Simple kernel for playfield
8 replies to this topic
#1 tschak909 OFFLINE
tschak909
  • 1,984 posts
Posted Thu May 26, 2016 11:03 PM
Hello everybody, thought i'd paste this, a simple kernel for outputting playfield. The playfield data is vertically reflected, as well as horizontally reflected (like the combat playfield), and is nominally 8 scanlines deep.
(yeah, I know it's not optimal, at all. I'm learning...)
        PROCESSOR 6502
        include vcs.h
        include macro.h
        SEG.U VARS
        ORG $80
ScanLine:       ds 1            ; scanline counter.
        SEG CODE
        ORG $F800
ColdStart:
        CLEAN_START
MainLoop:
        jsr VerticalSync
        jsr VerticalBlank
        jsr Kernel
        jsr OverScan
        jmp MainLoop
VerticalSync:
        lda #$02                ; Get ready to start VSYNC
        ldx #49
        sta WSYNC               ; Next line
        sta VSYNC               ; Start VSYNC
        stx TIM64T
        sta CTRLPF
        sta WSYNC
        sta WSYNC
        lda #$00
        sta PF0
        sta PF1
        sta PF2
        sta WSYNC
        sta VSYNC
Sleep12:
        rts
VerticalBlank:
        ldx #3
        ldy #3
        lda SWCHB
        and #$08
        bne SOCloop
        ldy #7
SOCloop:
        lda Colors,Y
        sta COLUP0,x
        dey
        dex
        bpl SOCloop
        rts
Kernel:
        LDA #$01
        STA CTRLPF
        sta WSYNC
        lda INTIM
        bne Kernel
        sta VBLANK
        sta WSYNC
        ldx #$00
kl0:    ldy #$08
kl1:    lda PF0_0,x
        sta PF0
        lda PF1_0,x
        sta PF1
        lda PF2_0,x
        sta PF2
        sta WSYNC
        dey
        bne kl1
        inx
        cpx #$0B
        bne kl0
kl2:    ldy #$08
kl3:    lda PF0_0,X
        sta PF0
        lda PF1_0,x
        sta PF1
        lda PF2_0,x
        sta PF2
        sta WSYNC
        dey
        bne kl3
        dex
        bpl kl2
        sta PF0
        sta PF1
        sta PF2
        rts
OverScan:
        sta WSYNC
        lda #2
        sta VBLANK
        lda #32
        sta TIM64T
OSWait: sta WSYNC
        lda INTIM
        bne OSWait
        rts
Colors:
        .byte $86
        .byte $C6
        .byte $46
        .byte $00
        .byte $0E
        .byte $06
        .byte $0A
        .byte $00
        align 256
PF0_0  .byte $F0 ; |XXXX    |
       .byte $10 ; |   X    |
       .byte $10 ; |   X    |
       .byte $10 ; |   X    |
       .byte $10 ; |   X    |
       .byte $10 ; |   X    |
       .byte $10 ; |   X    |
       .byte $10 ; |   X    |
       .byte $10 ; |   X    |
       .byte $10 ; |   X    |
       .byte $10 ; |   X    |
       .byte $10 ; |   X    |
PF1_0  .byte $FF ; |XXXXXXXX|
       .byte $00 ; |        |
       .byte $00 ; |        |
       .byte $00 ; |        |
       .byte $38 ; |  XXX   |
       .byte $00 ; |        |
       .byte $00 ; |        |
       .byte $00 ; |        |
       .byte $60 ; | XX     |
       .byte $20 ; |  X     |
       .byte $20 ; |  X     |
       .byte $23 ; |  X   XX|
PF2_0  .byte $FF ; |XXXXXXXX|
       .byte $80 ; |X       |
       .byte $80 ; |X       |
       .byte $00 ; |        |
       .byte $00 ; |        |
       .byte $00 ; |        |
       .byte $1C ; |   XXX  |
       .byte $04 ; |     X  |
       .byte $00 ; |        |
       .byte $00 ; |        |
       .byte $00 ; |        |
       .byte $00 ; |        |
;;; ;; Function to check for free space at end of cart.
 if (* & $FF)
        echo "!!!!! ", [$FFFA - *]d, "Bytes free before end of cartridge."
        align 256
 endif
        ORG $FFFA
        .WORD ColdStart
        .WORD ColdStart
        .WORD ColdStart
#2 Nukey Shay OFFLINE
Nukey Shay
    Sheik Yerbouti
  • 21,707 posts
Posted Fri May 27, 2016 2:15 AM
Note: for a non-asymmetrical playfield, you don't need to rewrite PF registers scanline-to-scanline unless the data is changing. This would draw the same thing and save 21 cycles on each successive scanline as Y counts down...
