Programming the Bally Arcade/Astrocade
66 replies to this topic
#1 ballyalley OFFLINE
ballyalley
  • 1,773 posts
Posted Tue Apr 12, 2016 12:46 PM
This post would ideally fit into an Astrocade programming sub-forum, but since such a forum doesn't exist, it will live here in the main Astrocade forum on AtariAge.com.  I posted a similar thread to the Bally Alley discussion group on Yahoo just a little while ago.  While this is a re-post (of sorts), it is actually my hope that this thread catches on and can become a focus area for people interested in programming the Astrocade.  If that happens, then I'll pin this thread in the forum so that it doesn't disappear in just a few weeks.
I wrote an article called "Programming the Bally Arcade/Astrocade," mostly to completion, back in 2012.  It wasn't until the Astrocade High Score Club peaked my interest again in programming the Bally Arcade system that I decided that it was time to finish and polish the article so that others could use it.  I finished it up today and posted it to BallyAlley.com.
You can read "Programing the Bally Arcade/Astrocade," here:
http://www.ballyalle...rcade-Astrocade
The article explains how to set up the "PS Pad" text editor so that it will automatically assemble the source code of a program that runs on the Zilog Z80 CPU of the Bally Arcade/Astrocade. We'll be using the "Zmac" z80 cross-assembler, which is a command line-only program.
More specifically, you'll be guided through the process required to make "Zmac" the default editor for assembling Bally Arcade/Astrocade programs. Once these step-by-step directions are completed, "PS Pad" will be more than just a text editor; it will become a nearly complete Integrated Development Environment (IDE).
Here is what is covered in this article:
  1. Introduction
  2. Astrocade Programming Using the "Nutting Manual"
  3. Download the "Zmac" Assembler
  4. Download "PS Pad" and z80.ini
  5. Download the "Home Video-Game Library" Equates (HVGLIB.H)
  6. Set Up "PS Pad" for Use with the "Zmac" Assembler
  7. Test "PS Pad" by Assembling Z80 Source Code
  8. Summary
My friend Chris, who isn't an assembly language programmer, was this article's test subject (i.e. guinea pig).  He followed all of the steps in the article.  When he was done, he was able to assemble the cartridge "Treasure Cove" from its source code.  Hooray!  Then, because he is awesome (!), he edited the article to make sure it was easy enough for a beginner to follow.  Thanks for the help, Chris.  You rule!
I am especially interested in hearing feedback from anyone who follows these directions.  If you have any questions about programming the Bally Arcade/Astrocade console, then consider this the thread to express your thoughts and comments on the matter.
Enjoy the article!
Adam
#2 ballyalley OFFLINE
ballyalley
  • 1,773 posts
Posted Tue Apr 12, 2016 1:53 PM
I have added Software and Hardware for the Bally Arcade - A Technical Description (unofficially, but commonly, called the "Nutting Manual") to archive.org.  This is a 179MB grayscale version of the manual that has had the large red watermark removed from all of the pages.  The manual describes the Bally Home Video-Game System. The description begins with a discussion of the major sub-sections of the system. Following this, each sub-section is presented in greater detail. The particulars include sequence-calling and resource use.
The major sub-sections of the system are:
  1. The User Program Interface - Allows cartridges to reference the system routines through a standard interface. Includes an interpreter.
  2. The Screen Handler - A complex set of routines for creating
    screen images. Includes facilities for initialization, pattern and
    character display, coordinate conversion, and object vectoring.
  3. The Interrupt Processor - Decrements timers, plays music and produces sounds.
  4. The Human Interface - Reads keyboard and control handles, and inputs game selection and options.
  5. Math Routines - A package of routines for manipulating floating BCD numbers.
Also included in the "Nutting manual" are the complete source-code listings for the console's four built-in programs (Calculator, Checkmate, Gunfight and Scribbling).
The manual can be downloaded here:
https://archive.org/...ttingAssociates
I expected there to be a preview of the manual available after I uploaded it to Archive.org, but one doesn't exist yet (Jason Scott tells me it can take several hours for this to appear).  In the meantime, even if you can't preview the document, you can download the pdf from there and use it on your computer.
