metzger130 Posted February 2, 2016 Share Posted February 2, 2016 I have 2 controllers that work well, and I have 4 that have different issues with them, some buttons stick, some don't fire, etc etc. how hard are coleco controllers to take apart and fix? I have fixed my atari 5200 controllers MULTIPLE times so not sure if it's the same basic thing inside these or not. Quote Link to comment Share on other sites More sharing options...
R.Cade Posted February 2, 2016 Share Posted February 2, 2016 They hold up much better than 5200 sticks. The fire buttons are "real" switches and the directions are just hard contacts. Usually they just need cleaning with contact cleaner. Not sure about the number pads- I've never had to repair those. Quote Link to comment Share on other sites More sharing options...
Hannacek Posted February 2, 2016 Share Posted February 2, 2016 Coleco controllers are relatively easy to take apart and clean. So long as no plastic or metal pieces are broken, they should work after a cleaning. Just see if any bits of plastic or metal are loose inside when you open it up. If no little bits fall out when you open it up, you should be good. Quote Link to comment Share on other sites More sharing options...
ColecoNoob Posted February 2, 2016 Share Posted February 2, 2016 Or - as an alternative - simply replace the contact plates and switches with micro tactile switches. It's not that hard to do though minimum soldering skills are needed. Quote Link to comment Share on other sites More sharing options...
NIAD Posted February 2, 2016 Share Posted February 2, 2016 Also be aware that the wires connected to the keypad from the PCB will either be soldered or crimped on clips. The crimped on clips are very brittle after all these years and easily break. Quote Link to comment Share on other sites More sharing options...
ColecoNoob Posted February 2, 2016 Share Posted February 2, 2016 (edited) I can confirm that for the soldered version too :/ But after resoldering the cables they should now last another 30+ years I don't want to abuse this thread but as it is quite fresh I would like to use this for my question: Has anyone who modified his CV controller to tactile switches found a way to stabilize the joystick? As the big spring is gone mine is whobbling around. Putting in the original spring is not an option as it prevents completely the stick from moving and will force all tactile switches in the "pressed" position. Also I would like to know, how to straighten the coiled cable of the controller. Is there a safe and "easy" way to perform this mod? Thanks in advance guys! Edited February 2, 2016 by ColecoNoob Quote Link to comment Share on other sites More sharing options...
Hannacek Posted February 3, 2016 Share Posted February 3, 2016 I wouldn't bother trying to straighten the cords. Its not worth the time or effort, and the coiled cords are part of the charm and history of the ColecoVision.You can buy Sega Genesis extension cables for $4-$5, and that makes the coiled cord a non-issue.I use Genesis extension cables on all my consoles (that have the 9 pin connector). You get much need extra cord length, and also you don't risk damaging the joystick ports by plugging controllers in and out of them. The ColecoVision has a problem with the controller IC failing, so using extension cables helps protect the system. Quote Link to comment Share on other sites More sharing options...
ValkerieSilk Posted February 3, 2016 Share Posted February 3, 2016 There’s a new method of taking the controller apart, start here… http://atariage.com/forums/topic/248669-is-it-just-me-or/ Coleco controllers are relatively easy to take apart and clean. So long as no plastic or metal pieces are broken, they should work after a cleaning. Just see if any bits of plastic or metal are loose inside when you open it up. If no little bits fall out when you open it up, you should be good. 1 Quote Link to comment Share on other sites More sharing options...
