Pixelboy Posted May 9, 2016 Share Posted May 9, 2016 There are about 5 known Stand-Alone Adam Memory Consoles that can play ALL the "SGM Required" games that have been released to date.... but if they output sound thru the SGM's sound chip, this sound will be missing. Are you sure about that? My experience with the sound issue has been that the SGM's sound chip cannot output via the monitor cable, but it works fine via the regular RF output. Quote Link to comment Share on other sites More sharing options...
NIAD Posted May 9, 2016 Share Posted May 9, 2016 Are you sure about that? My experience with the sound issue has been that the SGM's sound chip cannot output via the monitor cable, but it works fine via the regular RF output.The sound output from the 7-pin DIN Auxillary Port on the Stand-Alone Adam Memory Console was improperly tapped by Coleco... the same way that early Composite A/V mods were improperly tapping the sound. Due to this the Expansion Module #1, the Opcode SGM and the Juicebox Audio will all experience the same "low volume" output when using a Monitor Cable plugged into the Auxillary A/V Port. The RF A/V output will obviously not suffer from this problem. The quick fix for this issue is to turn up the volume on your TV all the way to hear the audio output, but most will experience some to a lot of line noisebfrom the TV volume being turned up so high. The proper fix is to remove how Coleco made their hack for audio output and tap off of C88... once this is done, audio is as crystal clear with proper volume output just like a Yurkie Composite A/V modded ColecoVision. Quote Link to comment Share on other sites More sharing options...
epoxy2600 Posted May 10, 2016 Share Posted May 10, 2016 Hey Retroillucid, I PM'd you on 4/28 to check on the status of my order for a Hang-On, Drol and Bombjack and haven't heard back. Paypal payment was sent at the time of the order. Could you please check on that and PM back? Thanks! Howie Quote Link to comment Share on other sites More sharing options...
coleco_master Posted May 10, 2016 Share Posted May 10, 2016 Hey Retroillucid, I PM'd you on 4/28 to check on the status of my order for a Hang-On, Drol and Bombjack and haven't heard back. Paypal payment was sent at the time of the order. Could you please check on that and PM back? Thanks! Howie Hi Howie, You should contact me for any order questions I confirm that your order as been shipped a few days ago, you should see it soon! Thank you Toby Quote Link to comment Share on other sites More sharing options...
PhilCoulson616 Posted May 31, 2016 Share Posted May 31, 2016 I'm sure it's a bit of a long shot at this point, but any copies of Bombjack or Light Grid Racing left? Quote Link to comment Share on other sites More sharing options...
retroillucid Posted May 31, 2016 Author Share Posted May 31, 2016 I'm sure it's a bit of a long shot at this point, but any copies of Bombjack or Light Grid Racing left? Contact Toby http://atariage.com/forums/user/29693-coleco-master/ 1 Quote Link to comment Share on other sites More sharing options...
arcade124 Posted July 1, 2016 Share Posted July 1, 2016 How much do any of your games cost? Quote Link to comment Share on other sites More sharing options...
coleco_master Posted July 1, 2016 Share Posted July 1, 2016 How much do any of your games cost? PM sent Quote Link to comment Share on other sites More sharing options...
