Flash ROM Cart
468 replies to this topic
#401 Lee Stewart OFFLINE
Lee Stewart
  • 3,905 posts
Posted Wed Aug 24, 2016 6:15 AM
... Let's take a 16K ROM. I guess I have to supply it as one file and not two files. And that answers my question about how the logic works in the FlashROM99, - one file equals one game equals one entry in the FlashROM99 menu !?
Well—it doesn't have to be a game; but, yes, one file (32KiB or less of non-inverted banks) equals one program equals one entry in the FlashROM99 menu.
... And entries/carts that have their own TI menu is no problem. After selecting the entry via the FlashROM99 menu, the system simply boots with that cart in place !?
Yup.
...lee
#402 sometimes99er OFFLINE
sometimes99er
  • 4,204 posts
Posted Wed Aug 24, 2016 6:25 AM
Excellent. Thanks for stepping in. Now I know all I need to know to support the hardware.
#403 ralphb OFFLINE
ralphb
    Dragonstomper
  • 626 posts
Posted Wed Aug 24, 2016 6:26 AM
That's not entirely correct, as one file equals one program may have several entries, just like Disk Manager 2 (that's not a FlashROM title, but I can't think of any right away).  If you select any of those entries you will not get the Disk Manager 2 cart menu, but the selected entry will start right away.
#404 sometimes99er OFFLINE
sometimes99er
  • 4,204 posts
Posted Wed Aug 24, 2016 6:32 AM
Oh, so if I make a cart that has two TI menu entries (GAME A and GAME B), these two will show up in the FlashROM99 menu. And if I press Fctn = (Quit), after selecting and running GAME A, what will show in the TI menu ?
Edited by sometimes99er, Wed Aug 24, 2016 6:35 AM.
#405 Lee Stewart OFFLINE
Lee Stewart
  • 3,905 posts
Posted Wed Aug 24, 2016 6:35 AM
Does that mean that my fbForth 2.0 or Willsy's TurboForth will not show its startup menu, but go, instead, only ever to the first option?
Never mind.  I re-read your docs, which makes it embarrassingly clear!:
Images may have more than one program entry to select. The FlashROM 99 lists all entries of all images.
...lee
Edited by Lee Stewart, Wed Aug 24, 2016 6:55 AM.
#406 ralphb OFFLINE
ralphb
    Dragonstomper
  • 626 posts
Posted Wed Aug 24, 2016 7:22 AM
It'll show GAME A and GAME B.  If you also push the FlashROM reset button, you'll see FLASHROM 99 again.
#407 sometimes99er OFFLINE
sometimes99er
  • 4,204 posts
Posted Wed Aug 24, 2016 7:32 AM
Excellent. Thanks for taking the time to answer what is probably already in your docs. :|
:thumbsup:
#408 chouimat OFFLINE
chouimat
    Space Invader
  • 38 posts
Posted Tue Sep 20, 2016 7:24 PM
are the assembled cart and case still available?
#409 ralphb OFFLINE
ralphb
    Dragonstomper
  • 626 posts
Posted Wed Sep 21, 2016 3:17 AM
Yes, I still offer carts and parts.  For cases, though, you'll have to contact c0d3m4st4 or modify a Romox shell (perfect fit) or standard shell (lesser fit).
Note that you can also build your own cart from scratch, as everything but the case is in the repository.
#410 MacRorie ONLINE
MacRorie
  • 1,008 posts
  • No matter where you go, there you are.
Posted Thu Sep 22, 2016 1:10 PM
If you are in the United States, I also have cases and fully assembled cartridges.
#411 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 13,640 posts
Posted Thu Sep 22, 2016 9:43 PM
One can also go to ebay.com and use thebsearch term "flashrom99" once there pick your color, click buy and you.are good to go.
#412 chouimat OFFLINE
chouimat
    Space Invader
  • 38 posts
Posted Thu Sep 22, 2016 10:06 PM
damn wrong contry ... I'm Canada ;)
#413 gfreige OFFLINE
gfreige
    Star Raider
  • 75 posts
Posted Mon Nov 28, 2016 10:18 PM
I'm currently at the schematics stage ...  Layout will be challenging because we have two busses criss-crossing all over the board.
Well, somewhat difficult. :)  One of my early designs used a 512K SRAM chip and loaded everything up front, then the menu would simply select the corresponding bank.  That wasn't very straightforward at all, and loading times are short, so I went for "load on demand" instead.