Adam
#3 5-11under OFFLINE
5-11under
  • 3,396 posts
Posted Tue Apr 12, 2016 3:56 PM
Now all I need is a Bally.
#4 ballyalley OFFLINE
ballyalley
  • 1,773 posts
Posted Tue Apr 12, 2016 4:50 PM
Nah, you don't need a Bally console to program for it.  Just like you don't need an a Atari 2600 to write for that system.  That's the beauty of emulation.
You can program the Bally Arcade using the Astrocade emulator included in MAME.  This actually works well.  Heck, if you use MAME, then technically you can make use of the Astrocade chipset in hi-res mode (204x320 pixels) rather than the standard low-res mode (102x160 pixels).  Of course, anything that uses hi-res mode won't work on a real Astrocade.  The arcade games "Wizard of Wor," "Gorf" and others use the Astrocade chipset.
Programming in hi-res mode would require one of the arcade emulators in MAME, rather than the Astrocade emulator.  I can't think of any examples of anyone doing this, but there is no reason it couldn't be done.  As an example, David Turner hacked his original "Gorf" to say some amusing phrases back in 2008:
For a complete list of the arcade games that use the Astrocade chipset, see this document:
http://www.ballyalle...rcade_games.txt
If anyone knows of any arcade chipset games that have been hacked, then I'd be interested in reading about them (or even trying them out, if possible).
Adam
#5 nitrofurano OFFLINE
nitrofurano
    Moonsweeper
  • 307 posts
  • meditating
Posted Fri Mar 3, 2017 11:53 AM
instead of Zmac, i’m really interested about how to use Pasmo only for that (alone, without whatever library)
if anyone know where can we find, it would be really great! (or if anyone can convert those Zmac-based .asm files into Pasmo-based, please do and share to us!)
thanks a lot in advance! :)
#6 nitrofurano OFFLINE
nitrofurano
    Moonsweeper
  • 307 posts
  • meditating
Posted Fri Mar 3, 2017 12:08 PM
i’m trying this code now, i really have no idea why this is not working....
http://pastebin.com/raw/NyXsm2uv
#7 nitrofurano OFFLINE
nitrofurano
    Moonsweeper
  • 307 posts
  • meditating
Posted Fri Mar 3, 2017 2:16 PM
finally i got one example working: http://pastebin.com/raw/kK8y2e7a
soon i’m going to have something working from Boriel’s ZX-Basic Compiler
#8 nitrofurano OFFLINE
nitrofurano
    Moonsweeper
  • 307 posts
  • meditating
Posted Sat Mar 4, 2017 5:05 AM
started something on Boriel’s ZX-Basic Compiled: http://www.boriel.co...cade#first_test
(it was far simpler that i could imagine, i guess that there are no excuses for not developing something for this really interesting game console! :D )
#9 ballyalley OFFLINE
ballyalley
  • 1,773 posts
Posted Tue Mar 7, 2017 9:40 AM
I'm not familiar with the Pasmo assembler.  I did find this link for it:
http://pasmo.speccy.org/#docu
Is this the assembler that you're using?
Adam
#10 ballyalley OFFLINE
ballyalley
  • 1,773 posts
Posted Tue Mar 7, 2017 9:49 AM
Hmm.  I'm confused by this.  I'm not overly familiar with the ZX Spectrum, although as a semi-regular reader of Retro Gamer magazine, I am familiar with it, but certainly not on an intimate level.  Did you use the ZX-BASIC compiler to somehow create a binary file for the Astrocade that executes as a cartridge?
In one of your previous posts, you wrote that you'd rather not use "Zmac [...] without whatever library]"  By this statement, I think that you mean that you don't want to use any of the on-board subroutines using the HVGLIB.H (Home Video Game Library).  If that's the case, then be aware that if you make any direct calls to the systems ROM (without going through the on-board system subroutines) then you can run into some compatibility issues between the three ROM versions that were released for the Bally Arcade/Bally Home Library Computer and the Bally Astrocade.
Adam
#11 ballyalley OFFLINE
ballyalley
  • 1,773 posts
Posted Wed Mar 8, 2017 8:58 PM
I have added Michael Matte's hand-written Z80 source code and instructions for his High-Res "Test Rotate" Routine to BallyAlley.com.  He sent this to me in the mail yesterday.  Michael just wrote this routine this year.
