RespeQt on Raspberry Pi?
52 replies to this topic
#26 TheMontezuma OFFLINE
TheMontezuma
    Dragonstomper
  • 661 posts
Posted Mon Mar 14, 2016 2:49 PM
There was an issue with the Qt file dialog windows, with case sensitivity of the file suffixes (atr is not equal ATR), but I didn't see it with the newest Qt.
Can you try the precompiled binaries from my post above?
#27 TheMontezuma OFFLINE
TheMontezuma
    Dragonstomper
  • 661 posts
Posted Fri Mar 18, 2016 2:37 AM
R3 binaries: http://atariage.com/...d/#entry3471143
#28 DrVenkman ONLINE
DrVenkman
  • 3,710 posts
  • Back off, man! I'm a scientist.
Posted Sun Mar 20, 2016 4:45 PM
I downloaded the R3 source and compiled on my RPi2 this evening - up and running in less than 10 minutes just like last time. Running great here.
#29 DrVenkman ONLINE
DrVenkman
  • 3,710 posts
Posted Sun Jul 24, 2016 5:34 PM
So for what it's worth, I downloaded the current repository from Git on the RPi2 that I use for SIO emulation with my A8 machines. I experimented with manually setting the POKEY divisor but haven't changed the error delay timing at all ... at any rate, my first try let me boot my 800XL with a nifty little speed boost. :)
#30 DrVenkman ONLINE
DrVenkman
  • 3,710 posts
Posted Mon Jul 25, 2016 5:47 AM
Okay, so a little follow-up. On my RPi2, I can go as low as POKEY divisor 3 and get reliable transfers at a bit over 89 kbps. Any higher causes stuttering and dropping back to 19.2. So far as I can tell, changing the delay timing from the default 860 µs makes things worse rather than better, whether I increase the delay or lower it.
#31 David_P ONLINE
David_P
    Dragonstomper
  • 928 posts
Posted Sun Feb 26, 2017 6:01 PM
Any advice on how I can get this running on my PogoPlug (v2), running ArchLinux?  Assume I know enough about the command line in Linux to be dangerous...
#32 DrVenkman ONLINE
DrVenkman
  • 3,710 posts
Posted Tue Feb 28, 2017 6:01 PM
I don't know what a PogoPlug is, but if it has enough storage and can run X applications, you should be able follow the installation instructions up-thread.
Personally, I've built and run RespeQt on both an RPi3 and RPi2, and I just tonight ordered a new RPi ZeroW that I plan to try it on. If it works well enough, I'm eventually going to find a way to interface it with a touchscreen and mount the whole thing inside a dead Atari peripheral.
#33 David_P ONLINE
David_P
    Dragonstomper
  • 928 posts
Posted Tue Feb 28, 2017 6:36 PM
It's an ARM5 at 1.2ghz with 256mb RAM. Headless system with GigE and 4 USB 2.0 ports.
I'll give it a whirl and see what comes out the other end.
#34 DrVenkman ONLINE
DrVenkman
  • 3,710 posts
Posted Wed Mar 1, 2017 4:32 PM
Good luck!
#35 dkerfoot OFFLINE
dkerfoot
    Chopper Commander
  • 111 posts
Posted Wed Mar 8, 2017 9:22 AM
Seems to me that the new Pi Zero W would be a perfect match for this.  Has anyone tried running RespeQt on a zero yet?
#36 DrVenkman ONLINE
DrVenkman
  • 3,710 posts
Posted Wed Mar 8, 2017 10:29 AM
I've got one on the way to me from Canakit as I type - should be here any day now. :)
#37 dkerfoot OFFLINE
dkerfoot
    Chopper Commander
  • 111 posts
Posted Wed Mar 8, 2017 12:33 PM
Please update us once you have had a chance to experiment.  I'd like to benefit from your hard work.  :)
#38 DrVenkman ONLINE
DrVenkman
  • 3,710 posts
Posted Fri Mar 10, 2017 8:36 PM
I received my Pi Zero W this afternoon and I'm happy to report success! RespeQt is working great, serving up files to my 800XL easily at 57,600 bps. I haven't yet experimented with the software modes for higher speeds.
One caveat - the Pi Zero W with its limited RAM and single-core processor is a lot slower at compiling; it took me well over 30 minutes to compile RespeQt (as opposed to about 10 minutes on my RPi2 that I had previously been using).