You can still increase capacity beyond 32K with the current design, but the ATmega 8515 has only one pin left for addressing the RAM.  This by itself would not be so much of a problem, though.  In fact, I have an alternative design that uses a more regular ATmega 328 instead of the bulky but wimpy 8515.  To compensate for the lack of pins I'd add two 590 8-bit counters that address the RAM sequentially -- the software is written not to use random access.  But as the size requirements for 328 + 2x 590 vs. 8515 are about the same, I went for the 8515 because that would mean less wires.  So you could use that approach to address the ATmega pin shortage.
But the bus switch also has no free pins left.  You need to switch the bank selector as well, as the 377 has no output enable.  So to answer your question: A higher capacity would require two additional chips on the board, making it even larger.  At this point I'd rather leave it as it is.
Yes, that idea is pure genius -- kudos!  That free pin mentioned above should be just right for this task ...  I'll have to try this out on the weekend.  This would also eliminate the need for the reset button, unless you like to have a hardware reset button anyway.
Any plan to make a 256K or 512K flashrom99+ with the alternate larger design? Some games can´t fit in 32K. Removing the 171 files limitation would be nice too :)
#414 ralphb OFFLINE
ralphb
    Dragonstomper
  • 626 posts
Posted Tue Nov 29, 2016 8:08 AM
I'm currently working on a GROM-capable successor cart, and yes, it will have more RAM.  :)
The prototype PCB should arrive within some days, but it'll take some more months before the cart is ready to ship.
#415 gfreige OFFLINE
gfreige
    Star Raider
  • 75 posts
Posted Tue Nov 29, 2016 8:13 AM
Good news everyone!!  :)
#416 OLD CS1 OFFLINE
OLD CS1
    Technomancer
  • 5,933 posts
  • Technology Samurai
Posted Tue Nov 29, 2016 8:40 AM
I'm currently working on a GROM-capable successor cart, and yes, it will have more RAM.  icon_smile.gif
Attached File  drooling_homer.gif~c200.gif   7.75KB   6 downloads
Attached File  kuGysZI.gif   3.17MB   6 downloads
#417 Davvel OFFLINE
Davvel
    Moonsweeper
  • 259 posts
  • Married
Posted Tue Nov 29, 2016 9:53 AM
This is great news, it opens up a new door to TI, beyond the obvious. It will be an exponential gain to all. Thanks RalphB.
#418 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 13,640 posts
Posted Tue Nov 29, 2016 10:12 AM
Yep, the sky could be the limit with this one!  My head is about to explode with all the possibilities going through it at the moment.
I wonder if this thing will finally bring us to the era of a true DOS or GUI environment for us 'average 4A users'?  All we would have to do is easily download the .BIN modules we want, slap then on the SD card and could then theoretically have all required or wanted  programs in the cartridge... and only use disks for data storage.  Wow, what a speed advantage that would give us.
The possibility of NEVER having to swap cartridges EVER again is also pretty appealing.  Being that it's GROM capable and all SD based and it turns out that the MENU PROGRAM can also be swapped in an out with a DOS or GUI this thing could have multiple personalities and applications not even considered yet.
#419 acadiel OFFLINE
acadiel
  • 1,484 posts
  • www.hexbus.com
Posted Tue Nov 29, 2016 10:13 AM
Nice! Ping me with how you're approaching it. Dying of curiosity. :)
Sent from my Nexus 5X using Tapatalk
#420 gfreige OFFLINE
gfreige
    Star Raider
  • 75 posts
Posted Tue Nov 29, 2016 2:23 PM
All we need now is a cheap/easily available SAMS card :)
#421 sometimes99er OFFLINE
sometimes99er
  • 4,204 posts
Posted Wed Nov 30, 2016 12:37 AM
... or GUI environment ...
ralphb, maybe bank-switching to some high address and you'll be able to read a mouse connected to the board ?
#422 ralphb OFFLINE
ralphb
    Dragonstomper
  • 626 posts
Posted Wed Nov 30, 2016 1:22 PM
Hehe, that might even work, but certainly not in a compatible way.  I don't even if know if there is a common standard for mice that all/most legacy programs use.
#423 sometimes99er OFFLINE
sometimes99er
  • 4,204 posts
Posted Wed Nov 30, 2016 3:11 PM
I don't think any of them went thru the cartridge port, so yeah, a new way. If you could just read 2 bytes, the current x and y positions of the mouse.
#424 sparkdrummer OFFLINE
sparkdrummer
  • 1,050 posts
  • Status? I don't need no stinkin' status!
Posted Thu Dec 1, 2016 7:31 AM
Attached File  Flash on desk.jpg   525.31KB   6 downloads
Attached File  Flash in computer.jpg   510.57KB   6 downloads
#425 Sinphaltimus ONLINE
Sinphaltimus
  • 2,518 posts
  • Distracted at the Keyboard
Posted Thu Dec 1, 2016 8:58 AM
That is sexy.