The "Rotate" routine rotates a 4x4 pixel pattern that resides in the Astrocade's user RAM. This routine was written for use on a modified high resolution Astrocade, but (this is the cool part), this routine can be modified for use on a normal Astrocade.
For those unaware how cool this is, the "Nutting Manual" (sort of the Astrocade's programming Bible) says that the rotate function of the Magic System does not function on a low-res Astrocade console. Specifically, page 98 of the manual says, "the rotator can only be used in commercial [hi-res] mode." However, Michael discovered that it is just a case that the on-board graphic subroutines in the Astrocade's ROM do not support the Rotate function. The Astrocade's hardware does support the rotate function, but the user has to write the routine to tell the hardware to rotate the pattern. The documentation included with this hand-written Z80 source code provides the needed changes to use the rotate function on a low-res Astrocade unit.
The routine, as written, does the following:
  1. Sets a high-res Astrocade screen map to "High-Res" mode.
  2. Clears the top 10 lines on screen.
  3. Outputs "Rotate" bit to Magic Register.
  4. Sets Magic address to display rotated pattern midway at top of screen.
  5. Writes the initial pattern a second time at the same exact Magic address.
  6. The Astrocade hardware then rotates the initial pattern 90 degrees.
  7. The Z80 halts and continues executing NOP's until the Astrocade Reset button is pressed.
I haven't tested this code, but Michael used it in both hi-res and low-res modes of his modified Astroacade.
You can download the hand-written source code here:
http://www.ballyalle...stRotateRoutine
I've already re-typed this entire rotate document and source code (including all the documentation and comments) and assembled it using Zmac with no errors.  However, I have not yet compared the output code against the hand-written listing.  I'll do this over the next few days.  After that, I'll modify the source code to try the routine on a low-res system, then it's off to test the routine under the Astrocade emulator, and (eventually) under the Machine Language Manager cartridge.  Maybe by the weekend, or possibly next week, I'll have this done.
For all those Z80 programmers out there, I'd say this is pretty awesome!
Adam
#12 nitrofurano OFFLINE
nitrofurano
    Moonsweeper
  • 307 posts
  • meditating
Posted Tue Mar 14, 2017 2:28 PM
yes, that is the Pasmo, a quite simple cross-compiler, it is multiplatform, and available by default from Debian and Ubuntu repositories (perhaps on most of the other GNU/Linux distributions as well - since i use GNU/Linux over 99% of the time, having a cross-compiler like this easily and natively available is really important and useful for me )
and yes, i were using an ansi-basic cross-compiler designed for ZX-Spectrum, and it is really great for creating z80 binaries for most of all other z80-based hardware, Bally-Astrocade included - for the “patchwork”, we just need to know the particularities of each hardware, and make the needed adaptations, like adding specific functions and routines, avoiding those related to ZX-Spectrum, etc. - for doing such “patchwork” automatically i were using bash scripts, but i think similar scripting can be done on other non-bash cli-based tools (like dos-prompt used on ReactOS and ms-Windows)
the situation about Zmac and HVGLIB.H is that they “scares” newbies like me! :D - it was difficult to find simple and pure code (without includes) which we could start almost from scratch - it was a great “luck” for me having some stuff working, but it took a few years (almost 5, i guess! :D ) for figuring out how Bally-Astrocade works (almost the same time i were trying to do something for Bandai RX78, a quite rare japanese z80-based home computer) - but see that i’m not misregretting HVGLIB.H at all, for sure it has really great information, and i have it saved as a very valid reference documentation
and thanks also for all information you’re sharing! :)
#13 Komb' OFFLINE
Komb'
    Combat Commando
  • 9 posts
Posted Tue May 23, 2017 6:11 PM
Never heard of Pasmo before.
Yep, it's there in my repository...
Moved my latest code plus HVGLIB.H to a new folder/directory and gave it a try.
OK, I Have to specify 'file.asm file.bin'. I'm used to only specifying  code file and having .bin and .lst generated automaticly.
Resulting .bin runs in MESS. :)
I'm happy.