#39 DrVenkman ONLINE
DrVenkman
  • 3,710 posts
Posted Sat Mar 11, 2017 6:49 PM
Okay, today I did a bit more testing. My device nominally uses DSR handshaking. With that left as-is, RespeQt on the RPi Zero W can easily handle POKEY divisor 3 speeds (~89kbps).  With handshaking set to NONE, I can safely boot and load files at POKEY divisor 0, 125kpbs. Admittedly, I didn't do much testing beyond booting Atari DOS 2.5, load a small BASIC file, and test-booting a couple of .XEX's, but it all worked great.
I can't WAIT until I can integrate a touch display and build a small standalone widget!
#40 dkerfoot OFFLINE
dkerfoot
    Chopper Commander
  • 111 posts
Posted Wed May 17, 2017 10:16 AM
I'm playing with connecting the Raspberry Pi Zero W UART through an SIO23v3 (https://oshpark.com/...ojects/cvBmkVl4) voltage shifter.
I've noticed that whenever I have the Atari off, the Pi's CPU pegs out at 100% and stays there.  When I turn the Atari on and the actual data transfer begins, CPU use drops to around 20%.  Curious if this is a software bug or if there is an explanation for why it happens?
The user manual references HIAS' AtariSIO.  It says it requires an RS232.  Wondering if it actually requires the RS232 or if it would work over RPI UART?  If yes, what advantage would it bring over using the ttyAMA0?
I originally had some real problems connecting via ttyAMA0.  In the process I learned a few things.  The RPI3 and Zero W both use ttyAMA0 for bluetooth.  Apparently they added an additional serial port (ttySO) but it is partially implemented via software and I couldn't get it to connect at all.
First, I used sudo raspi-config to disable Console from the Serial but enable Serial.  I then forced bluetooth to use ttySO via the following:
$ sudo nano /boot/config.txt and added:  dtoverlay=pi3-miniuart-bt
Save and reboot.
I realize the overlay is specific to pi3, but it worked for me on the Zero W.  It is also suggested to set core_freq=250 to enable bluetooth to actually work.  I am not sure if that setting would be the same for the Zero W and don't need actually bluetooth for the moment, so I didn't mess with it.
Here is the original article I followed:
http://spellfoundry....including-pi-3/
Edited by dkerfoot, Wed May 17, 2017 10:20 AM.
#41 TheMontezuma OFFLINE
TheMontezuma
    Dragonstomper
  • 661 posts
Posted Wed May 17, 2017 11:57 AM
Save and reboot.
Regarding your connection between RPI and ATARI.
I guess you didn't connect a command line, did you?
In case you didn't and you use "NONE" or "SOFTWARE" handshake, a high CPU load is normal (RespeQt tries to read data all the time).
Do you use r4?
https://github.com/j...releases/tag/r4
Long time ago I played with RPI 1:
http://atariage.com/...pi-as-a-floppy/
and I remember that there was only TxD and RxD signals available on the GPIO PINs at that time.
Regarding AtariSIO from HIAS - it is not possible on RPI.
AtariSIO is a device driver, which requires a UART triggering a IRQ when a single byte is in an input buffer.
HIAS explained me that the UART in Broadcom chip used in RPI can only trigger an IRQ, when at least 2 bytes are there... NO GO
My recommendation - use the USB version of a SIO2PC cable :)
#42 dkerfoot OFFLINE
dkerfoot
    Chopper Commander
  • 111 posts
Posted Thu May 18, 2017 1:00 PM
Do you use r4?
Yes, command is connected through the level shifter to GPIO 17, just like this:  http://atariage.com/...y/#entry2698490
Yes R4
Thanks for info on AtariSIO.  I appreciate you saving me time going down a dead-end!
I do have one of Sloopy's SIO2PC-USBs.  It works about the same as the UART.  The speed keeps dropping down to 19200 even when set faster and the CPU maxes out.  I'd really like to get the UART connection working better since it make such a nice compact solution with the RPI0W.
#43 TheMontezuma OFFLINE
TheMontezuma
    Dragonstomper
  • 661 posts
Posted Thu May 18, 2017 1:25 PM
Yes R4
The normal version of the RespeQt does not support sensing on Raspberry's GPIO PINs for a command line signal.
