OS X RespeQt issues
MAC OSX RESPEQT
19 replies to this topic
#1 TheMontezuma OFFLINE
TheMontezuma
    Dragonstomper
  • 676 posts
Posted Wed Feb 3, 2016 3:24 AM
I started a new topic: "OS X issues" with focus only on the OS X specific problems/changes, etc.
The Logic Analyzer helped me to understand the lower communication speed over Bluetooth.
The timing of the Bluetooth stack in the OS X seems to be ugly.
Instead of expected ~50ms pauses between data chunks I observed ~250ms pauses (200ms additional delay in OSX BT stack?)
Additionally bigger data chunks were not transmitted in one shot.
With "bigger" I mean a diskette sector + checksum (129 bytes), There was a 200ms pause in between.
The virtual serial port is opened with O_NDELAY parameter, so the "read()" and "write()" calls are non blocking.
The "write()" call will not necessarily process all bytes. It returns the number of bytes that could be written.
The still awaiting bytes have to be sent in the next "write()" call (in a loop) and this happens for 129 bytes (sent in to chunks: 126 + 3)
At the end, the data transfer was successful, but I don't have any idea how to improve that :?
Edited by TheMontezuma, Wed Feb 3, 2016 3:26 AM.
#2 TheMontezuma OFFLINE
TheMontezuma
    Dragonstomper
  • 676 posts
Posted Fri Feb 5, 2016 2:36 AM
After looking at the code and thinking it over, I think that this issue simply reveals a poor design of the application :(
Normally GUI applications start threads to execute lengthy or blocking tasks, so the user can still interact with the GUI.
AspeQt/RespeQt has a SIOWorker QThread, but if it is blocked, the GUI is blocked as well...
That's why the serial port is opened in a non blocking mode and every IO operation exits after a timeout to keep the application responsive :-o
#3 Smokeless Joe OFFLINE
Smokeless Joe
    Moonsweeper
  • 289 posts
Posted Sat Feb 6, 2016 5:02 PM
I just started using RespeQt with DrVenkman's Jan 31, 2016 build.  I love it, but if I cmd-Q or RespeQt > Quit RespeQt, it tells me that it quit unexpectedly.  Clicking the red button will close it without error.
Definitely minor, but annoying.  Any ideas what's going on?
#4 DrVenkman OFFLINE
DrVenkman
  • 3,968 posts
  • Back off, man! I'm a scientist.
Posted Sat Feb 6, 2016 7:33 PM
Glad it's working for you! I get the same error, for what it's worth. I think it's got to be some kind of bug in either Qt itself or in the application close/shut down process. Doesn't seem to harm anything or damage any of the loaded .ATR images so far as I can tell, just a silly annoyance.
#5 Dmitry OFFLINE
Dmitry
    Chopper Commander
  • 240 posts
Posted Tue Apr 19, 2016 6:43 PM
deleting
Edited by Dmitry, Tue Apr 19, 2016 6:46 PM.
#6 Dmitry OFFLINE
Dmitry
    Chopper Commander
  • 240 posts
Posted Tue Apr 19, 2016 6:46 PM
Sorry for the weirdness, was testing some posting from code.
Edited by Dmitry, Tue Apr 19, 2016 6:48 PM.
#7 TheMontezuma OFFLINE
TheMontezuma
    Dragonstomper
  • 676 posts
Posted Sun Aug 7, 2016 7:15 AM
I got a new Mini Mac and I downloaded RespeQt-r3, but I'm not able to get it running with my SIO2PC/USB cable.
The virtual serial port is visible under /dev
When I change the handshake to NONE, I see at least the RespeQt log window the "GetStatus" command.
However the answer (status) is not reaching the ATARI.
I was able to setup Bluetooth connection with my SIO2BT and everything works well.
My SIO2PC/USB cables are OK (work perfectly on a WIndows and on a Linux machines),
so I suspect the serial port driver or the USB hardware (Mini Mac has only USB 3.0 ports).
Any ideas?