#14 ballyalley OFFLINE
ballyalley
  • 1,773 posts
Posted Sat May 27, 2017 2:35 PM
I have added Michael Matte's Bally Arcade/Astrocade Gunfight Assembly Language Breakdown to BallyAlley.com.
http://www.ballyalle...ownMichaelMatte
I wrote an overview for the document, which I'm including here:
The breakdown includes:
1) Overview and Q&A - An introduction and overview of the Z80 machine language breakdown of Gunfight.  Also included is some background material asked of Michael Matte in a Q&A format.
2) Gunfight Breakdown (Typed) - The first two pages of the breakdown have been typed and are included to make the pdf document friendlier to Internet search engines.
3) Handwritten Gunfight Breakdown - Michael Matte's complete, 42-page breakdown of the Astrocade game Gunfight.  This breakdown will be most useful if used with the source code for the Bally's 8K system ROM, which is available in the "Nutting Manual."
4) Errata Sheet - Two pages of corrections for errors and/or omissions made in the handwritten document.
Overview
The Bally Arcade/Astrocade game system was released in January 1978 by Bally.  It was re-released in 1981 by Astrovision, Inc.  The system has an 8K ROM with four built-in programs: Gunfight, Checkmate, Calculator and ScribblingGunfight is a home port of the B&W arcade game Gunfight, released by Midway in November 1975.  The original release of the game was called Western Gun: it was released by Taito in Japan and used, as was the convention at the time, discrete logic (i.e. the system didn't use a CPU).  The North American arcade version of Gunfight moved away from the original design.  It is usually credited as the first arcade game to use a microprocessor (the Intel 8080 CPU).  The Midway arcade version of Gunfight was programmed by Tom McHugh.
The Astrocade version of Gunfight is probably the most sophisticated of the four programs built into the Astrocade.  The Software and Hardware for the Bally Arcade - A Technical Description (aka "Nutting Manual" and/or "The Handbook of Hardware & Software") has the complete Z80 assembling language source listing for the game.  Many people used this manual, which could be purchased through the Arcadian newsletter, to learn to program the Bally Arcade/Astrocade.
In the 1980s, Michael Matte, a passionate Astrocade user, used the source listing for the 8K ROM as a basis for his detailed breakdown of Gunfight.  Michael created the breakdown "to provide beginner assembly or machine language programmers an inside look at the game Gunfight.  The documentation will reveal how on-board subroutines in the System ROM can be used to execute particular tasks.  The 'special routines' listing can be used as a reference source for programming demos or games."
Michael Matte: Questions & Answers
In May of 2017, Michael Matte sent me his 42-page handwritten Gunfight breakdown so that it could be archived on BallyAlley.com.  The following are a few questions, asked via email, about the creation of the intriguing document.
Adam: When did you write the breakdown of Gunfight?  How long did it take you?
Michael: "Wrote this breakdown back in the 80's.  Don't recall what year I wrote it or how long it took.  Must have rewritten it because the breakdown is well organized.  Had no word processor or printer at that time."
Adam: Did you ever share it with anyone before now?
Michael: "I wrote it for myself for future reference.  I did not share it with anyone.  It does provide insight as to how one can use the on-board subroutines to create a demo or game.  I feel it does a better job with comments then what I have seen so far in Gunfight documentation.  I also plan this style of documentation when I breakdown The Incredible Wizard with a greater emphasis on comments and details on the many routines utilized to create all that wonderful graphics and animation.  The intent of my IW breakdown will be to open the door for those interested in developing skills in programming graphics in assembly or machine language and for future reference."
Adam: What was your experience with Z80 machine language when you began the project?
Michael: "I developed my skills prior to writing my Gunfight breakdown by attacking the on-board subroutines.  I first broke down the UPI [User Program Interface] instruction by instruction using the Nutting Manual's ROM documentation, then broke down a bunch of the on-board sub's with an emphasis on the graphics routines.  I documented that effort for future reference and learned a lot.  I also broke down some of Andy Guevara's ML work and learned a great deal.  Having Bit Fiddler's MLM [Machine Language Manager cartridge] was great because it allowed me to experiment and write ML routines and then eventually come up with high-res MLM."
