Lynx Multi Card Preorders
2161 replies to this topic
#2151 akira666 ONLINE
akira666
    Space Invader
  • 12 posts
Posted Sat Feb 9, 2019 2:11 PM
If I look at the list on the first page and then the entries that are not yet registered there, it will probably take a while.
#2152 Rynlaw OFFLINE
Rynlaw
    Combat Commando
  • 1 posts
Posted Sat Feb 9, 2019 3:19 PM
Hi please add me to the list for an non cased version.
#2153 Aardvarq OFFLINE
Aardvarq
    Combat Commando
  • 1 posts
Posted Mon Feb 11, 2019 7:08 AM
I'd love to be on the waitlist for this, if at all possible. This thing looks amazing.
#2154 mrbearhand OFFLINE
mrbearhand
    Combat Commando
  • 1 posts
Posted Mon Feb 11, 2019 1:38 PM
Hello,
I would like to be added to the pre-order waitlist for the Lynx SD multi-card. Uncased, with unglued case (if possible). Thank you!
#2155 Xperiaplay33 OFFLINE
Xperiaplay33
    Combat Commando
  • 2 posts
Posted Thu Feb 14, 2019 10:54 PM
Thank you very much for your great work, I join the list, I also want an SD card, a hug!
#2156 orsoguey OFFLINE
orsoguey
    Combat Commando
  • 4 posts
Posted Fri Feb 15, 2019 2:15 AM
Hello, I would like to be added to the list for the Lynx SD multi-card. I don't care too much about if cased or not
#2157 necrocia OFFLINE
necrocia
    Moonsweeper
  • 290 posts
Posted Sun Feb 17, 2019 5:09 AM
A little bit of a preview of what I've been working on... https://atarigamer.c...ews/1e7yrs62y9s
New SD menu loader is coming up soon  :grin:
#2158 karri OFFLINE
karri
  • 2,557 posts
Posted Sun Feb 17, 2019 5:20 AM
Nice!
I wonder if you could try out my FlappyBird SD cart version. It should store the high score on the cart as seen below:
unsigned lynx_SDwrite(unsigned addr, unsigned val)
    if (LynxSD_OpenFile("/saves/flappy.hi") == FR_OK) {
        LynxSD_WriteFile(&val, 2);
        LynxSD_CloseFile();
This code will hang forever if the SD processor is shut down. So if the eeprom bit in the lnx header has bit 6 on it should leave the SD CPU on after programming the cart.
#2159 necrocia OFFLINE
necrocia
    Moonsweeper
  • 290 posts
Posted Sun Feb 17, 2019 5:28 AM
I've not changed any of the header handling code so far and the original code (version 1.8) looks like it doesn't check for this so I'll make changes to enable this feature. I've come across some limitations though, you can't (in you ROM) create files that don't exist and the SD cart can't resize files so if you have a 0 byte file on the SD and you try to write 2 bytes to it, it will lock up. With the code above it means that the file "saves/flappy.hi" must be on the SD card before any of this will work. Maybe it can be possible to write directly to the ROM itself since that's guaranteed to be there.
#2160 karri OFFLINE
karri
  • 2,557 posts
Posted Sun Feb 17, 2019 5:41 AM
That is a good idea. I could add a set of bytes at the end of the ROM for high scores.
#2161 King Radinov OFFLINE
King Radinov
    Combat Commando
  • 1 posts
Posted Yesterday, 1:56 AM
If you're still accepting orders I'd like to be added to the list for a cased flash cart.
#2162 Xperiaplay33 OFFLINE
Xperiaplay33
    Combat Commando
  • 2 posts
Posted Yesterday, 2:24 AM
Of course I also want to join the purchase of the flash card, if I pass the PayPal address I leave the card already paid, I do not care if it does not have the card protector, a greeting !!!
1 user(s) are browsing this forum
0 members, 1 guests, 0 anonymous users
