SCSI2SD Adapter Works!
115 replies to this topic
#51 arcadeshopper OFFLINE
arcadeshopper
  • 4,286 posts
Posted Mon Feb 1, 2016 10:03 PM
KijGeKziq.gif I don't have a SCSI card for my TI!
what he said
#52 Schmitzi ONLINE
Schmitzi
  • 4,508 posts
  • ToXiC
Posted Tue Feb 2, 2016 4:33 AM
                            SCSI
#53 OLD CS1 OFFLINE
OLD CS1
    >OLD CS1█
  • 6,027 posts
  • Technology Samurai
Posted Tue Feb 2, 2016 9:21 AM
A little trivia: SCSI was originally intended to be pronounced "sexy."
#54 Schmitzi ONLINE
Schmitzi
  • 4,508 posts
  • ToXiC
Posted Tue Feb 2, 2016 9:47 AM
here it sometimes was spoken like [ Schoosee ]   (maybe short for "Excuse Me")   :)
deutsch: [ Skusie ]
#55 mizapf OFFLINE
mizapf
  • 3,563 posts
Posted Tue Feb 2, 2016 9:52 AM
I always called it [Skuh-zee]
(IPA: ['ska:zi:])
Reminds me of one thing I learned on a trip through Peru. There was one site called "Sacsayhuaman" ( https://en.wikipedia...iki/Saksaywaman), and our guide mentioned that this was one of the few Peruvian names that English-speaking people reliably kept in mind. :-D
#56 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,390 posts
Posted Sat Feb 6, 2016 4:07 PM
One of my EZ135 drives failed so I thought 'what better time to try the SCSI2SD device".
Following Chris's lead, I used the Windows SCSI2SD utility to upgrade the firmware to 4.6. I then created a 120MB partition.  Once the PC work was done I returned to the Geneve.
First, I replaced the bad EZ135 (Thanks Omega!).  Once that was functional I searched for a second SCSI cable since my card has two 50-pin connectors. I attached the SCSI2SD device to the second cable.  I did not connect the molex power.
I turned on the Geneve and ran the POWER utility, which found both EZ135 drives, the SCSI2SD device, and the SCSI host adapter.    Using the Geneve SCSI formatter, MYS, I was able to in turn create a 120MB partition.  I copied files to the newly created partition and as best I can tell, everything is working as expected.
My devices and cable termination now look like this:
[Termination]--[EZ135#1]--[EZ135#2]-------------------[SCSI Card]--------------[SCSI2SD]--[termination]
If I have time I'll try a few speed tests between Geneve OS 6.50 and 6.70RC2.  The latter should be about twice as fast.
#57 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,390 posts
Posted Sat Feb 6, 2016 4:20 PM
A few pictures...
I haven't figured out how to mount the SCSI2SD inside my Geneve case.  For now it will rest inside an open slot above my EZ135s.
Attached File  IMG_0235.JPG   695.9KB   3 downloads
POWER utility showing the devices.   The SCSI2SD device is listed as a SLOW device.  ;)  I don't know why it shows version 4.2 as I upgraded the firmware. Hmmm.
Attached File  IMG_0233.JPG   906.53KB   3 downloads
Directory showing the free sectors and a folder I created to copy the PFM flash drive (onboard the Geneve) to the SCSI2SD drive.
Attached File  IMG_0234.JPG   864.74KB   3 downloads
Edited by InsaneMultitasker, Sat Feb 6, 2016 4:22 PM.
#58 OLD CS1 OFFLINE
OLD CS1
    >OLD CS1█
  • 6,027 posts
Posted Sun Feb 7, 2016 7:57 PM
Going to try SCSI-2 mode with the WHT SCSI.
#59 OLD CS1 OFFLINE
OLD CS1
    >OLD CS1█
  • 6,027 posts
Posted Sun Feb 7, 2016 8:04 PM
deutsch: [ Skusie ]
Makes sense... SCSI has a LOT to be sorry for, in particular when it comes to termination. :D  20th Century Voo-doo.
