File Transfer ST to Portfolio
noclafirata
Ebay is probably the best bet sadly, I had to get mine there a few years back. If you use an ST the serial one is probably better, I'm not sure the standard parallel works with the ST (although this is going from memory, sadly not had time to use mine for a couple of years). The difference in parallel cables might be something to do with the ST parallel port, which is not fully bi-directional iirc.
You found this page I presume for software
http://www.atari-portfolio.co.uk/library/tx-downloads.html
  • 2 weeks later...