Adam: What tools did you use to examine the game's code (i.e. the MLM)?
Michael: "I have 2 books covering Z80 machine and assembly language which provide detailed info on using the Z80 instructions and other goodies.  Having the MLM breakdown as part of the MLM User Manual plus my previous ML experience allowed me to figure out how MLM worked."
Adam: I presume that you based your breakdown on the ROM's Z80 source code that was included with the "Nutting Manual."  Is that correct?
Michael: "I did use the Nutting Manual's breakdown on Gunfight as a guide and then expanded that info documenting it with a non-traditional style for future reference in creating or breaking down an Astrocade game.  After looking at my Gunfight breakdown recently, I could have spent more time on it with regard to comments because there are some parts of the breakdown that are vague.  However, when I get to the advanced programming examples in my 'In-Depth Look At..' series, I will be presenting a bunch of ML examples using my Gunfight breakdown as a guide and could add some more comments (for my use) to it then."
Enjoy Michael's very detailed breakdown of Gunfight!
Adam
#15 hxlnt OFFLINE
hxlnt
    Space Invader
  • 19 posts
Posted Fri Nov 24, 2017 9:50 AM
Does anyone have any tips on getting homebrew to run in the MAME emulator? I compiled an Astrocade ROM from source, added its info to the XML file in the hash folder along with the CRC/SHA-1/ROM size info, and was able to load it MAME. However, I'm just seeing the Astrocade 1-2-3-4 menu, not the actual game.
As a test, I made a dupe of Zzzap/Dodgem and added it to the XML software list as described above, and I got the same result: the Astrocade menu (as if no cartridge were inserted). That kind of confounds me, since the entry looks pretty much identical to the working version of Zzzap/Dodgem, only with a different .bin and .zip name (which I changed in the software list to match).
I'm trying to get this up and running so I can start in on my own Astrocade homebrew ROMs. Assuming I can get the emulator working, my plan is to write a script that automatically overwrites the SHA-1 every time I recompile the .asm.
#16 ballyalley OFFLINE
ballyalley
  • 1,773 posts
Posted Sat Nov 25, 2017 7:25 PM
It's nice to see someone trying to write some homebrew for the Astrocade.  Here's how I normally start any game in MAME (including homebrew ROMS) under Windows 7:
  1. Start MAME by double-clicking icon.  I used MAMED, but regular MAME works too.
  2. As long as the three Astrocade ROMs are in the right place, then select Astrocade system of choice.
  3. Start the system "empty."  This brings-up the regular menu (no cart is inserted)
  4. Choose Tab > File Manager > Cartridge (Cart)
  5. Browse to the directory with the software that you want to run.
While I'm writing assembly code for the Astrocade, I nearly always run MAME from the command line of Windows.  Here are some examples of how I use MAME:
1) Starting Ms. Candyman from the MAME Debugger directory via the Command Line
mamed astrocde -cart mscandy -debug -nofilter
2) Start The Adventures of Robby Roto! from the MAME Debugger via the Command Line:
mamed robby -debug -nofilter
mamed robby -debug -nofilter -nounevenstretch -nosnapbilinear
3) Create a video of your gameplay:
mamed GORF -nofilter -nounevenstretch -nosnapbilinear -aviwrite GORF_001.avi
4) Record Input to file
mamed gorf -rec input_gorf.inp
5) Play Input from file
mamed gorf -pb input_gorf.inp
Remember that copy and paste in the command line is your friend.  Let me know if this is the kind of information that you're looking for right now.
Are you also planning of developing software using any real Astrocade hardware?  What sort of homebrew do you have in mind?
Adam
#17 hxlnt OFFLINE
hxlnt
    Space Invader
  • 19 posts
Posted Sat Nov 25, 2017 11:05 PM
Ahh, thank you so, so much! This loaded my helloworld.bin homebrew like a charm!
I recently acquired an Astrocade after spending hours reading through the great stories and source code on Bally Alley. I've been blown away by the tech (for its time) and am looking forward to developing for it. I think it would be fun to make a reflashable cart for personal dev testing on real hardware, but I don't have any big plans other than just learning the ins and outs of the CPU and having fun.
