Retro HQ SD Cart Menu 1.4
107 replies to this topic
#51 GadgetUK OFFLINE
GadgetUK
  • 1,946 posts
Posted Fri Jul 29, 2016 5:11 PM
Don't worry - it's not a major problem, I am sure we can fix it.  It's just the menu trying to load preview file, so even if it doesn't exist it still seeks and tries to see if its there.  I will put a fix in over the weekend if I get time.
#52 Trew OFFLINE
Trew
    Chopper Commander
  • 246 posts
Posted Sat Jul 30, 2016 2:34 AM
Yep, like I say, it's a minor thing, but noticeable.
When can we get full Netflix style menu implemented ;)
#53 Level42 OFFLINE
Level42
  • 2,602 posts
Posted Sat Jul 30, 2016 3:51 AM
Yes, with full motion video previews, like a lot of front-ends for MAME and other emulators.......please ;);););)
Just kidding.....that box art idea.....I like, but bigger and flipping through them would be nice ;);)
The manuals could be included too LOL ;);) (I remember I printed a load of text-only files which were kind of manual/how to plays....with codes and stuff....:D
I think I messed something up with my SD card, I too created folders with the letters of the alphabet but now the card only gives the Insert Game message.....I'm on Mac too....
Edited by Level42, Sat Jul 30, 2016 3:53 AM.
#54 Level42 OFFLINE
Level42
  • 2,602 posts
Posted Sat Jul 30, 2016 4:04 AM
Never mind......I swapped in the wrong micro-SD card which was empty......LOL.....works fine now :D But I too noticed the lagging in button presses...
Edited by Level42, Sat Jul 30, 2016 4:04 AM.
#55 GadgetUK OFFLINE
GadgetUK
  • 1,946 posts
Posted Sun Jul 31, 2016 7:40 AM
Here's v1.9.
I've increased the delay on preview, but also added option to enable and disable the preview by pressing Option 1 button.  It will save the setting to the SD card as well in the menu/prefs file.
In the zip is the menu, files that go in the /menu folder, and it also includes the _preview folder with the latest images (2 more added, Vindicators demo and Pounce .LSD files).
Menu v1.9
https://www.dropbox....u v1.9.zip?dl=0
Source for v1.9:-
https://www.dropbox....source.zip?dl=0
Hopefully that's not too laggy now.  There's no easy answer because it has to look for the preview file (if preview is enabled) and that's the thing that makes it freeze for a split second.  We could of course scan all the ROMs at the start and work out which previews exist in order to avoid seeking when navigating, and we could even automatically have it rename the preview files based on checksum of the ROM from some initial scan etc, but all of that would take lots of time and effort and I just dont think its worth it.   I could make the delay configurable later to make it take even longer before it tries to display the preview, but hopefully being able to turn on and off with the option 1 button is the best solution anyway?
Edited by GadgetUK, Sun Jul 31, 2016 8:03 AM.
#56 Trew OFFLINE
Trew
    Chopper Commander
  • 246 posts
Posted Sun Jul 31, 2016 8:28 AM
Seems to work a charm. I'm not using previews at all, so can only speak of the menu lag issue, but this seems to have done the trick at least. Thanks!
#57 Level42 OFFLINE
Level42
  • 2,602 posts
Posted Sun Jul 31, 2016 12:46 PM
Cool will try it a bit later....
Not sure if this is in the menu system or elsewhere but I'd love to see a filling up "loading" or "programming" bar while the game is being programmed to the SRAM. Not a biggy, but such a bar seems to shorten the waiting time.....of course it doesn't.....but.....humans like being fooled ;)
Edited by Level42, Sun Jul 31, 2016 12:46 PM.
#58 SainT OFFLINE
SainT
  • 1,063 posts
Posted Sun Jul 31, 2016 3:42 PM
Yes, agreed! It should be quite possible, as I added the ability to program any part of a file to the SRAM from the Lynx, so it should be fine to do it in blocks. There's no progress per block, but as long as the block size is small enough, that's fine. Will see if I can take a look at some point...
