32k expansion for the side port - released
32k sidecar memory
406 replies to this topic
#76 retroclouds OFFLINE
retroclouds
  • 1,689 posts
Posted Thu Aug 18, 2016 10:17 PM
would be cool if, in addition to the 32k ram , the board could include a programmable timer that generates a load interrupt signal. See some possibilities for a task scheduler that way.
#77 Opry99er OFFLINE
Opry99er
  • 10,609 posts
Posted Thu Aug 18, 2016 10:51 PM
My speech synth has a load interrupt button on it. :D
Richard Lauhead from the MSP UG did the mod.
#78 OLD CS1 OFFLINE
OLD CS1
    Technomancer
  • 5,935 posts
  • Technology Samurai
Posted Fri Aug 19, 2016 6:29 AM
Can you hit that 60 times a second? ;)
#79 jedimatt42 OFFLINE
jedimatt42
  • 1,860 posts
Posted Fri Aug 19, 2016 10:56 AM
i can see me buying a couple of these when they are out!
I clearly need a bigger house so I can have need for even one.
-M@
#80 Opry99er OFFLINE
Opry99er
  • 10,609 posts
Posted Fri Aug 19, 2016 11:19 AM
I suppose this would depend on a few factors... ;)
I do live in Tennessee and could probably scrounge up some meth... My wife is a coffee drinker, so I have access to that.
I am guessing without chemical modification, I could hit the button 7-8 times in a second.
#81 jedimatt42 OFFLINE
jedimatt42
  • 1,860 posts
Posted Fri Aug 19, 2016 12:07 PM
How about a slow-motion option? poking the READY pin so you can slow down your games...
Actually, all of that is out of scope... I believe in single-responsibility principles of design. I am working on a layout that includes headers for daughterboards. You could add whatever you want that way.
-M@
#82 Tursi OFFLINE
Tursi
  • 5,500 posts
  • HarmlessLion
Posted Fri Aug 19, 2016 12:12 PM
Well, if it doesn't have a debounce circuit, you could take advantage of mechanical contact bounce for a few more rapid hits... mind you it's pretty hard to control the frequency of the input. ;)
#83 JamesD OFFLINE
JamesD
  • 8,406 posts
Posted Fri Aug 19, 2016 12:58 PM
Playing back sound samples and 1 bit music would certainly benefit from a higher interrupt rate.
As I said in another thread, the one in the CoCo 3 would be worth a look and it's not difficult to implement.
A task scheduler can run off of a vertical blank interrupt.
#84 retroclouds OFFLINE
retroclouds
  • 1,689 posts
Posted Sun Aug 21, 2016 3:06 AM
I'm aware it's possible to use the vertical blank interrupt for that. I've already done a task scheduler on the TI-99/4A using that approach (spectra2 game library).
But I'd like to try my hands on implementing some form of preemptive task scheduling; timed load interrupts would fit that perfectly. Also a nice benefit would be the higher interrupt rate.
That could possibly also be accomplished using the TMS9901 as a timer. There was a discussion about that a few years ago http://atariage.com/...901-as-a-timer/
#85 jedimatt42 OFFLINE
jedimatt42
  • 1,860 posts
Posted Tue Aug 30, 2016 12:57 PM
In attempting to make the pcboard layout small, the address lines from the TI to the SRAM chip are the biggest pain. So i am thinking order of an address line doesn't matter to RAM like it does to ROM. Except of course those that are about the highmem/lowmem mapping.
Am I crazy, or correct?
-M@
#86 Stuart OFFLINE
Stuart
    Dragonstomper
  • 833 posts
Posted Tue Aug 30, 2016 4:04 PM
-M@
Correct. Ditto for the data lines as well.
#87 JamesD OFFLINE
JamesD
  • 8,406 posts
Posted Tue Aug 30, 2016 4:22 PM
Just keep a counter of vertical blank interrupts.
The Amiga does this.  You can set how many "jiffies" between task switches and that's just that counter.
#88 jedimatt42 OFFLINE
jedimatt42
  • 1,860 posts
Posted Tue Aug 30, 2016 4:28 PM
I'm officially and politely asking now that task scheduler discussions move to a new thread.  It will make it easier for people to find your discussion as well.
-M@
#89 Willsy OFFLINE
Willsy
  • 3,100 posts
Posted Wed Aug 31, 2016 3:38 AM
Aye. It's only important for ROM.
#90 Lee Stewart OFFLINE
Lee Stewart
  • 3,906 posts
Posted Wed Aug 31, 2016 6:07 AM
-M@
I don't understand the implied question in your opening paragraph.
...lee
#91 jedimatt42 OFFLINE
jedimatt42
  • 1,860 posts
Posted Wed Aug 31, 2016 8:35 AM
...lee
The question is: can I swap address lines 5 and 6 between the TI and the SRAM chip?