Kernel:
        LDA #$01
        STA CTRLPF
        sta WSYNC
        lda INTIM
        bne Kernel
        sta VBLANK
        sta WSYNC
        ldx #$00
kl0:    ldy #$08
        lda PF0_0,x
        sta PF0
        lda PF1_0,x
        sta PF1
        lda PF2_0,x
        sta PF2
k11:    sta WSYNC
        dey
        bne kl1
        inx
        cpx #$0B
        bne kl0
kl2:    ldy #$08
        lda PF0_0,X
        sta PF0
        lda PF1_0,x
        sta PF1
        lda PF2_0,x
        sta PF2
K13:    sta WSYNC
        dey
        bne kl3
        dex
        bpl kl2
        sta PF0
        sta PF1
        sta PF2
        rts
Are the last 3 PF writes intended to clear the registers with zero? If so, you might want to store Y instead of A to each. Y is zero at the end of the subroutine, A is $FF.
#3 SpiceWare OFFLINE
SpiceWare
    Draconian
  • 11,789 posts
  • Medieval Mayhem
Posted Fri May 27, 2016 8:35 AM
Minor mistake with your free space check - you've merged the free space before page-aligned table
 if (* & $FF)
    echo "------", [(>.+1)*256 - .]d, "bytes free before DigitGfx"
    align 256
  endif
with free space at end of cartridge
; free space check before End of Cartridge
    echo "------", [$FFFA - *]d, "bytes free before End of Cartridge"
#4 tschak909 OFFLINE
tschak909
  • 1,984 posts
Posted Fri May 27, 2016 11:05 AM
Thanks, I was looking for replies, like this. :)
I haven't gotten down to the bare metal in my day job in over two decades, so it's nice to be able to do this. :)
I'm looking at the Combat source code, and I see tricks that were definitely done by people who had spent a LOT of time with the 6502...the stack trick is very clever...
-Thom
#5 tschak909 OFFLINE
tschak909
  • 1,984 posts
Posted Sat May 28, 2016 6:21 PM
I tried another approach, inspired by the Combat kernel, and with the following code:
;;; ;; Scratchpad to test ideas.
        PROCESSOR 6502
        include vcs.h
        include macro.h
        SEG.U VARS
        ORG $80
BallY0:         ds 1            ; ball y0
        SEG CODE
        ORG $F800
ColdStart:
        CLEAN_START
MainLoop:
        jsr VerticalSync
        jsr VerticalBlank
        jsr Kernel
        jsr OverScan
        jmp MainLoop
VerticalSync:
        ldx #49
        stx TIM64T
        sta CTRLPF
        sta WSYNC
        sta WSYNC
        lda #$00
        sta PF0
        sta PF1
        sta PF2
        sta WSYNC
        sta VSYNC
Sleep12:
        rts
VerticalBlank:
        ldx #3
        ldy #3
        lda SWCHB
        and #$08
        bne SOCloop
        ldy #7
SOCloop:
        lda Colors,Y
        sta COLUP0,x
        dey
        dex
        bpl SOCloop
        lda SWCHB               ; read switches
        lsr                     ; shift bit 0 into carry
        bcs norst               ; and ignore if not pressed.
