Little Ninja Hattori-kun Prototype Famicom Cartridge
5 replies to this topic
#1 fkgiggles OFFLINE
fkgiggles
    Combat Commando
  • 1 posts
Posted Wed Apr 27, 2016 11:46 PM
So I've recently acquired this prototype cart for a Famicom game called Little Ninja  Hattori-kun. To my knowledge, there wasn't any standardization for test cartridges for the Famicom, so companies would typically fabricate  whatever hardware they needed at the time. My question here is twofold: does anyone have any idea what the switch on the board actually does? Information on games with these switches seems very scarce, but I did come across a thread here that said that they might be used to delete data of the cartridge, but if that's the case, then why leave the eproms exposed? Also to my knowledge the game is identical to the full release, however on the off-chance it isn't, I'd still like to dump it, so if anyone could perhaps point me in the right direction for that, I would super appreciate it.
#2 Supergun OFFLINE
Supergun
  • 1,091 posts
Posted Fri Apr 29, 2016 8:36 AM
The switch is most likely for the H & V selecting.
#3 Supergun OFFLINE
Supergun
  • 1,091 posts
Posted Fri Apr 29, 2016 8:40 AM
It's appears to be a very recycled cart. Perhaps they put a game on it, test it, play it, use it, etc. then they place it in a UV light fixture box, it erases the EPROMs data, then they have a special edge connector reader device that can reprogram the EPROMs with the next revision or next game without having to open the cart and unplug the EPROMs, etc.
Hence the Windows make that easy and possible, and the switch is to toggle if needed depending on the type of game programmed at the moment in the cart.
Edited by Supergun, Fri Apr 29, 2016 8:41 AM.
#4 Ksarul OFFLINE
Ksarul
  • 5,138 posts
Posted Fri Apr 29, 2016 3:26 PM
Or, following your logic a little bit further, Supergun, it may be that the switch allows the programmer to select between the EPROMs during the reprogramming run. That way, the burner only sees one chip of a type it knows at the end of the programmer adapter. . .instead of two very different chips simultaneously. Note that one chip is a 2764 and the other is a 27256, so they would need to be programmed separately.
#5 Shawn OFFLINE
Shawn
    As Above
  • 18,748 posts
  • So Below
Posted Fri Apr 29, 2016 8:22 PM
The switch could be to select the high address line on the chip.
#6 TheRedEye OFFLINE
TheRedEye
    Moonsweeper
  • 351 posts
Posted Fri May 20, 2016 3:54 PM
This likely isn't an actual prototype, this is a contemporary flash cart people would use to pirate games. You see them listed on ebay all the time as "prototype?".
http://www.ebay.com/...tUAAOSwu1VW8F-s
http://www.ebay.com/...UUAAOSwZG9WlEhq
http://www.ebay.com/...TkAAOSwKtlWlEvU
Edited by TheRedEye, Fri May 20, 2016 3:56 PM.