With a prom, there must be a contract defining how the lines are used so that the chip can interface with multiple devices, namely the programmer device and the consuming device.
But with the sram, and no battery and removability goals, there is only one device to make a contract with.
So it is fine to swap, swivel and shuffle the data and address lines.
My first board posted earlier was about 4"x3" , armed with this knowledge and less chips, my layout is now 3"x2". This cuts the cost of the most expensive component in half since you typically pay by the square inch.
Speaking of less chips, I have eliminated the buffers for the address lines and control signals but kept the buffers for the data lines. This passes memory tests on the prototype, where not using the buffer back to the TI typically failed memory tests.
So it is down to the following 4 ics:
SRAM,
Bidirectional data line buffer
3 to 8 bit decoder
Double quad-AND gate
The LED is controlled with a discrete pnp transistor.
So I feel done enough trying to reduce waste from the design.
-M@
#92 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 13,644 posts
Posted Wed Aug 31, 2016 8:57 AM
That is neat!  I'm glad you included a little LED in the design to jazz things up a little.
I cannot wait to get my hands one.  I'm building another (smaller) TI system up and it NEEDS  this little device.
The size you mentioned seems rather nice.  Once this thing is completed and someone designs a 3D printed case for it, they'll be flying out the door.  I can see many more people getting into the TI with a combo of your memory expansion married with the FR99.
#93 Sinphaltimus OFFLINE
Sinphaltimus
  • 2,518 posts
  • Distracted at the Keyboard
Posted Wed Aug 31, 2016 9:04 AM
I need this as well. I'm not waiting on no cases. You say when.
This, and the Vampire II board for my Amiga 500 (it's at about the same stage of development) and I'll be set. *THUD*
Edited by Sinphaltimus, Wed Aug 31, 2016 9:07 AM.
#94 Willsy OFFLINE
Willsy
  • 3,100 posts
Posted Wed Aug 31, 2016 10:57 AM
Have you got a schematic?
#95 Tursi OFFLINE
Tursi
  • 5,500 posts
  • HarmlessLion
Posted Wed Aug 31, 2016 11:23 AM
You can normally swizzle both address and data lines to a RAM chip, yes. All a RAM cares is that each address points to a unique cell, the order of the cells or the bits doesn't matter. :)
#96 jedimatt42 OFFLINE
jedimatt42
  • 1,860 posts
Posted Wed Aug 31, 2016 11:59 AM
I have 2 schematics, and neither are exactly what I've designed on the pcboard.
Next steps:
  update the schematic to match what I'm building
  build that exactly on the breadboard again
  check the pcboard layout against the schematic
  wait for the power jacks to arrive so I can verify the physical layout
  get OSHPark to print me a sample - wait 12 days
  build the sample
  cross my fingers
  test the built sample
  order parts and boards in greater quantity
  wait
  assemble
  test
  distribute
Of course things could go horribly wrong.
-M@
#97 Ksarul OFFLINE
Ksarul
  • 5,157 posts
Posted Wed Aug 31, 2016 5:42 PM
But it is a really fun ride, @Matt--and when you are done you'll have a project to be proud of, one that really serves a community need.  :)
#98 jedimatt42 OFFLINE
jedimatt42
  • 1,860 posts
Posted Wed Aug 31, 2016 6:01 PM
It is totally fun!  This little board is cause for learning so many fundamentals.  When I was 11, the TI made me decide I wanted to go to college and learn to do this sort of thing... design ICs actually. But then I started programming classes in high school, decided I didn't need to learn to mess with hardware. ( Which I would still say is true, based on the word 'need' ) But learning to mess with hardware is so much more rewarding/tangible right now than the last 20 years of bits on disk.   I do want to settle down for a while and really do some game writing on the TI and Geneve once this board is rolling out.  But who knows. It is all hobby heaven.
-M@
#99 arcadeshopper ONLINE
arcadeshopper
  • 4,199 posts
Posted Thu Sep 1, 2016 11:41 AM
Can't wait to see/try it! Great work and thanks for sharing the details :)
Greg
#100 Sinphaltimus OFFLINE
Sinphaltimus
  • 2,518 posts
Posted Thu Sep 1, 2016 12:13 PM
I may have gotten confused with several projects around here.
I want to be clear, this is a 32k ram expansion for the side port that replaces the need for 32k in a PEB or replaces the 32k internal ram mod correct?
No other bells whistles features or doodads right? An amazing accomplishment for sure, just trying to set my expectations properly, it can not; for instance, core a apple.
Edited by Sinphaltimus, Thu Sep 1, 2016 12:14 PM.
Also tagged with one or more of these keywords: 32k, sidecar, memory
