. If nothing else, it is a piece of ST peripheral history. At the very least, maybe the 3 1/2 drive will work. I noticed that it has an OUT connector hole on the case without a connector. I am hoping it is as easy as adding a connector to have that work. Quote Link to comment Share on other sites More sharing options...
walter_J64bit Posted January 9, 2016 Share Posted January 9, 2016 (edited) Just by looking at the photos, it looks like you can only use one drive at a time by using the witch labeled 5 1/4 and 3 1/2. I would think that you might be able to use the IB drivers to use the 5 1/4 drive in TOS. The 3 1/2 drive you might not need any drivers just plug and play and for the "OUT connector" you don't need one its just for using multiple disk drives in TOS if you want one I would check with best electronics. Edited January 9, 2016 by walter_J64bit Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted January 11, 2016 Author Share Posted January 11, 2016 I'll try the IB driver. I was thinking the same about the 3 1/2. I could always put this unit as the last drive in the chain, but It would be cool to have the out port available. It looks like it is going to be delivered tonight. Quote Link to comment Share on other sites More sharing options...
walter_J64bit Posted January 11, 2016 Share Posted January 11, 2016 (edited) Here you go IB drivers good luck with your drive. IBDRIVE.ZIP.zip Edited January 11, 2016 by walter_J64bit Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted January 11, 2016 Author Share Posted January 11, 2016 Thanks Walter Quote Link to comment Share on other sites More sharing options...
