Stella 4.7 released
stella paddles
23 replies to this topic
#1 stephena OFFLINE
stephena
  • 3,390 posts
  • Stella maintainer
Posted Mon Jan 25, 2016 4:09 PM
So it's time for a new release of Stella.  I've been sick over the past few months, and didn't get to work on Stella as much as I'd have liked.  Anyway, here it is:
* Improved paddle emulation in several ways:
    - Added ability to specify the maximum range of movement for paddles when using a mouse or digital device to emulate the paddle. This is useful since on a real console most paddle games use very little of the paddle range, and could result in moving the mouse onscreen with nothing appearing to happen (when in effect it was as if you turned a real paddle all the way to the end of the range). This eliminates issues in (for example) Kaboom, where there was a huge 'deadzone' when moving to the left. All applicable ROMS in the internal database have been updated.
    - The range for paddle emulation now takes an integer from 1 - 20, indicating how much to scale movement (ie, how fast the onscreen paddle will move when you move the mouse). The movement itself is now also smoother than before.
* Fixed bug in 'Score mode' in TIA emulation; the TIA object colours were correct, but the associated priority was sometimes incorrect.
* Fixed bug in ROM launcher; selecting 'Options -> Game Properties' after loading a ROM would always point to the last opened ROM, not to the one currently selected.
* Fixed bug in storing ROM properties; in some cases, a copy of the ROM properties was being stored in the external file when it was exactly the same as the internal entry.
* Added 'CV+' bankswitching scheme, developed by myself and LS_Dracon (of AtariAge). This scheme contains RAM like the CV scheme, and also switchable 2K ROM segments by writing to $3D.
* Added more C++11 updates all over the codebase, and ran Stella through Coverity for the first time. I'm proud to say that Stella now has a 0.00 defect rate!
A number of bugs from the '4.6.5 release thread' have been fixed, but there's still a few more to go.  As usual, Stella can be downloaded here, and donations are welcome here.  Feedback can be in this thread or by PM.
#2 SpiceWare OFFLINE
SpiceWare
    Draconian
  • 12,765 posts
  • Medieval Mayhem
Posted Mon Jan 25, 2016 4:37 PM
Awesome!
I've had some ideas on making the screen jitter work better - it should take multiple frames, not just one, to recover from a large variance in scanline count (i.e. a screen roll).  I'll make sure to get the latest source this weekend before I work on it.
#3 wongojack OFFLINE
wongojack
  • 3,322 posts
Posted Mon Jan 25, 2016 6:37 PM
Thanks.  I'll have to get a few games of Kaboom in and see how it plays!
#4 wongojack OFFLINE
wongojack
  • 3,322 posts
Posted Tue Jan 26, 2016 7:56 PM
Ok, I see that digital paddle sensitivity now goes up to 20.  Where does one configure the range of movement?
#5 stephena OFFLINE
stephena
  • 3,390 posts
  • Stella maintainer
Posted Wed Jan 27, 2016 10:57 AM
Both the 'digital paddle sensitivity' and 'mouse paddle sensitivity' can now go to 20, but the former is for digital inputs (ie, digital joystick, keyboard, etc), and the latter is for the mouse.  So if you're using the mouse for paddle movement, the latter is what you should be changing.
The range of movement is per-ROM, and as such is accessed in 'Game Properties' for each ROM.  It basically says how far left the mouse/digital input can move before it stops sending 'paddle events'.  It eliminates a huge deadzone on the left which is the result of real paddles not using the full range of rotation.  All paddle games in the internal ROM database have already had this adjusted, so you shouldn't need to mess with it.  If you do want to change it, see Game Properties -> Controller -> Mouse axis range.
#6 Keatah OFFLINE
Keatah
    Missile Commander
  • 22,097 posts
Posted Wed Jan 27, 2016 11:05 AM
I believe Breakout has more slop on the right side now. I'll have to re-check it later this weekend when I have access to my proper emulation rig.
#7 stephena OFFLINE
stephena
  • 3,390 posts
  • Stella maintainer
Posted Wed Jan 27, 2016 11:11 AM
I don't see how the right side would have changed.  This corresponds to turned 'completely clockwise' on a real paddle, and wasn't addressed at all by my code changes (unless I accidentally introduced a bug).  I concentrated specifically on the left side/counter-clockwise movement.
#8 wongojack OFFLINE
wongojack
  • 3,322 posts
Posted Wed Jan 27, 2016 12:29 PM
Perhaps a taboo question, but I am not sure what the ROM database is that you are referencing.  Is it the ROMs or just the data that recognizes when specific ROM is opened?  I'll look more carefully on the Stella website, but if you can point me in the right direction, that would be helpful.
#9 stephena OFFLINE
stephena
  • 3,390 posts
  • Stella maintainer
Posted Wed Jan 27, 2016 1:37 PM
The internal database I refer to is one that's built into Stella.  You can see if by referencing the code here.  All I meant is that I've manually went through all the paddle ROMs in the internal database and added an appropriate range for each one.  So you shouldn't need to change the range at all.  Now, if you're using a ROM that isn't in the database, then of course you're free to change the range.  I just meant that it's currently as plug-and-play as possible; you shouldn't need to do anything for common ROMs; I've already taken care of it.
