TI-99/4A - TMS9938/9958: 80 Col & Enhanced Graphics HW&SW
80col+EGA-stuff TMS9938 TMS9958 EGA PROGRAMs Geneve Dijit Mechatronik TIM SNUG
59 replies to this topic
#51 globeron OFFLINE
globeron
    Dragonstomper
  • 812 posts
Posted Fri Apr 29, 2016 2:39 AM
Yesterday my father had the honour to get the 80-Column card to work  (we removed "extra wiring" which I will put in the next message in this thread)
we compared dip-switch settings, etc.
Assuming that the card always worked is that my guess is that the TV  (SCART / RGB) is the one that fixed it  (and my VCR-SCART is not
reading the signals correctly). The other option is the home-made cable (but I checked that a few times with Ralf) and I got a white dot moving
(which looked like a Synchronisation problem).
80-Column card is the device at the right side (plugged into the side-slot of the TI-99/4A) and requires 5V power adapter.
This 80-Col card has been adjusted with a power switch at the front.
Result:
Attached File  IMG_20160428_211249.jpg   813.56KB   2 downloads
#52 globeron OFFLINE
globeron
    Dragonstomper
  • 812 posts
Posted Fri Apr 29, 2016 2:46 AM
The 80-Col card came with some  components soldered to it
1.  power switch at the front with wiring
     Right 2x wires   (red and black) and PCB-board has a cut/disconnect
     Attached File  IMG_20160428_204002.jpg   817.95KB   2 downloads
2. some resistors ?  (no clue what the purpose is, but there was 1x wire to the video-chip)
    We removed all these first, before plugging it in  (so these were not needed to get the card to work)
     4x wires in total  (I forgot to make a picture of the resistors)
  Attached File  IMG_20160428_203955.jpg   887.92KB   2 downloads
   Attached File  IMG_20160428_204013.jpg   752.86KB   2 downloads
   Attached File  IMG_20160428_204029.jpg   818.41KB   2 downloads
  Question:  anyone has an idea why it would be beneficial ?
3. Some extra wiring and component, no clue what the purpose is
     Attached File  IMG_20160428_203749.jpg   819.34KB   2 downloads
    Attached File  IMG_20160428_203804.jpg   754.34KB   2 downloads
   Attached File  IMG_20160428_203834.jpg   732.14KB   2 downloads
   Attached File  IMG_20160428_203840.jpg   641.64KB   2 downloads
  Question:  I think it goes into the Video-chip location, but then you cannot plug something on top of it
   Any clue  ?
#53 mizapf OFFLINE
mizapf
  • 3,506 posts
Posted Fri Apr 29, 2016 5:12 AM
The TMS9928a in the console delivers the GROMCLK and VDPINT signal. As you remove that circuit, you must get it from somewhere else. This is done by the external video card. You can plug in that socket into the VDP socket in the console.
I know because I had that issue in the last release of MAME/MESS when I moved the v9938 where it actually resides, and then I had to create something very similar to those external cables.
#54 globeron OFFLINE
globeron
    Dragonstomper
  • 812 posts
Posted Fri Apr 29, 2016 5:30 PM
Thank you Michael!
Is it very important?  (because the other 80 col. card does not have it, and it seems to work okay without these cables)
What would be the behavior / risk without having these "GROMCLK and VDPINT signal" ?
When I compared the 80 Col. cards, I noticed a difference in components (e.g. newer software version) and some other
electrical components (but probably these have the same function).
#55 mizapf OFFLINE
mizapf
  • 3,506 posts
Posted Fri Apr 29, 2016 5:54 PM
Is it the EVPC? Or the EVPC2? Or another card?
The problem is that without the VDPINT there is no 60Hz interrupt anymore, in particular no sound, no sprite movement, no QUIT key. And without the GROMCLK the GROMs won't work, so it's pretty important.
Later developments (EVPC2) included a separate unit (Replx99) that was used plugged into the empty VDP socket to deliver these signals.
#56 Schmitzi OFFLINE
Schmitzi
  • 4,473 posts
  • ToXiC
Posted Sat Apr 30, 2016 7:20 AM
The Pics here are taken from the Mechatronik 80 ZK
#57 Schmitzi OFFLINE
Schmitzi
  • 4,473 posts
  • ToXiC
Posted Tue Jul 19, 2016 3:11 PM
New Software :)
Editor/Assembler III and EDIT1 (40/80col) v1.4 by Fred Kaal
http://www.ti99-geek.nl/
#58 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 13,617 posts
Posted Tue Jul 19, 2016 8:00 PM
New Software :)
Have you tried this yet?   I've been very happy with the FlashROM 99 version of EAII with v1.3 of the 80 column editor.
What's so different?
#59 jedimatt42 OFFLINE
jedimatt42
  • 1,850 posts
Posted Tue Jul 19, 2016 10:41 PM
Fred modified his EA II to parameterize how it loads Edit1, so it can be in 40 or 80 column mode. So the same image can be used on F18A or 9938 systems in 80 column mode, or stock 9918 systems in 40 column mode.  He also indicated that there are some additional keyboard shortcuts added to the editor.
The editor keeps the text buffer resident when you go back to the menu where you select load/edit 40/edit 80/save/purge... so you can actually switch between the 40 and 80 column editor without losing data as well.  That is kind of slick, as even on an 80 column capable 4a, you might want to create text data that looks easy to read for 40 column TI users...
-M@
  • RXB likes this
#60 Schmitzi OFFLINE
Schmitzi
  • 4,473 posts
  • ToXiC
Posted Mon Aug 29, 2016 2:29 PM
Hi,
there is a new update on Fred Kaal´s hompage, the Editor/Assembler III r2 module with 40/80 column EDIT1 v1.5
(just klick on "Site history" on the left pane)
xXx
Also tagged with one or more of these keywords: 80col+EGA-stuff, TMS9938, TMS9958, EGA, PROGRAMs, Geneve, Dijit, Mechatronik, TIM, SNUG