#60 Schmitzi ONLINE
Schmitzi
  • 4,508 posts
  • ToXiC
Posted Mon Feb 8, 2016 8:54 AM
yes. Most common "error" was the the missing SCSI-Power, not jumpered, but needed for active terminators.
I think I still have tons of SCSI-equipment somewhere around here, from all generations.
Have almost stopped using that when switched to NetServers (LH3) & Proliant-servers (G2)
#61 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,390 posts
Posted Mon Feb 8, 2016 5:03 PM
When I try to use the SCS2SD with MDOS (Geneve) OS 6.70RC2, it will not access properly.  A catalog shows "NOTREADYET" for the volume and filenames.
Attempting to reset the SCSI card with a standard reset sequence results in a lockup.  If I disconnect the SCSI2SD, my EZ135s work just fine.
Geneve OS 6.50 works fine.
I have since connected power to the molex connector with the same results.
#62 Shift838 OFFLINE
Shift838
  • 2,539 posts
  • SHIFT838
Posted Mon Feb 8, 2016 7:57 PM
do you think it's just an issue with MDOS 6.7RC2 ?
#63 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,390 posts
Posted Mon Feb 8, 2016 10:09 PM
Uncertain.  All other devices appear to work properly with both OS versions.  If I remove SCSI2SD, everything works fine.  Weird.
#64 Schmitzi ONLINE
Schmitzi
  • 4,508 posts
  • ToXiC
Posted Tue Feb 9, 2016 3:04 AM
hmm, maybe it is worth to test the adapter with SD-device on a PC ?
just to see what happens ?
Maybe you want to check your failed EZ-135 there, too ?
maybe MDOS has a problem with the used SCSI-ID ? (too high or low)
Why is the Geneve's Power-tool showing "slow" speed ?
Is the whole SCSI-bus based on 50-pin/cable ?
#65 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,390 posts
Posted Tue Feb 9, 2016 10:28 AM
Yes - all 50 pin cable.
The POWER tool reports whatever the device specifies.  So this must be how the SCSI2SD is intended to report?
SCSI ID is configurable - no problem with ID
The failed EZ135 was a mechanical problem; it could not properly mount the platter.
I tested with an earlier version of 6.70 and had different results.  For now, I will proceed as if the OS is at fault.   There may be a reset problem due to timing.
One thing is clear - removal of the SCSI2SD device stops the OS from failing. There is a connection...
#66 Schmitzi ONLINE
Schmitzi
  • 4,508 posts
  • ToXiC
Posted Tue Feb 9, 2016 2:01 PM
Yes, I think if you eject the SD-Card, you´ll also "eject" the LUNs, and maybe this device behaves like also releasing the SCSI-ID,
to prevent the host-controller from errors (As otherwise, a hdd-device maybe is reported with the SCSI-ID, and therefor is beeing scanned
or talked to by the host, but nothing but error will work as no hdd/partition or LUN is present)
I don´t have the manual of the SCSI2SD or the Controller here, but maybe you can configure the Synch-Negotiation in a different way,
or the synch speed. I must see the menues to find anything :) but this may be handled different, in MDOS 6.50 and 6.70
Maybe 6.70 is a bit "closer" to the SCSI-RFCs, and does not accept "such things" (which are here coming from a setup-issue)
Or just play around a bit with the possible setup-entries of the SCSI2SD and the controller.
There also was a parameter for "holding" SCSI-devices, without matter what they do (?) I have to remember, I have to see.
Ah OK, "Enable Disconnection", maybe you toggle it if you see it (on the SCSI-Controller).
Maybe just play around with all settings, before you reprogram the (w)holy MDOS 6.70 :)
Sure that terminators are OK, and term-power is activated on 1 device at least ?
xXx
#67 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,390 posts
Posted Tue Feb 9, 2016 2:46 PM
Good ideas.  I will need to test the SCSI2SD device -without- any other devices.