        sta RESP0
        SLEEP 6
        sta RESBL
        SLEEP 18
        sta RESP1
        lda #$20
        sta BallY0
norst:
        rts
Kernel:
        LDA #$01
        STA CTRLPF
        sta WSYNC
        lda INTIM
        bne Kernel
        sta VBLANK
        lda #38
        sta ScanLine
        sta WSYNC
vmain:  lda ScanLine
        bpl refl
        eor #$F8
refl:   cmp #$20
        bcc kend
        lsr
        lsr
        lsr
        tax
kl0:    lda PF0_0,x
        sta PF0
        lda PF1_0,x
        sta PF1
        lda PF2_0,x
        sta PF2
        sta WSYNC
        inc ScanLine
        cmp #$EC
        bne vmain
kend:   rts
OverScan:
        sta WSYNC
        lda #2
        sta VBLANK
        lda #32
        sta TIM64T
OSWait: sta WSYNC
        lda INTIM
        bne OSWait
        rts
Colors:
        .byte $86
        .byte $C6
        .byte $46
        .byte $00
        .byte $0E
        .byte $06
        .byte $0A
        .byte $00
        align 256
PF0_0
        .byte $00
        .byte $00
        .byte $00
        .byte $00
        .byte $00
        .byte $F0 ; |XXXX    | $F779
       .byte $10 ; |   X    | $F77A
       .byte $10 ; |   X    | $F77B
       .byte $10 ; |   X    | $F77C
       .byte $10 ; |   X    | $F77D
       .byte $10 ; |   X    | $F77E
       .byte $10 ; |   X    | $F77F
       .byte $10 ; |   X    | $F780
       .byte $10 ; |   X    | $F781
       .byte $10 ; |   X    | $F782
       .byte $10 ; |   X    | $F783
       .byte $10 ; |   X    | $F784
PF1_0
        .byte $00
        .byte $00
        .byte $00
        .byte $00
        .byte $00
        .byte $FF ; |XXXXXXXX| $F785
       .byte $00 ; |        | $F786
       .byte $00 ; |        | $F787
       .byte $00 ; |        | $F788
       .byte $38 ; |  XXX   | $F789
       .byte $00 ; |        | $F78A
       .byte $00 ; |        | $F78B
       .byte $00 ; |        | $F78C
       .byte $60 ; | XX     | $F78D
       .byte $20 ; |  X     | $F78E
       .byte $20 ; |  X     | $F78F
       .byte $23 ; |  X   XX| $F790
PF2_0
        .byte $00
        .byte $00
        .byte $00
        .byte $00
        .byte $00
        .byte $FF ; |XXXXXXXX| $F791
       .byte $80 ; |X       | $F792
       .byte $80 ; |X       | $F793
       .byte $00 ; |        | $F794
       .byte $00 ; |        | $F795
       .byte $00 ; |        | $F796
       .byte $1C ; |   XXX  | $F797
       .byte $04 ; |     X  | $F798
       .byte $00 ; |        | $F799
       .byte $00 ; |        | $F79A
       .byte $00 ; |        | $F79B
       .byte $00 ; |        | $F79C
        ORG $FFFA
        .WORD ColdStart
        .WORD ColdStart
        .WORD ColdStart
I got the following output:
slight tearing on the extremes, and, i noticed that in the original Combat kernel, the pointers to the playfield data are offset negatively by 4, I had to do something similar here, is that to correct the offset bias so that the divide by 8 would work correctly?
-Thom
#6 tschak909 OFFLINE
tschak909
  • 1,984 posts
Posted Sun May 29, 2016 2:27 PM
A bit more fenagling, and I can get a display, although i'm spilling over, need to see why...
Why am I getting ripples? ... investigating...
        PROCESSOR 6502
        include vcs.h
        include macro.h
        SEG.U VARS
        ORG $80
Score:          ds 1            ; Score
Timer:          ds 1            ; Timer
DigitOnes:      ds 2            ; Player 0 and 1 digit graphics
DigitTens:      ds 2            ; Player 0 and 1 digit graphics
ScoreGfx:       ds 1            ; pointers
TimerGfx:       ds 1            ; pointers
Temp:           ds 1            ; Temp
        SEG CODE
        ORG $F800
ColdStart:
        CLEAN_START
MainLoop:
        jsr VerticalSync
        jsr VerticalBlank
        jsr Kernel
        jsr OverScan
        jmp MainLoop
VerticalSync:
        ldx #45
        stx TIM64T
        sta CTRLPF
        sta WSYNC
        sta WSYNC
        lda #$00
        sta PF0
        sta PF1
        sta PF2
        sta WSYNC
        sta VSYNC
Sleep12:
        rts
VerticalBlank:
        jsr SetColors
        jsr PrepScoreForDisplay
        rts
Kernel:
        lda INTIM
        bne Kernel
        sta VBLANK
        lda #$20
        sta ScanLine
        LDA #$02
        STA CTRLPF
        sta WSYNC
        ldx #5
ScoreLoop:
        ldy DigitTens
        lda DigitGfx,y
        and #$f0
        sta ScoreGfx
        ldy DigitOnes
        lda DigitGfx,y
        and #$0F