#8 Joey Z OFFLINE
Joey Z
    Dragonstomper
  • 876 posts
Posted Sun Aug 7, 2016 8:34 AM
Any ideas?
there are tty devices, and cua devices, maybe try the other? (just a shot in the dark)
Edited by Joey Z, Sun Aug 7, 2016 8:35 AM.
#9 JoSch OFFLINE
JoSch
    Moonsweeper
  • 495 posts
Posted Sun Aug 7, 2016 10:12 AM
I bought the SIO2PC-USB dongle from Lotharek and used the OSX driver, he links to on his website.
That works fine for me.
#10 TheMontezuma OFFLINE
TheMontezuma
    Dragonstomper
  • 676 posts
Posted Sun Aug 7, 2016 11:52 AM
A driver update from FTDI has helped.
#11 tuf OFFLINE
tuf
    Chopper Commander
  • 245 posts
Posted Sat Aug 20, 2016 3:04 PM
I might have missed this, but does this imply that an SIO2BT works with respeQt?
#12 flashjazzcat ONLINE
flashjazzcat
  • 14,498 posts
Posted Sat Aug 20, 2016 3:27 PM
It most certainly does. Configure RespeQt for your BT virtual COM port and select "Handshaking: None".
#13 tuf OFFLINE
tuf
    Chopper Commander
  • 245 posts
Posted Sat Aug 20, 2016 5:37 PM
Ok this is exciting.  I noticed since updating my U1MB my OS slots have changed - which OS provides the SIO2BT patching?
#14 flashjazzcat ONLINE
flashjazzcat
  • 14,498 posts
Posted Sat Aug 20, 2016 5:45 PM
You can use SIO2BT with any OS by turning on HSIO+SIO2BT in the U1MB PBI BIOS. You can do this without using the SIDE HDD and it's compatible with cartridges. Imminent update supports faster SIO2BT speeds too.
Of course you can still use a patched version of the High speed OS if you prefer, or if you use SDX, optionally configure its SIO driver for SIO2BT. PBI high speed driver takes precedence over everything else when enabled, though.
#15 tuf OFFLINE
tuf
    Chopper Commander
  • 245 posts
Posted Sat Aug 20, 2016 6:16 PM
Working!  I should note that I had to select "SOFTWARE (SIOBT)" under handshake method to get it working in RespeQt.  This is with a U1MB and the PBI SIO2BT options enabled, as you suggested.  Thanks for the help!
#16 flashjazzcat ONLINE
flashjazzcat
  • 14,498 posts
Posted Sun Aug 21, 2016 4:36 AM
Yes: I had a blonde moment there. Software handshake. :)
#17 Joey Z OFFLINE
Joey Z
    Dragonstomper
  • 876 posts
Posted Tue Apr 11, 2017 1:37 PM
yes, this should be fixed. Have we talked about this ever? I'd appreciate it if you could add an issue to github, more things that really should be fixed, to add to the ever growing list.....
#18 Level42 OFFLINE
Level42
  • 2,602 posts
Posted Thu Sep 7, 2017 6:02 AM
I stil have the issue that sometimes I can drag and drop files into the drive positions but sometimes I have to click the disk icon (or folder icon) and go through the menu to mount an ATR or folder.
#19 DrVenkman OFFLINE
DrVenkman
  • 3,968 posts
Posted Thu Sep 7, 2017 3:56 PM
This isn't a strictly-OS X issue though; I have the same problem running on my RPi boxes, though I don't think I've seen it in (very limited) use with my Win10 box. Of course, my Win10 box is VASTLY overpowered compared to my Pi's, so maybe it's just that the (inefficient) core code just executes faster on my (much faster) Winbox?
#20 Level42 OFFLINE
Level42
  • 2,602 posts
Posted Fri Sep 8, 2017 1:05 PM
Encountered this behavior when I first used it so I'm a bit surprised it still isn't fixed. It's annoying as hell.....o well....it's free software.
Edited by Level42, Fri Sep 8, 2017 1:06 PM.
Reply to this topic
Also tagged with one or more of these keywords: MAC, OSX, RESPEQT
