TI-99/4A manuals and documentation project
documentation
102 replies to this topic
#51 Ksarul OFFLINE
Ksarul
  • 5,020 posts
Posted Mon Oct 2, 2017 10:30 AM
You have just given me my next drawing project. . .I'll transfer this into Visio and build a nice crisp schematic from it.  :)  It is also good that I have a Percom box to validate against. :)
I can do the same with the FLUG diagram--and it may have been a variant of the TI DSDD card that used the NEC 765. I'd have to dive into the schematics and compare them to be sure. . .
Edited by Ksarul, Mon Oct 2, 2017 10:31 AM.
#52 RickyDean OFFLINE
RickyDean
  • 1,020 posts
Posted Mon Oct 2, 2017 10:35 AM
I will scan the FLUG schematics tonight and upload them in the morning then. Glad to help promote our machine :-D
#53 Ksarul OFFLINE
Ksarul
  • 5,020 posts
Posted Mon Oct 2, 2017 10:56 AM
Also, if you could include a bitmap of the rest of the Percom card before the initial enhancement work, that would be useful as well. The bitmap you included helps eliminate some ambiguities that show up as enhancement artifacts, as some of the component numbers go from being barely comprehensible to total head scratchers. Others aren't readable on either--but I've been able to suss out enough that I'm sure I can build a good one from this. :)  One oddity that I will have to compare to my card though--it looks like they weren't using 74LS244s to buffer the address lines per the diagram, but I thought they did on the board. More nice things to look at.  :)
Thanks for scanning the other diagrams as well. My eventual goal is to have nice diagrams for every card out there, but that is a long-term project, as I've only completed about 25 pages of schematics in the last year.
#54 RickyDean OFFLINE
RickyDean
  • 1,020 posts
Posted Mon Oct 2, 2017 11:44 AM
Well I did have 4 pages of the same schematic, scanned all of them a half page at a time due to the fact that they were about 17 x 11 inch drawings. They were identical, except one that had a hand written correction on it. When I save them all as jpg's, I will upload them the same as these.
#55 Ksarul OFFLINE
Ksarul
  • 5,020 posts
Posted Mon Oct 2, 2017 12:06 PM
Many thanks! That helps a lot when doing diagram reconstructions.  :)
#56 RickyDean OFFLINE
RickyDean
  • 1,020 posts
Posted Tue Oct 3, 2017 7:22 AM
Here are the scanned pdf schematics of 3 controllers. The first 'Percom' scans are basically the same, except there are different levels of detail in each, due to age and deterioration. The one labeled Percom 4 has a pinned in mod added.
The TI pdf could be a planned DSDD controller, or maybe the existing one, I don't know for sure, haven't studied it yet.
The FLUG pdf was scanned from a set of schematics that had looked like bad copies from another, but they are fairly readable and something could be created from them, seems to be based on a pd765 controller chip?
Edited by RickyDean, Tue Oct 3, 2017 7:22 AM.
#57 Ksarul OFFLINE
Ksarul
  • 5,020 posts
Posted Tue Oct 3, 2017 1:14 PM
These will help a lot. The Product 360 Disk Controller is the standard PEB DSSD card. You can compare it to the ones on Mainbyte to verify any possible differences, but that looks like the ones I know for that card. The FLUG DSDD schematics are the schematics for the TI DSDD card. I put the manual for it up on WHT a few years ago--but I didn't have a standard schematic set to go with it. I have some hand-drawn stuff on it though, along with one of the original cards, so I should be able to restore it. Many thanks for taking the time to scan these, as it gives me more fun things to work on (I've already started on the Percom schematics).
#58 Ksarul OFFLINE
Ksarul
  • 5,020 posts
Posted Thu Oct 26, 2017 5:21 AM
Here's the cleaned-up Percom schematic.
#59 Ksarul OFFLINE
Ksarul
  • 5,020 posts
Posted Mon Nov 6, 2017 7:53 PM
Here's the next bit of schematic fun. I went through the FLUG DSDD controller schematics to turn the somewhat sketchy, late-generation-photocopy diagrams of the TI DSDD controller shown there into a clear set of schematics. That was a lot of head-scratching fun at several points in the process. I had several points where neither the old schematic nor the specifications for the TI DSDD controller could bring clarity. I will need to pull out one of my TI DSDD controller boards and do some careful trace comparisons to eliminate the final ambiguities, but for now, here is the much-improved TI DSDD controller schematic set. Each remaining ambiguity is identified with a note (there are three of them between the two pages of the schematic). I was able to condense it from three pages to two, and based on the part number in the specification, I also changed the schematic number to match the one listed in the specification, as that way people looking at both documents will be sure that they belong together.