        ora ScoreGfx
        sta ScoreGfx
        sta WSYNC
        sta PF1
        ldy DigitTens+1
        lda DigitGfx,y
        and #$F0
        sta TimerGfx
        ldy DigitOnes+1
        lda DigitGfx,y
        and #$0F
        ora TimerGfx
        sta TimerGfx
        jsr Sleep12
        sta PF1
        ldy ScoreGfx
        sta WSYNC
        sty PF1
        inc DigitTens
        inc DigitTens+1
        inc DigitOnes
        inc DigitOnes+1
        jsr Sleep12
        dex
        sta PF1
        bne ScoreLoop
        sta WSYNC
        stx PF1
        sta WSYNC
        sta WSYNC
        lda #$01
        sta CTRLPF
vmain:
        sta WSYNC
        lda ScanLine
        bpl refl
        eor #$F8
refl:   cmp #$20
        bcc kend
        lsr
        lsr
        lsr
        tax
kl0:    lda PF0_0,x
        sta PF0
        lda PF1_0,x
        sta PF1
        lda PF2_0,x
        sta PF2
        inc ScanLine
        lda ScanLine
        cmp #$EC
        bne vmain
kend:   rts
OverScan:
        sta WSYNC
        lda #2
        sta VBLANK
        lda #22
        sta TIM64T
OSWait: sta WSYNC
        lda INTIM
        bne OSWait
        rts
SetColors:
        ldx #3
        ldy #3
        lda SWCHB
        and #$08
        bne SOCloop
        ldy #7
SOCloop:
        lda Colors,Y
        sta COLUP0,x
        dey
        dex
        bpl SOCloop
        rts
PrepScoreForDisplay:
        inc Timer
        bne PSFDskip
        inc Score
PSFDskip:
        ldx #1
PSFDloop:
        lda Score,X
        and #$0F
        sta Temp
        asl
        asl
        adc Temp
        sta DigitOnes,x
        lda Score,x
        and #$F0
        lsr
        lsr
        sta Temp
        lsr
        lsr
        adc Temp
        sta DigitTens,x
        dex
        bpl PSFDloop
        rts
Colors:
        .byte $86
        .byte $C6
        .byte $46
        .byte $00
        .byte $0E
        .byte $06
        .byte $0A
        .byte $00
        align 256
PF0_0
        .byte $00
        .byte $00
        .byte $00
        .byte $00
PF1_0
        .byte $00
        .byte $00
        .byte $00
        .byte $00
PF2_0
        .byte $00
        .byte $00
        .byte $00
        .byte $00
DigitGfx:
        .byte %01110111
        .byte %01010101
        .byte %01010101
        .byte %01010101
        .byte %01110111
        .byte %00010001
        .byte %00010001
        .byte %00010001
        .byte %00010001
        .byte %00010001
        .byte %01110111
        .byte %00010001
        .byte %01110111
        .byte %01000100
        .byte %01110111
        .byte %01110111
        .byte %00010001
        .byte %00110011
        .byte %00010001
        .byte %01110111
        .byte %01010101
        .byte %01010101
        .byte %01110111
        .byte %00010001
        .byte %00010001
        .byte %01110111
        .byte %01000100
        .byte %01110111
        .byte %00010001
        .byte %01110111
        .byte %01110111
        .byte %01000100
        .byte %01110111
        .byte %01010101
        .byte %01110111
        .byte %01110111
        .byte %00010001
        .byte %00010001
        .byte %00010001
        .byte %00010001
        .byte %01110111
        .byte %01010101
        .byte %01110111
        .byte %01010101
        .byte %01110111
        .byte %01110111
        .byte %01010101
        .byte %01110111
        .byte %00010001
        .byte %01110111
        .byte %00100010
        .byte %01010101
        .byte %01110111
        .byte %01010101
        .byte %01010101
        .byte %01100110
        .byte %01010101
        .byte %01100110
        .byte %01010101
        .byte %01100110
        .byte %00110011
        .byte %01000100
        .byte %01000100
        .byte %01000100
        .byte %00110011
        .byte %01100110
        .byte %01010101
        .byte %01010101
        .byte %01010101
        .byte %01100110
        .byte %01110111
        .byte %01000100
        .byte %01100110
        .byte %01000100
        .byte %01110111
        .byte %01110111
        .byte %01000100
        .byte %01100110
        .byte %01000100
        .byte %01000100
        ORG $FFFA
        .WORD ColdStart
        .WORD ColdStart
        .WORD ColdStart
#7 tschak909 OFFLINE
tschak909
  • 1,984 posts
Posted Sun May 29, 2016 2:54 PM
scooting the STA WSYNC from the beginning of Vmain to the lda/sta of pf0, fixed the ripple... stella debugger proving insanely useful here.