My background is in making cutesy, girly homebrew games for the NES, so I'll likely be making... cutesy, girly games for the Astrocade. :)
Thanks again for the help and for all you do with Bally Alley! It's awesome!
#18 ballyalley OFFLINE
ballyalley
  • 1,773 posts
Posted Sun Nov 26, 2017 10:45 AM
I'm glad that worked for you!  MAME can be a pain to get working sometimes, but it's the only emulation choice that we have for the Astrocade.  I wish MAME supported tape input, but it doesn't-- which is a shame, as there are hundreds of programs available on tape.
These was a flashable 512K bankswitch cart made for the Astrocade by AtariMax.  It worked rather well, but it never went into production.  The software for it is here:
http://www.ballyalle...sh/maxflash.htm
The Z80 is a cool CPU.  You might have fun, if you're into programming on real hardware, trying out the Machine Language Manager software (a cart that allows you to program in machine language using hex).  A more apt name for it would have been The Bally Arcade/Astrocade Z80 Machine Language Monitor.  You can read a review of the MLM here:
http://www.ballyalle... Rathmell).html
If you haven't visited the BallyAlley Yahoo group, you can usually find a few of us talking about the Astrocade over there:
https://groups.yahoo...ballyalley/info
You don't have to join the group to read message, but you have to join it to post there.
I'd be interested in seeing what you've created for the NES.  Maybe it will give me an idea of what you have in mind for the Astrocade.
I'm glad that you have enjoyed reading the BallyAlley website.  I created about nine Astrocade podcasts with a couple of co-hosts.  You can listen to those here:
http://ballyalleyast...syn.com/podcast
We haven't made any new Astrocast episodes since March of 2017.  I guess we'll eventually get back to them again, but they're on the backburner for right now.
When you get some Astrocade examples up and running (via emulation or on real hardware), then it would be cool to see a thread about what you're working on.
Adam
#19 carlsson ONLINE
carlsson
    Metagalactic Mule
  • 8,638 posts
Posted Tue Nov 28, 2017 4:02 AM
If you follow the links in her signature to "games" and "stuff", you will find some of her previous work.
#20 hxlnt OFFLINE
hxlnt
    Space Invader
  • 19 posts
Posted Thu Nov 30, 2017 3:46 AM
A few updates with tips and tricks I learned along the way...
I made a simple .bat file that compiles the source code, copies the ROM into the proper MAME folder, and opens the ROM in MAME all at once. It makes the dev/test cycle quite easy!
zmac -o mygame.bin mygame.asm
copy mygame.bin "C:\<your-path-to>\mame\roms\astrocde\"
cd "C:\<your-path-to>\mame\"
mame64.exe astrocde -cart "C:\<your-path-to>\mame\roms\astrocde\mygame.bin"
I wanted to try full-screen graphics for the Astrocade, but after hand-coding 100 bytes or so of pixels, I realized it'd be nicer to write a web app to convert a BMP for me. So, I whipped up some Javascript that accepts a locally-stored 160x102 BMP and displays the byte codes row by row like this:
; ASTROCADE GRAPHICS
; Row 1
DB $0, $0, $0, $6, $aa, $aa, $aa, $aa, $aa, $aa, $aa, $aa, $aa, $aa, $aa, $a0, $0, $0, $0, $0, $0, $0, $0, $6, $aa, $aa, $aa, $aa, $aa, $aa, $aa, $aa, $aa, $aa, $aa, $aa, $c0, $0, $0, $0
; Row 2
DB $0, $0, $0, $a, $aa, $aa, $aa, $aa, $aa, $aa, $aa, $aa, $aa, $aa, $aa, $aa, $a8, $0, $0, $0, $0, $0, $0, $a, $aa, $aa, $aa, $aa, $aa, $aa, $aa, $aa, $aa, $aa, $aa, $aa, $aa, $b0, $0, $0
; Row 3
DB $0, $0, $0, $a, $aa, $aa, $aa, $aa, $aa, $aa, $aa, $aa, $aa, $aa, $aa, $aa, $aa, $aa, $0, $0, $0, $0, $0, $a, $aa, $aa, $aa, $aa, $aa, $aa, $aa, $aa, $aa, $aa, $aa, $aa, $aa, $aa, $a0, $0
The code is on GitHub, though it's suuuuper hacky and unfinished, as I made it as quickly as possible and just to convert my specific BMP rather than the full range of different BMP color depths, byte orders, etc. Right now, it's also hardcoded to accept just four colors. However, I'll continue working on it in December and host it on my site so it can actually be useful to other people! :)
Here's the result from my BMP conversion as seen in the MAME Astrocade emulator:
OK, this is too fun...