#59 Lynxpro OFFLINE
Lynxpro
  • 3,736 posts
Posted Sun Aug 21, 2016 8:23 PM
Are there instructions somewhere to be had?
I ended up buying another Lynx because I couldn't find where my sig.other placed my original one.  :)
About to try it for the first time!  Yeah!  :)
#60 Level42 OFFLINE
Level42
  • 2,602 posts
Posted Sun Aug 21, 2016 10:57 PM
Instructions ?
What instructions do you need ?
:D
- remove micro SD card from SD cartridge and connect it to your computer
- find ROM files (f.i. On the Internet) and download them
- if they are packed (f.i, ZIP), unpack them, you need to have files with the .LNX extension
- copy files to micro SD card
- unmount SD card and remove it from your computer
- insert SD card into the SD cartridge
- insert SD cartridge into Lynx
- power on
- "INSERT GAME" message will appear for a moment
- menu will load and display
- select game by using the d-pad and A button
- "programming" message will appear
- enjoy game
If you want to update the menu to the latest version download it from this thread
http://atariage.com/...d-cart-menu-14/
(regretfully the topic version stays at 1.4 but 1.9 is the latest version at the moment.
Copy the downloaded menu files to where the previous version was before on your SD card.
In this thread you will also find out how to download and copy screendumps of the games so that the menu program will display them before loading the game, but this is optional and usually requires manually renaming the filenames of the games.
You can also create folders on the SD card and put games in those. F.I. I made a folder with every letter of the Alfabet and stored the games starting with that letter inside the corresponding folder. This makes it quicker to select a certain game you wish to play.
I also made a folder Homebrew where I put in various demo's.
Edited by Level42, Sun Aug 21, 2016 11:07 PM.
#61 Lynxpro OFFLINE
Lynxpro
  • 3,736 posts
Posted Mon Aug 22, 2016 1:14 PM
Instructions ?
:D
- power on
- enjoy game
But if you create Letter folders, do you have to copy the Preview pics into them as well for them to work?
Is there a date corresponding to each version of the Menu that's been released?
Is there a button - or combo - that'll exit the game and return you back to the Main Menu without having the restart the entire Lynx?
What other file types - if any - besides .LNX will launch?
It's the small things...
#62 Lynxpro OFFLINE
Lynxpro
  • 3,736 posts
Posted Mon Aug 22, 2016 1:17 PM
Speaking of Preview Pics, Jason Schelhorn was inspired enough today to create this for the Marlboro game. You have his permission to use it.  :)
http://atariage.com/...lboro-red-time/
#63 Level42 OFFLINE
Level42
  • 2,602 posts
Posted Mon Aug 22, 2016 2:22 PM
No, you keep the preview pics in the _PREVIEW folder and it will work.
No idea. What does that matter ?
No. You have to power off, power on. Scanning for a button combo like that would require modding the firmware of the Lynx. (Or all the games).
Well, give them a try....
Edited by Level42, Mon Aug 22, 2016 2:23 PM.
#64 Lynxpro OFFLINE
Lynxpro
  • 3,736 posts
Posted Mon Aug 22, 2016 2:34 PM
I only asked about the dates for the Menu releases since the file is the same name. Regardless, whatever version was on the SD Adapter's card certainly wasn't version 1.9. :)
If I cribbed the info correctly, the Preview files have to be named essentially the same way as the .LNX files...
I'm loving the device. Although my pocketbook isn't going to be happy with me because I'm going to have to end up buying more of 'em for multiple Lynxes...  :)
#65 Level42 OFFLINE
Level42
  • 2,602 posts
Posted Mon Aug 22, 2016 2:37 PM
Yeah....it's a bit of a pain to have to rename the filenames....then again....it's only about 100 titles on the Lynx ;)
#66 SainT OFFLINE
SainT
  • 1,063 posts
Posted Mon Aug 22, 2016 3:03 PM
Sorry, I will get some proper instructions written up! The menu has just been an evolving thing, but now it's pretty mature and not much is changing feature wise, so it's about time I wrote something down.