-Thom
#8 SpiceWare OFFLINE
SpiceWare
    Draconian
  • 11,789 posts
  • Medieval Mayhem
Posted Sun May 29, 2016 4:45 PM
When you update the various TIA registers can be time critical, so you should get in the habit of adding cycle counts to your kernel.  An example from Collect:
ScoreLoop:              ;   43 - cycle after bpl ScoreLoop
        ldy DigitTens   ; 3 46 - get the tens digit offset for the Score
        lda DigitGfx,y  ; 5 51 -   use it to load the digit graphics
        and #$F0        ; 2 53 -   remove the graphics for the ones digit
        sta ScoreGfx    ; 3 56 -   and save it
        ldy DigitOnes   ; 3 59 - get the ones digit offset for the Score
        lda DigitGfx,y  ; 5 64 -   use it to load the digit graphics
        and #$0F        ; 2 66 -   remove the graphics for the tens digit
        ora ScoreGfx    ; 3 69 -   merge with the tens digit graphics
        sta ScoreGfx    ; 3 72 -   and save it
        sta WSYNC       ; 3 75 - wait for end of scanline
        sta PF1         ; 3  3 - @66-28, update playfield for Score dislay
        ldy DigitTens+1 ; 3  6 - get the left digit offset for the Score+1
        lda DigitGfx,y  ; 5 11 -   use it to load the digit graphics
        and #$F0        ; 2 13 -   remove the graphics for the ones digit
        sta ScoreGfx+1  ; 3 16 -   and save it
        ldy DigitOnes+1 ; 3 19 - get the ones digit offset for the Score+1
        lda DigitGfx,y  ; 5 24 -   use it to load the digit graphics
        and #$0F        ; 2 26 -   remove the graphics for the tens digit
        ora ScoreGfx+1  ; 3 29 -   merge with the tens digit graphics
        sta ScoreGfx+1  ; 3 32 -   and save it
        jsr Sleep12     ;12 44 - waste some cycles
        sta PF1         ; 3 47 - @39-54, update playfield for Score+1 display
        ldy ScoreGfx    ; 3 50 - preload for next scanline
        sta WSYNC       ; 3 53 - wait for end of scanline
        sty PF1         ; 3  3 - update playfield for the Score display
        inc DigitTens   ; 5  8 - advance for the next line of graphic data
        inc DigitTens+1 ; 5 13 - advance for the next line of graphic data
        inc DigitOnes   ; 5 18 - advance for the next line of graphic data
        inc DigitOnes+1 ; 5 23 - advance for the next line of graphic data
        jsr Sleep12     ;12 35 - waste some cycles
        dex             ; 2 37 - decrease the loop counter
        sta PF1         ; 3 40 - @39-54, update playfield for the Score+1 display
        bne ScoreLoop   ; 2 42 - (3 43) if dex != 0 then branch to ScoreLoop
        sta WSYNC       ; 3 45 - wait for end of scanline
The first number after each ; is the number of cycles that instruction will take. The second number is cumulative cycles for that line AFTER the instruction finishes. Some lines have an @xx-yy to denote the acceptable cycles for updating a time-critical TIA register. Additionally, branches show the timing for when the branch is not taken, followed by parentheses containing the timing if the branch is taken.
Collect Step 3 covers the time critical updates for the PFx registers, and includes a handy diagram that Andrew Davie posted.
#9 tschak909 OFFLINE
tschak909
  • 1,984 posts
Posted Sun May 29, 2016 4:59 PM
Yup, I know, I need to get into the habit. I'm thinking through an extension to the emacs assembler mode, that would take a selection and add cycle counts... hmm.... :)
on another note, am working on some ball code. Trying to replicate the billiard mode combat physics...
-Thom