#10 israelg OFFLINE
israelg
    Moonsweeper
  • 409 posts
Posted Wed Jan 27, 2016 4:07 PM
Thanks!  :)
#11 Thomas Jentzsch OFFLINE
Thomas Jentzsch
    Thrust, Jammed, SWOOPS!, Boulder Dash, THREE·S, Star Castle
  • 24,033 posts
  • Always left from right here!
Posted Fri Jan 29, 2016 1:41 PM
Stephen, I will let you know about v12. :)
#12 SpiceWare OFFLINE
SpiceWare
    Draconian
  • 12,765 posts
  • Medieval Mayhem
Posted Sat Jan 30, 2016 9:11 AM
Think this turned out pretty good.  The blog entry has a test build for OS X, as well as the 2 source files that were changed in case somebody wants to build and test it on Linux or Windows.
#13 stephena OFFLINE
stephena
  • 3,390 posts
  • Stella maintainer
Posted Sat Jan 30, 2016 11:38 AM
Spice, I'll look at the code soon.  I just wanted to report I found a bug with the new 'paddle range' stuff for Medieval Mayhem; the range is adjusted too low, so you can't select the # of players :(  I've already committed a fix, which will be in the 4.7.1 release.
#14 stephena OFFLINE
stephena
  • 3,390 posts
  • Stella maintainer
Posted Sat Jan 30, 2016 12:20 PM
The blog entry also contains test builds for Windows too now.
#15 InversePhase OFFLINE
InversePhase
    Combat Commando
  • 8 posts
Posted Thu Feb 4, 2016 5:04 AM
Hey Stephen, congrats on the release! Looking forward to playing some paddle games to test it out.
By the way, a potentially strange request: can you post the changelog more prominently on your website? Even just a sidebar link on the stella site to the current text version of the changelog/whatsnew would be useful.
#16 stephena OFFLINE
stephena
  • 3,390 posts
  • Stella maintainer
Posted Thu Feb 4, 2016 6:03 AM
It's under "Stella News", but now that I think of it, all it contains is the Changelog anyway, so I may as well change the name of the link.
#17 cjameslv OFFLINE
cjameslv
    Dragonstomper
  • 656 posts
Posted Thu Feb 4, 2016 10:20 AM
Thanks for the update!
#18 Prosystemsearch OFFLINE
Prosystemsearch
    Dragonstomper
  • 876 posts
Posted Sun Feb 7, 2016 10:17 AM
Don't have stella, but good update! Now if only some more of the Supercharger bugs got fixed and support for light gun games were addressed...
#19 Keatah OFFLINE
Keatah
    Missile Commander
  • 22,097 posts
Posted Wed Feb 10, 2016 5:17 PM
Three ways to do light-gun support.
1- You'd have to simulate the light-gun "pointed-to" area by way of crosshairs overlayed on the game screen, and controlled with a mouse.
2- Build a sensing array and controller that transmits it's position, not unlike wii and xbox.
3- Have the lightgun analyze the game frame, and tell the console/emulator what pixels it just pointed at when the trigger was pulled. Tell that information to the emulator. The emulator would need to be aware of where it was in the screen rendering process along and correlate that with the gun timing to determine if a target was hit.
There are other means, but I don't have time to type them in at the moment.
#20 stephena OFFLINE
stephena
  • 3,390 posts
  • Stella maintainer
Posted Wed Feb 10, 2016 5:40 PM
The lightgun, KidVid, and Compumate controllers are something I want to work on when I find more time.  But since they only affect a few games each, there are other more serious issues that have higher priority.
About the Supercharger though, what bugs are there??
#21 Keatah OFFLINE
Keatah
    Missile Commander
  • 22,097 posts
Posted Fri Feb 12, 2016 3:17 AM
CPU usage bug report for 4.7:
I noticed that the rom selector screen makes my older laboratory machine run at 100% usage. That's not good.
However, when playing Miniature Golf the usage is 20-50% which is what I would expect for this level of hardware.
Version 3.9.3 shows 0-2% usage while in the rom selector screen, essentially nothing.
#22 Thomas Jentzsch OFFLINE
Thomas Jentzsch
  • 24,033 posts
Posted Sat Feb 13, 2016 1:59 AM
When is the scan line counter reset bug fixed, that happens when you e.g. hit a break in the debugger?
#23 Keatah OFFLINE
Keatah
    Missile Commander
  • 22,097 posts
Posted Sat Feb 13, 2016 4:09 AM
Talking to me? The high cpu usage problem happens right away at startup. No debugger.
#24 stephena OFFLINE
stephena
  • 3,390 posts
  • Stella maintainer
Posted Sat Feb 13, 2016 1:33 PM
I've just released Stella 4.7.1, so the remaining bugs here will have to be addressed for the next release.
Also tagged with one or more of these keywords: stella, paddles
