tschak909 Posted May 18, 2016 Share Posted May 18, 2016 Just curious, mostly because I never really see it mentioned here in the 10 years that I've been on this board: Do you guys store your code in a version controlled repository, e.g. GitHub? and if not, why not? I've been developing software in one form or another for roughly 30 years, and all through that process, a version control system was always in play (I started with RCS, then CVS, then SVN, and when git came along, I never looked back!), mostly because it provided a convenient way for me to track my source code changes as I worked through a project, and a convenient place to store stuff in case something terrible would happen. I do this even with my comparatively small 6502 projects, even, because at the end of the day, I want my stuff to last. How about you guys? -Thom 1 Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted May 18, 2016 Share Posted May 18, 2016 Thomas and I used an online repository for Boulder Dash development. Quote Link to comment Share on other sites More sharing options...
gauauu Posted May 18, 2016 Share Posted May 18, 2016 Absolutely. Anything that I work on for more than a few hours goes into a repository. Right now that's Atlassian's Bitbucket (they have free private git repos). I've got a repository per project, and a general "misc" repository where I keep small little bits of code that I've messed around with that hasn't earned a real repo yet. Quote Link to comment Share on other sites More sharing options...
ZackAttack Posted May 18, 2016 Share Posted May 18, 2016 I just use a single repository in bitbucket for all my atari projects. Each one gets its own folder. Though I'd probably create a new repository if I got serious about a specific project. Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted May 18, 2016 Share Posted May 18, 2016 My repository is AtariAge. Source for all the revisions of my projects, with the exception of Stay Frosty 1 & 2, can be found in my blog. I've started posting SF2 source, though am behind on that. 1 Quote Link to comment Share on other sites More sharing options...
Joe Musashi Posted May 18, 2016 Share Posted May 18, 2016 http://atariage.com/forums/topic/190695-your-development-environment/?do=findComment&comment=2413535 For me, the main advantage of using a version control system is that I can easily diff between revisions. Before checking in a new feature, I always diff all the files I changed, which often reveals that I forgot something (e.g., removing debugging code). 1 Quote Link to comment Share on other sites More sharing options...
+splendidnut Posted May 18, 2016 Share Posted May 18, 2016 For Atari 2600 projects, I personally like to keep all my code in a single file and save a backup copy (with date in filename) every time I do any substantial work. I don't really see a need for a robust version control system... unless you're doing team work like BoulderDash. Similar to Spiceware... my blog entries also work as a repository. 1 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted May 18, 2016 Author Share Posted May 18, 2016 I am storing stuff for my current project, here: http://github.com/tschak909/dodgeball Quote Link to comment Share on other sites More sharing options...
DanOliver Posted May 20, 2016 Share Posted May 20, 2016 I use source control when working with other programmers or when a client requires some system. For projects where I'm the only programmer I don't use a source control system since it just adds a level of complexity and no benefits I need. I do duplicate the project about once a day using a script that creates an archive folder with the date and time so folders in the archive are sorted. About once a week I upload an archive folder to the cloud. I don't compress source in any way so I can do text search my archive. Disk space is now soooo cheap (free) and network is plenty fast and reliable. Quote Link to comment Share on other sites More sharing options...
Mr SQL Posted May 20, 2016 Share Posted May 20, 2016 I agree and I write version control systems - difference engines are fun and very useful to see other developers changes, but for my own it's much easier to view my development log; a difference engine is an inferior tool to a log except when the log is missing or errant. And large groups are a different story but pair programming team are rarely load balanced; the actual redundancy gained from this model is that the pair programmers become good friends so when the lead programmer leaves the friend can call them up at their new organization for help. Quote Link to comment Share on other sites More sharing options...
DanOliver Posted May 20, 2016 Share Posted May 20, 2016 I'd never thought of this before but I guess I could always check in as much of my archive as I wanted into a source control system should that ever be needed. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted May 20, 2016 Share Posted May 20, 2016 Since Boulder Dash I am using SVN for all my games. Star Castle Arcade Three.s Even if you are on you own, it makes it easier to develop on multiple computers and serves as a backup. Quote Link to comment Share on other sites More sharing options...
gauauu Posted May 21, 2016 Share Posted May 21, 2016 Even if you are on you own, it makes it easier to develop on multiple computers and serves as a backup. It also makes it easier to do diffs and figure out where you introduced bugs. (Git in particular has a great command, bisect, which helps you do a binary search through revisions to find what change broke your code) Quote Link to comment Share on other sites More sharing options...
tschak909 Posted May 21, 2016 Author Share Posted May 21, 2016 git bisect is worth its weight in gold, not to mention just the action of pulling out a branch to work on an idea, merge it back in when ready, keeps things really stable, and you can track things cleanly, using bisect only when you're not entirely sure when something snuck in... (git's bisect and branching tools were the reason I ditched every other VCS system that I had been using: RCS, CVS, SVN, Mercurial, Perforce, etc...etc..) -Thom Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted May 21, 2016 Share Posted May 21, 2016 I just read a bit about bisect. Is it really only a comfort feature which saves you calculating the revision number which halves the interval? Quote Link to comment Share on other sites More sharing options...
gauauu Posted May 22, 2016 Share Posted May 22, 2016 (edited) I just read a bit about bisect. Is it really only a comfort feature which saves you calculating the revision number which halves the interval? Yup. Comparing it with SVN, which uses normal human revision numbers, it sounds crazy. But git uses nasty hashes for revision ids, so it helps quite a bit. (And the convenience of it is pretty nice. It's definitely only a comfort feature, but they did a good job making it really easy, you basically just type "git bisect good" or "git bisect bad", and it immediately goes and gets a different version checked out for you to try. Takes the thinking out of checking out different versions, letting you save your thinking for fixing the problem.) Honestly, for a single developer project, I don't think git is really all that superior to svn. The branching model is a little faster and easier, and local branches are nice, but I have no beef with svn, despite all the cool kids hating it these days. Edited May 22, 2016 by gauauu 1 Quote Link to comment Share on other sites More sharing options...
Tjoppen Posted June 6, 2016 Share Posted June 6, 2016 (edited) I use git locally for pretty much all my projects. When I need to collaborate with other people I tend to use bitbucket, self-hosted gitlab or (rarely) github. SVN isn't an option since it requires a network connection. And yes, bisect is immensely useful. Plus git has a working merge, unlike SVN I hear hg is better than git UX-wise, so newcomers to DVCS might want to give that a spin Edited June 6, 2016 by Tjoppen Quote Link to comment Share on other sites More sharing options...
