mantadoc Posted January 24, 2016 Share Posted January 24, 2016 (edited) Maybe i sort it out Richard Edited January 24, 2016 by mantadoc Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted January 24, 2016 Share Posted January 24, 2016 what happened ?? Quote Link to comment Share on other sites More sharing options...
mantadoc Posted January 24, 2016 Author Share Posted January 24, 2016 Hmm i thought i erased the topic , i am messing around in network resistors , i need a 4k7 ,14 pins , but hopeless to find , then i was thinking i could take a 16 pins and not use the left 2 pins , any idea or a link to the 4k7 14 pins network resistor ? 1 Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted January 24, 2016 Share Posted January 24, 2016 hmm, is that something to eat ? please give me some more info what that is, I´ll have a look here at grossist ( or pls check www.reichelt.de and tell me) Quote Link to comment Share on other sites More sharing options...
mantadoc Posted January 24, 2016 Author Share Posted January 24, 2016 This should be the one , but not on stock Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted January 24, 2016 Share Posted January 24, 2016 hmm I really don´t know about, clueless.... Maybe you want to check it at www.reichet.de and give me their number, if you can find it ? I have already checked minutes ago, but I think you have to search for other words that I don´t know.... Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted January 24, 2016 Share Posted January 24, 2016 Radio Shack in Australia says they have them in stock, with a minimum buy of 25 pieces. 1 Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted January 24, 2016 Share Posted January 24, 2016 Here's an alternate part number for you: SOMC14034K70GEJ If you are searching for the one that has 7 isolated (not bussed) Resistors, correct? If so, you could do as you thought and just clip the leads off the last resistor on a 16-pin and put it on the board that way. If it is a bussed resistor, make sure pin1 is present (the common) and clip the furthest two leads, and again, it should work. The 16-pin types seem to be in stock everywhere. The only place I found with 14-pin isolated-types in stock was the one in Australia. . .and everyone else had a 2,000 piece minimum order. Quote Link to comment Share on other sites More sharing options...
mantadoc Posted January 24, 2016 Author Share Posted January 24, 2016 Thank you very much , that was helpful , and found it on the RS Danish site It looks to be the same : http://www.digikey.com/product-detail/en/767143472G/767-143-R4.7K-ND/47797 The link have the exact resistor type as written in the component list , isolated resistor Now waiting for the parts ..... Richard Quote Link to comment Share on other sites More sharing options...
Shift838 Posted January 24, 2016 Share Posted January 24, 2016 Thank you very much , that was helpful , and found it on the RS Danish site It looks to be the same : http://www.digikey.com/product-detail/en/767143472G/767-143-R4.7K-ND/47797 The link have the exact resistor type as written in the component list , isolated resistor Now waiting for the parts ..... Richard When I originally did the large parts buy for the IDE project I purchased these at DigiKey. Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted January 24, 2016 Share Posted January 24, 2016 I went there first too, Chris, but they are no longer a stocked item--and with a minimum order of 2,000 pieces to get them to make an order for you, they are a bit cost-prohibitive for that part now. Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted January 24, 2016 Share Posted January 24, 2016 Why not get a socket and populate it with the appropriate resistors? ...lee Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted January 24, 2016 Share Posted January 24, 2016 Surface mount parts. . .no room for a standard socket. Quote Link to comment Share on other sites More sharing options...
Shift838 Posted January 25, 2016 Share Posted January 25, 2016 wondering if this below is a cross for it. It looks like it but I'm not sure: HERE Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted January 25, 2016 Share Posted January 25, 2016 I just pulled up the datasheet. The "A" variants of that series are the Isolated type we need. The "B" are bussed, and the "J" type are dual termination. I just bought some to have on hand, as I still have at least one of these boards that I haven't assembled yet. . . Quote Link to comment Share on other sites More sharing options...
mantadoc Posted January 26, 2016 Author Share Posted January 26, 2016 Thanks ?? Last thing i need , anyone who had a link or site where i can find this slide switch look picture where to mount ? Quote Link to comment Share on other sites More sharing options...
mantadoc Posted January 26, 2016 Author Share Posted January 26, 2016 Sw2 Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted January 26, 2016 Share Posted January 26, 2016 Here a picture maybe for a better identification: 2 Quote Link to comment Share on other sites More sharing options...
mantadoc Posted May 4, 2016 Author Share Posted May 4, 2016 Hmm working on Ide card ... Trouble , can't see there should be any errors , any of you knowing about chip ALS373 is the same as ALS373A ? it´s the only difference i can see........ any ideas ? 1 Quote Link to comment Share on other sites More sharing options...
Shift838 Posted May 4, 2016 Share Posted May 4, 2016 Hmm working on Ide card ... Trouble , can't see there should be any errors , any of you knowing about chip ALS373 is the same as ALS373A ? it´s the only difference i can see........ any ideas ? Is the fly in the picture Supervising or Inspecting the board? 2 Quote Link to comment Share on other sites More sharing options...
mantadoc Posted May 4, 2016 Author Share Posted May 4, 2016 Is the fly in the picture Supervising or Inspecting the board? Hehe ,oh did not know the board had visitors Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted May 4, 2016 Share Posted May 4, 2016 coool, didn´t realize that visitor.... George McFly on the IDE-trip Built on the fly .... Quote Link to comment Share on other sites More sharing options...
ti99iuc Posted May 4, 2016 Share Posted May 4, 2016 (edited) Is the fly in the picture Supervising or Inspecting the board? it is the SuperFly's Sprite that want fire the Bug in the Cards ! Edited May 4, 2016 by ti99iuc 2 Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted October 8, 2016 Share Posted October 8, 2016 1 Quote Link to comment Share on other sites More sharing options...