#60 RickyDean OFFLINE
RickyDean
  • 1,020 posts
Posted Tue Nov 7, 2017 6:45 AM
Oh yes, much improvement, thanks for your hard work and dedication, put into bringing these back to life.
#61 Ksarul OFFLINE
Ksarul
  • 5,020 posts
Posted Tue Nov 7, 2017 10:34 AM
Also, I have a general question: A lot of the original TI schematics had a first page that identified the pin out for each of the PALs used on the board, along with the combinatorial logic necessary to recreate the PAL JEDEC files. Would it make sense for me to add a page with this data to the schematics that didn't have it (where available)? I have the formulae for most of the TI produced cards (as well as the data for a couple of third-party cards).
#62 RickyDean OFFLINE
RickyDean
  • 1,020 posts
Posted Tue Nov 7, 2017 11:13 AM
I believe the more information the better, it would be possible to recreate the logic, if needed. I know it's hard for a PAL to die, but if it does, it would be nice to be able to replace it.
#63 HackMac OFFLINE
HackMac
    Chopper Commander
  • 164 posts
  • Skywalker
Posted Wed Nov 8, 2017 5:12 AM
Yes, of course, it makes definitely sense to add all kind of information that are available. I agree with RickyDean that only complete documentations will help us and it will revaluate your works.
I think you don't refurbish the schematics for us so we can make wallpapers form it for our next Man Cave improvement? ;-)
#64 --- Ω --- OFFLINE
--- Ω ---
    Sunbaenim
  • 13,473 posts
Posted Fri Nov 10, 2017 9:20 AM
Would you please let me know when these are complete so I can link to them for easier public accessibility/searching.
#65 Ksarul OFFLINE
Ksarul
  • 5,020 posts
Posted Fri Nov 10, 2017 9:51 AM
Will do. I have already added the PAL data to the TI DSDD controller set, but I still have to dig out one of my cards to do some trace tracking to solve the last three ambiguities in the diagrams.
#66 OLD CS1 OFFLINE
OLD CS1
    Technomancer
  • 5,860 posts
  • Technology Samurai
Posted Fri Nov 10, 2017 9:53 AM
Although...
#67 --- Ω --- OFFLINE
--- Ω ---
    Sunbaenim
  • 13,473 posts
Posted Fri Nov 10, 2017 10:02 AM
Well, I *DID* have this displayed on the wall in my den for about 6 months at one point...
#68 arcadeshopper OFFLINE
arcadeshopper
  • 4,054 posts
Posted Fri Nov 10, 2017 10:21 PM
http://www.cafepress...stuff.557717212
#69 Ksarul OFFLINE
Ksarul
  • 5,020 posts
Posted Thu Jan 11, 2018 9:50 PM
Here's another nice schematic for you--Thierry Nouspikel's IDE controller. This includes all of the fine little nuances like a page with the alternate RTC chips and any changes needed to the board for them.
#70 arcadeshopper OFFLINE
arcadeshopper
  • 4,054 posts
Posted Mon Feb 26, 2018 12:51 PM
anybody have Preditor?  I just ordered a copy from mdude so I'll scan it when I get it if not
Greg
#71 helocast OFFLINE
helocast
    Chopper Commander
  • 175 posts
Posted Mon Feb 26, 2018 1:18 PM
Is this one worth scanning for The Collection or just noise being third party and all?
SAMS Computer Facts, Computer: Texas Instruments TI-99/4A Model PHC004A, April 1984
I picked it up pristine/sealed off of eBay - several 11"x17" photos of component locations with list by value/tolerance, troubleshooting, etcetera.
#72 arcadeshopper OFFLINE
arcadeshopper
  • 4,054 posts
Posted Mon Feb 26, 2018 1:41 PM
https://www.zazzle.c...577160522691353
#73 Fritz442 OFFLINE
Fritz442
    Chopper Commander
  • 213 posts
Posted Mon Feb 26, 2018 4:53 PM
YES, I think so!!!  :thumbsup:
#74 acadiel OFFLINE
acadiel
  • 1,456 posts
  • www.hexbus.com
Posted Mon Feb 26, 2018 5:12 PM
Just check to see if it’s on http://www.hexbus.com/tibooks in case it was already done :)
#75 OLD CS1 OFFLINE
OLD CS1
    Technomancer
  • 5,860 posts
Posted Mon Feb 26, 2018 8:12 PM
TRIS.
Also tagged with one or more of these keywords: documentation
