APE not working with Windows 10 and RS-232
20 replies to this topic
#1 cbmeeks OFFLINE
cbmeeks
    Moonsweeper
  • 297 posts
Posted Thu Jun 16, 2016 5:09 PM
I am using an original Atari 800.  On my Windows 10 machine, I have a USB to 9 pin adapter.  My SIO to PC device is the old one (NOT USB).
The SIO to PC worked on my Windows XP machine years ago.  The USB to 9 pin adapter I have now works with other devices.  But they don't seem to work together.
I run the configuration wizard and it says it was successful.  However, it then shows "[Device Manager] RS232 Driver Failed to Initialize! (USB ONLY Mode Enabled)"
Booting the Atari from a mounted disk does nothing.  I only get the memo pad.
The version of APE I am using is 3.0.2.  The SIO to PC devices just shows a red light.
Any ideas what it could be?
Thanks.
#2 Stephen OFFLINE
Stephen
  • 6,635 posts
  • A8 Gear Head
Posted Thu Jun 16, 2016 6:09 PM
I can assume the USB to serial device is based on an FTDI chip.  On my Windows 10-64 machine, I first had to get VCP drivers for it.  I am trying to think if I needed the APE 64-bit drivers as well (to run my "generic" device, or if I only did that for the Tucker USB version).
#3 Timothy Kline OFFLINE
Timothy Kline
    Moonsweeper
  • 335 posts
Posted Thu Jun 16, 2016 6:11 PM
Thanks.
When you start APE, do the LEDs light up?
The other thing you'll want to make sure is that you have the signed drivers released by AtariMAX, as Windows 8 and up are grumpy when it comes to unsigned drivers. You can grab the latest signed drivers from the AtariMax forum as long as you've registered for an account.
http://www.atarimax....c.php?f=5&t=889
--Tim
#4 Timothy Kline OFFLINE
Timothy Kline
    Moonsweeper
  • 335 posts
Posted Thu Jun 16, 2016 6:15 PM
The other thing I'm seeing is that if you're running a 64-bit version of W10, you might be stuck unless you purchase the Version 3.0.13 which includes 64-bit RS232, USB and VCP Support.
--Tim
#5 cbmeeks OFFLINE
cbmeeks
    Moonsweeper
  • 297 posts
Posted Thu Jun 16, 2016 7:52 PM
Thanks for the responses.
To answer a few questions..
I am using 64 bit Windows 10.  The USB to 9 pin serial is based on the FTDI chip but I have used it successfully recently.  I use it to transfer data to an Apple IIe serial card.  So I know it works and the driver should be good.
I think the problem is on the APE end.  What does it take to get 64 bit RS232 support?  Buying the software?
Thanks.
#6 Larry OFFLINE
Larry
  • 3,947 posts
Posted Fri Jun 17, 2016 3:54 AM
Contact Atarimax. Ape was never designed to run with an adapter of that sort. To be reliable you likely need his usb adapter and probably licensed software.
Edit: Pretty sure this topic has been covered at the Atarimax forum.  Folks have been trying this type of setup for a long time -- including me.
-Larry
#7 atarifanboi OFFLINE
atarifanboi
    Chopper Commander
  • 224 posts
Posted Fri Jun 17, 2016 6:17 AM
I'm pretty sure that it says somewhere in the docs for the serial port version of the SIO2 PC by Atarimax, that it DOESN'T work with USB to serial adapters.
The USB drivers for APE only work (AFAIK) with the USB version of SIO2PC.
I have a Windows 10 PC running APE and it took a while to make my serial card actually work with it due to driver issues, but it does indeed work.
#8 Gunstar ONLINE
Gunstar
    Gunstar
  • 8,762 posts
Posted Fri Jun 17, 2016 8:37 AM
I've been through this, I have a COM2USB cable adapter and drivers and it works fine with AspQT, and with Prosystem from APE, but will not work with APE itself. So I have been using AspQT for file transfers and Imagic and Prosystem from APE for other stuff. I don't think Tucker intends to make a version to work with generic RS232 versions using a USB adapter. It would cut into his SIO2USB sales. Just use AspeQT or buy a new adapter from AtariMax.
#9 w1k OFFLINE
w1k
  • 1,663 posts
Posted Fri Jun 17, 2016 9:21 AM
looool...
ape
welcome in 1983
#10 Brentarian ONLINE
Brentarian
    Moonsweeper
  • 355 posts
Posted Fri Jun 17, 2016 2:51 PM
If your PC is a desktop you could easily install a serial card for under $20 (Amazon, EBay, Newegg, etc.).