I noticed that some standalone RESET code hangs with the SCSI2SD device on the chain.  So that is where I will start when I have time to debug.
Maybe my Geneve is telling me it is time to finish MDOS 7.00
#68 RickyDean OFFLINE
RickyDean
  • 1,082 posts
Posted Tue Feb 9, 2016 2:48 PM
Yeh,Yeh,Yeh.... ;-)
#69 Schmitzi ONLINE
Schmitzi
  • 4,508 posts
  • ToXiC
Posted Tue Feb 9, 2016 3:07 PM
Yes, I am absolutely sure this is the reason        :waving:
#70 mizapf OFFLINE
mizapf
  • 3,563 posts
Posted Tue Feb 9, 2016 3:23 PM
Will this be a forced upgrade? ;)
#71 Schmitzi ONLINE
Schmitzi
  • 4,508 posts
  • ToXiC
Posted Tue Feb 9, 2016 3:27 PM
yes, if you SLIP into the internet you´ll be brute-auto-updated :)
#72 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,390 posts
Posted Thu Feb 11, 2016 11:34 AM
Oh my.  Don't put such naughty ideas into my mind!!!  ;)
#73 mizapf OFFLINE
mizapf
  • 3,563 posts
Posted Thu Feb 25, 2016 8:28 AM
In the meantime, I got my SCSI2SD as well. I take a 2 GiB microSD card (which will be only filled with 248 MiB, so the rest may serve for its internal wear leveling) and tested in on the Geneve with SCUZZY in GPL mode. I found that SCUZZY only works with ROMPAGE, by the way; otherwise it locks up.
This is my way of mounting that card. The cardboard box is the one it was shipped in. Maybe I'll have to look for a shorter SCSI cable, but this one was the only one I could get hold of. The package had a price tag with DM and Euro (which means that it was stuck on it about 15 years ago - or the seller is already betting on the downfall of the Euro, but I think the first option is true).
#74 mizapf OFFLINE
mizapf
  • 3,563 posts
Posted Thu Feb 25, 2016 9:46 AM
Wow ... now that's pretty cool!
I tested my SCSI2SD device with SCUZZY, as written above, and there was an option "format", but the disk was still unusable. Then I read Tim's message here, talking about MYS, but as usual, you don't find things when you need them most urgently.
Then I had an idea: Why use MYS? There is nothing like low-level format for a SCSI device, and particularly not for a Flash card. It should be possibly to simply use the PC and write a ready-to-use image on the card. This could be done using TIImageTool.
Yes, and that worked indeed!
  • Use your favorite file manager to create a copy of your hard disk image which you want to use on the TI/Geneve. Alternatively, create a new SCSI hard disk image in TIImageTool and copy everything on this new image.
  • If you did not create the copy as a SCSI image yet, you can change the type in "Utility". In any case, the image for the SD card must be a SCSI type image. Do you convert your working image on the PC, since you will lose information when converting from HFDC to SCSI type.
  • Export the contents from the CHD to a file. ("Utility")
  • Use the dd command in Linux or install the dd utility for Windows. Note that you must be root/Administrator to directly write to a drive.
  • Copy the extracted raw file on the SD card. Make sure you don't accidentally overwrite your hard disk (which is not a big problem, since you certainly perform daily backups)
  • Remove the SD card, and use it in your TI/Geneve. Done!
(Some of these points could be simplified by using "open device", but I cannot recommend it, as it will be removed in the next release. Working with real devices should be done by special tools like dd.)
#75 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,390 posts
Posted Thu Feb 25, 2016 10:00 AM
Fred's DU2K should also work with the Geneve so long as you use GPL (not EXEC).   I do not remember if ROMPAGE is required.
Nice alternative with TIImageTool!   ( I even used the right name this time!)