You can find a link to an old (0.8.7) modified version of AspeQt which uses a GPIO PIN 17 for handshake here:
Perhaps this will work better for you?
I used it with RPI ver.1 (single core like RPI0W) and had good performance.
The other option is to use the latest version of the RespeQt and set the Handshake setting to "NONE" (in this case the GPIO PIN 17 is not used at all).
I didn't know Sloopy's SIO2PC-USBs, but quickly searched and found out, that you need "DSR" as a handshake setting in RespeQt:
http://atariage.com/...-3#entry2390626
#44 dkerfoot OFFLINE
dkerfoot
    Chopper Commander
  • 111 posts
Posted Fri May 19, 2017 8:13 AM
Ah, I misunderstood.  I assumed that you had built the command line function into all later versions.
I won't be able to play with it again for a couple days, but I'll let you know what I find when I do.
#45 dkerfoot OFFLINE
dkerfoot
    Chopper Commander
  • 111 posts
Posted Fri Jun 16, 2017 1:31 PM
Having finally installed new OS ROMs with Hias' 1.30 patch, I've been able to test a bunch of different scenarios
After much experimentation with the Raspberry Pi Zero W, I have found I can connect via version 0.8.7 of AspeQt at a reliable 57,600.   This matches what I can do over an old built-in (DE9) SIO2PC on my 800XL connected to an old desktop PC with a serial port.
With RespeQt 4, I can reliably connect at 128,000 (divisor 0) over SIO2PC-USB.  This matches what I see from my new laptop connected over the same device.
So, while the serial ports are certainly usable, USB is better than twice as fast.  Additionally, the Pi doesn't max out the CPU while querying the USB port like it does with the serial port and you don't need to rejigger the bluetooth settings.  So, USB seems like the obvious way to go.
#46 Mr Robot OFFLINE
Mr Robot
    Dragonstomper
  • 631 posts
  • Lost in the Robot Factory
Posted Mon Sep 25, 2017 8:23 AM
No need to compile QT5 yourself. If you are running the current Raspbian release (Jessie) it's as simple as that:
sudo apt-get install build-essential git qt5-default qtbase5-dev
git clone https://github.com/jzatarski/RespeQt.git
cd RespeQt
qmake
make -j 4
./RespeQt
Takes some 10 minutes total (depending on internet speed and performance of your SD card) on a RPi2. On the old RPi use "make" instead of "make -j 4".
so long,
Hias
Just a quick FYI. With the latest Raspbian (Stretch) this has changed a little. The procedure is now this
sudo apt-get install build-essential git qt5-default qtbase5-dev libqt5serialport5 libqt5serialport5-dev
cd RespeQt
qmake
make -j 4
./RespeQt
The qt5 serial port isn't included in qt5-default or base but qmake complains if it's missing.
#47 TheMontezuma OFFLINE
TheMontezuma
    Dragonstomper
  • 661 posts
Posted Mon Sep 25, 2017 2:43 PM
It is not due to latest Rasbian, but due to latest RespeQt release (4).
QtSerialPort is used now to support a dropdown list in the settings window with all available serial ports.
#48 Mr Robot OFFLINE
Mr Robot
    Dragonstomper
  • 631 posts
Posted Mon Sep 25, 2017 2:44 PM
Good to know!
#49 mega-hz OFFLINE
mega-hz
    Star Raider
  • 97 posts
Posted Tue Feb 20, 2018 12:30 AM
cd RespeQt
qmake
make -j 4
./RespeQt
This works not on my bpi...
E: Paket qt5-default kann nicht gefunden werden.
E: Paket qtbase5-dev kann nicht gefunden werden.
E: Paket libqt5serialport5 kann nicht gefunden werden.
E: Paket libqt5serialport5-dev kann nicht gefunden werden.
does anyone know how to get respeqt running on banana pi?
#50 Kyle22 OFFLINE
Kyle22
  • 3,823 posts
  • Call my BBS! telnet://broadway1.lorexddns.net
Posted Thu Jul 12, 2018 7:19 PM
Does anyone have a good dd type image of a micro SD card for the RPi3 that has a working RespeQt on it?  I have Android OS on it now, and it's not the best...
Thanks.
Reply to this topic