(P.S. Adam, you can see some of my NES projects such as ConnectedNES on my website, nobadmemories.com.)
#21 ballyalley OFFLINE
ballyalley
  • 1,773 posts
Posted Thu Nov 30, 2017 7:15 PM
That batch file seems useful. I use an editor that allows me to assemble the code and then run it in MAME. I actually prefer this NOT to be a one-step process, although it's not hard to setup this way.
Back in the early 2000s, I did a fullscreen conversion for an Astrocade screen by hand. What a pain. When Michael Garber (who wrote the Astrocade homebrews "War" and "Crazy Climber") was making the graphics for his games he wrote a program that converted images to data for inclusion in his source code.  His utility, called DSImage, seems very similar to what you are working on (it also converted bitmap images).  Michael gave me the c++ source code, but I could never get the program to work, as I didn't have Microsoft Visual Studio to compile it.  I do have an executable of his program, but I think it required some dependencies to be installed.  If you're interested, then I can asked Michael if I can share the utility.  Maybe you'll find it useful.
It's cool that you're having fun. You also seem to be making rapid progress-- which is really cool!
Adam
#22 128Kgames OFFLINE
128Kgames
  • 1,039 posts
  • Victory is mine! I am the Worrior!
Posted Mon Dec 25, 2017 2:07 PM
Always glad to see another programmer for the Astrocade.
#23 ballyalley OFFLINE
ballyalley
  • 1,773 posts
Posted Fri Jan 5, 2018 5:52 PM
On November 30, 2017, I asked Michael Garber if he would share the C++ source code for his bitmap image conversion program for use with the Bally/Astrocade. I asked Michael:
"I can't remember if you said that I could publically post the source code for your Bally utility DSImage. Can I? [...] If I can share the code, then I'll post it in this thread."
He responded today with:
"Sorry I missed this earlier.. You can post it - not very good code and you said you were having an issue compiling it.. but in any case I don't mind."
Here is the Visual C++ source code and some other misc. files for DS Image:
Attached File  dsimagesrc (2011)(Michael Garber).zip   2.9MB   74 downloads
If anyone can get this to compile and finds it useful, then please post about it here.
Michael made a simple program called "256K GFX Demo" that used images converted with DS Image to create a simple pokemon animation that was originally an animated GIF. This graphics demo, which requires the, unreleased (except for test purporses) 256K Maxflash Astrocade cartridge can be downloaded here:
Here is the Pokemon demo:
This demo features Riff Raff:
Hopefully you find this graphics utility useful. Enjoy!
Adam
#24 ballyalley OFFLINE
ballyalley
  • 1,773 posts
Posted Sat Jan 6, 2018 4:09 PM
Michael Garber sent me a few emails that he asked me to post in this thread.  I've concatenated them together:
"I'm on mobile and it's not convenient for me to add to your post on AA but wanted to clarify I didn't make that tool until after CC [Crazy Climber].  CC gfx we're done on graph paper and hand converted. [...] [DS Image] was created at the time of developing on the bank switched cart.  The nibbler stuff [a third homebrew game that Michael was working on in 2011, after he finished Crazy Climber] was hand converted also. [...] Also.. the reason I lost interest in finishing nibbler was the bank switched cart would have let me make a more authentic port.. and trying to squeeze it into 8k (would have been doable) didn't seem as interesting anymore."
Hopefully that clears up misconceptions that I've put out there about DS Image.
Adam
#25 nitrofurano OFFLINE
nitrofurano
    Moonsweeper
  • 307 posts
  • meditating
Posted Wed Jan 17, 2018 3:35 PM
i really need to update my astrocade stuff, at least coding a snake game...
