Millipede vs Millipede
Millipede Prototype GCC
17 replies to this topic
#1 Thomas Jentzsch OFFLINE
Thomas Jentzsch
    Thrust, Jammed, SWOOPS!, Boulder Dash, THREE·S, Star Castle
  • 24,031 posts
  • Always left from right here!
Posted Thu Jan 14, 2016 3:16 PM
While the GCC version has a spiffier title screen and plays faster, it's really hard to call it the superior version. Both versions have their pros and cons, and in the end it's all a matter of your own personal taste.
Indeed. So which version do you prefer and why? And how would an optimal, "best of both worlds" version look like?
The linked AtariProtos website already shows a nice comparison and list of difference details. And I can add more:
  • The mushrooms in the GCC protos require only 3 shots to be eliminated. Atari's version and the arcade require 4.
  • The controls in the GCC proto suck, because they are not responsive enough.
  • While the GCC player looks nicer, its movement is much coarser than the Atari version
  • ...what else...?
BTW: Please ignore are technical flaws of the GCC prototypes, I am pretty sure those can be fixed.
#2 maiki OFFLINE
maiki
    Dragonstomper
  • 694 posts
Posted Thu Jan 14, 2016 4:09 PM
If Centipede drove you buggy the Atari Millipede is sure to raid your brain...
I did not even know that there was "another" version of Millipede. Both of them look and behave suspiciously similar and that's why it does not make sence to keep both of them in my Harmony. While the GCC prototype has nice multicolored mushrooms and some of the sound effects are perhaps more polished, the Atari version has much smoother player vertical movement and really burns the TIA to the max... screen constantly filled from top to bottom, from bottom to top
#3 Ramses OFFLINE
Ramses
    Chopper Commander
  • 247 posts
Posted Thu Jan 14, 2016 8:21 PM
Personally, I prefer the grey lower area over blue and the enemy sprites we got in the released version.
#4 Feralstorm OFFLINE
Feralstorm
    Dragonstomper
  • 629 posts
  • Do not taunt Happy Fun Ball®
Posted Thu Jan 14, 2016 10:02 PM
The biggest bother I see in the GCC version is the use of a player object for the player's blaster and forces it to follow the same movement rules as the bugs and other player objects in that display kernel (all vertical motion goes in 'steps' that correspond with the mushroom rows). Presumably that's why the ball (I think) was used for the player's ship for the other versions - to allow free movement without over-stressing the kernel
#5 Impaler_26 OFFLINE
Impaler_26
    Cookie Meister
  • 2,677 posts
  • Braindead
Posted Fri Jan 15, 2016 3:00 AM
I prefer the released version. The GCC version has some nice touches (especially the title screen) but the released version is much more fun to play.
#6 Thomas Jentzsch OFFLINE
Thomas Jentzsch
  • 24,031 posts
Posted Fri Jan 15, 2016 3:54 AM
Why is the released version is much more fun to play? (e.g. better controls, nicer difficulty...)
#7 Thomas Jentzsch OFFLINE
Thomas Jentzsch
  • 24,031 posts
Posted Fri Jan 15, 2016 3:57 AM
Within Stella, press CTRL+F until you get to NTSC 50 mode. Then you can see the colors, which are meant to be used. But in a final version, I suppose they would have given some polishing.
#8 Thomas Jentzsch OFFLINE
Thomas Jentzsch
  • 24,031 posts
Posted Fri Jan 15, 2016 4:03 AM
Yes, that's why they used the ball. It definitely moves much smoother vertically. But what is the benefit of being able to position the player between two rows? IMO that makes it even more vulnerable.
Or is it more a matter of controls? That you cannot really predict in the GCC version, when the player moves a row (note that it moves down at double speed vs up; no clue why, maybe experimental code to show both speeds). Here definitely agree, but that's IMO mainly due to the lousy current controller code. It allows movement only at certain frames, so and movement faces some delay and a quick direction push on the joystick may get ignored completely.
#9 Lynxpro OFFLINE
Lynxpro
  • 3,736 posts
Posted Fri Jan 15, 2016 12:34 PM
What about taking some of the graphics and sound from the GCC prototype and add it to the [otherwise superior] Atari version?
#10 Feralstorm OFFLINE
Feralstorm
    Dragonstomper
  • 629 posts
Posted Fri Jan 15, 2016 11:37 PM
Can't really say on the gameplay, as I've only seen videos and stills so far. It may be just the perceptual expectation - when something is allowed free movement in two axes, it's reasonable to expect the motion to work roughly the same way along those axes. I'd have to try out the GCC to see how it goes in practice though.
I wonder how possible it would be to modify the width/position of the ball per scanline to get a less block-shaped blaster in the Atari version.
Edited by Feralstorm, Fri Jan 15, 2016 11:50 PM.
#11 Tempest OFFLINE
Tempest
    Fallen Moderator
  • 27,124 posts
Posted Sat Jan 16, 2016 8:54 AM
  • ...what else...?
I'll add that info to my page. Thank you.
#12 maiki OFFLINE
maiki
    Dragonstomper
  • 694 posts
Posted Sat Jan 16, 2016 9:16 AM
Objects should always move pixel per pixel if possible. It is just a matter of principle. A proof that the system has the ability to draw the screen properly...
#13 maiki OFFLINE
maiki
    Dragonstomper
  • 694 posts
Posted Sun Jan 24, 2016 9:27 AM
In the end I have decided to add the GCC version to my Harmony as well. There is something positive on the restricted vertical movement of the player and I really like the multicolored mushrooms and sound effects. So now, it is the only prototype I have in there...
#14 Lynxpro OFFLINE
Lynxpro
  • 3,736 posts
Posted Sun Jan 24, 2016 12:56 PM
But does it have native Trak-Ball support?  :)
#15 maiki OFFLINE
maiki
    Dragonstomper
  • 694 posts
Posted Mon Jan 25, 2016 6:27 AM
Is track ball control really that great? I don't know but I remember that it did not feel anywhere near as good as mouse, when I played the Centipede arcade machine with track ball 2 years back. I can't even imagine a track ball in digital joystick mode...
#16 Thomas Jentzsch OFFLINE
Thomas Jentzsch
  • 24,031 posts
Posted Mon Jan 25, 2016 7:02 AM
Trak-Ball or mouse are about the same. The control is precise for both. And you can play the Trak-Ball hacks with an Atari ST or Amiga mouse.
#17 Lynxpro OFFLINE
Lynxpro
  • 3,736 posts
Posted Mon Jan 25, 2016 9:53 AM
Wait…did I miss something?  Did you guys already hack the GCC version?
#18 Thomas Jentzsch OFFLINE
Thomas Jentzsch
  • 24,031 posts
Posted Mon Jan 25, 2016 10:20 AM
Nope. In its current state not worth it, IMO.
Also tagged with one or more of these keywords: Millipede, Prototype, GCC