#11 atarifanboi OFFLINE
atarifanboi
    Chopper Commander
  • 224 posts
Posted Sat Jun 18, 2016 2:29 AM
Exactly what I did :)
#12 Bikerbob OFFLINE
Bikerbob
    Dragonstomper
  • 608 posts
Posted Mon Jun 20, 2016 7:23 AM
I am not sure about everything that has been mentioned.
1. I am NOW a registered user of APE. But I did get the Trial to work with an original SIO2PC (Serial)
2. I have used that with a 15 year old serial to USB converter. All the software is concerned with.. is it a com port, am I getting the correct hand shaking and is the data coming and going using the correct lines. All the driver software does is re-route traffic.
3. Native SIO2USB - this I am not positive on. I think.. you need to be registered to use APE with windows 10.
If you simply want ATR access - No printer, no network, no modem etc.. use AspeQt or RespQt .. as far as I am aware they work pretty well.
I am waiting on 2 FTL breakout boards to come in. If you search threads.. there is talk about these being used.. and if I remember correctly with APE and I THINK.. not positive they used the trial version USB on windows 7.
James
#13 Spanner OFFLINE
Spanner
    Chopper Commander
  • 149 posts
Posted Fri Jan 12, 2018 4:13 PM
So Ape don't work with SIO2PC that is made with a FTDI chip..?,well It don't with mine....Thats the unregistered version,It works I think if you have the full version but I am not sure...I don't have the full version.
#14 DrVenkman ONLINE
DrVenkman
  • 2,575 posts
  • Back off, man! I'm a scientist.
Posted Fri Jan 12, 2018 4:31 PM
Please stop with the bullshit. I have one of Ray's devices  (with an FTDI chip) made in 2014 or so. Works fine with AspeQt, RespeQt, SIO2OSX (*), and yes - APE/ProSystem's trial version. Hell, it even worked with APE ON MY MAC! when I ran it under CrossOver and created a symlink from an empty file called "COM2" to the proper /dev/USB device in the file system.
(*) Before changes to OS X made that program stop functioning.
#15 Spanner OFFLINE
Spanner
    Chopper Commander
  • 149 posts
Posted Fri Jan 12, 2018 6:59 PM
Well its not working with mine..its detect it I can't load a Disk image and it says this.. [Device Manager] RS232 Driver Failed to Initialize! (USB ONLY Mode Enabled)
This is the one I am using,the one I made.. http://atariage.com/...-but-effective/
Edited by Spanner, Fri Jan 12, 2018 7:01 PM.
#16 Kyle22 OFFLINE
Kyle22
  • 3,180 posts
Posted Fri Jan 12, 2018 7:08 PM
I bought a cheap Chinese FTDi cable from eBay and soldered it in to an SIO plug. Works perfectly with RespeQt and APE.
APE limits me to 52K UltraSpeed, but RespeQt runs fine at full speed 125K divisor 0.
Check your drivers for the USB device. Check the serial port parameters in Device Manager.
#17 Kyle22 OFFLINE
Kyle22
  • 3,180 posts
Posted Fri Jan 12, 2018 7:13 PM
Have you changed the PID/VID back to FTDI defaults?
The individual that built that cable found it necessary to use a custom PID/VID for his device.
I uploaded the tools here (somewhere) to fix this.
#18 _The Doctor__ OFFLINE
_The Doctor__
  • 3,255 posts
Posted Fri Jan 12, 2018 7:19 PM
Might be a good idea to put pictures of your adapter cord handiwork up, might shed some light on things... sometimes they are crap from china and you can do it all the same with a slightly different device though called or even labeled as being the same and one works the other doesn't
#19 Kyle22 OFFLINE
Kyle22
  • 3,180 posts
Posted Fri Jan 12, 2018 7:24 PM
Edit: I thought you had an A8W device. Upon re-reading your OP, I see that you are running an RS232 device.
Does Win 10 support RS232?
Edited by Kyle22, Fri Jan 12, 2018 7:29 PM.
#20 DrVenkman ONLINE
DrVenkman
  • 2,575 posts
Posted Fri Jan 12, 2018 7:29 PM
Have you tried this on an XP (or 7) machine?
You may have better results.
For what it's worth, I used my Ray-made device with APE/ProSystem trial version to copy a copy a couple disks from a 1050 a few months ago under Win10 just fine.
#21 Kyle22 OFFLINE
Kyle22
  • 3,180 posts
Posted Fri Jan 12, 2018 7:48 PM