#67 Level42 OFFLINE
Level42
  • 2,602 posts
Posted Mon Aug 22, 2016 3:12 PM
Some additional info for Lynxpro:
- the B button returns you to the main menu (when you are somewhere in deeper levels of folders)
- I just tried a demo titled 2048.O and it works fine, so .O files seem to work
#68 SainT OFFLINE
SainT
  • 1,063 posts
Posted Mon Aug 22, 2016 3:14 PM
Yep, all file formats are supported -- .o, .com (not that I've seen any!), .lnx and .lyx
#69 Lynxpro OFFLINE
Lynxpro
  • 3,736 posts
Posted Mon Aug 22, 2016 6:50 PM
I can't even think of any other improvements that could be done with the Menu at this point.  I noticed a little lag when doing a page down scroll but I chalked that up to the buttons probably not working optimally on this less-than-mint Lynx I bought the other day...  :)
#70 Level42 OFFLINE
Level42
  • 2,602 posts
Posted Mon Aug 22, 2016 11:48 PM
No it's not the buttons, unless you feel that in the games too.
Well, I could think of sliding box-art of the games to select them, like the way OS-X scrolls through files/pictures in the cover flow view in finder.......but I don't think lynxes resolution is high enough to display a decent box art picture.....so maybe it could be done with the screenshots we have now.
However, although great looking and fancy, it would be a long process to reach Zarlor Mercenery if they would be alphabetized.....and in the end....a simple menu system like it is now is by far the quickest way to select a game.
Maybe there should be two versions of the menu, one with the possibility of displaying the screenshots and one without for those who don't want the lag in the menu's. I must say that since 1.9 I didn't notice the lag anymore but that maybe because I have a bare Lynx PCB at the moment and I use the loose rubber buttons to select games (for testing purposes).
One suggestion, would it be possible maybe to have an edge around the displayed screenshot.....or a text put over it like "press A to load". I ask this because sometimes I got confused thinking I had already selected the game and thought it was loaded already.....I know beginners thing, but new users get a little confused as I experienced here at home.
#71 tdp OFFLINE
tdp
    Chopper Commander
  • 138 posts
Posted Thu Sep 15, 2016 2:54 PM
Loving menu 1.9 - nice work.
Okay, while going through the _PREVIEW directory, I noticed the following .lsd files:-
rtype.lsd
WHAT????!!!!!!! I know I have been away from the Lynx for a long time. BUT ...... rtype???!!! Did I miss something?
#72 Level42 OFFLINE
Level42
  • 2,602 posts
Posted Sat Sep 17, 2016 9:09 AM
I'm working on organizing my ROM files and renaming them so the preview will show up.
Is there any way to get a preview of the .LSD files on a Mac ? OR could this be posted online somewhere ?
Some names I don't recognize (so I need to find the ROMs ;)).
Also there are three Alien related names:
Alien
alienmus
avp
Which is which ?
What is allein.lsd ?
Edited by Level42, Sat Sep 17, 2016 9:10 AM.
#73 GadgetUK OFFLINE
GadgetUK
  • 1,946 posts
Posted Sat Sep 17, 2016 9:52 AM
rtype.lsd
There's an R-Type title screen demo - just title screen with music.
#74 GadgetUK OFFLINE
GadgetUK
  • 1,946 posts
Posted Sat Sep 17, 2016 9:59 AM
Alien
alienmus
avp
Which is which ?
Alien = alien
alienmus is a general music player screen - DerLuchs released a few different music test roms and thats a screen shot from the alien music test files he released.
avp is obviously the aliens vs predator rom
And finally, allein is some homebrew produced by DerLuchs - not to be confused with alien!  I think "allein" means alone in German?
I've done some more preview updates recently but not released it yet - things like Pounce, Vindicators Demo, Jungle Jack (Pitfall beta), and Hot Dog, but most people probably won't have those in ROM form.
#75 GadgetUK OFFLINE
GadgetUK
  • 1,946 posts
Posted Sat Sep 17, 2016 10:02 AM
You can just press Opt 1 in the v1.9 to disable the previews and it remembers the setting - so you've got the 2 versions you talked about already ;)
