TIImageTool on Github
56 replies to this topic
#51 mizapf OFFLINE
mizapf
  • 3,563 posts
Posted Mon Jun 5, 2017 6:00 AM
In my case it is just an Ant project, so you actually don't have to do anything else but run ant. I did run into some trouble when building other people's projects, especially when they are using more complex tools like Maven ... and don't even tell you that you have to install Maven first, so you first need to figure out what build tool it more or less obviously seems to require.
#52 mizapf OFFLINE
mizapf
  • 3,563 posts
Posted Thu Jun 15, 2017 4:58 AM
Et voilà, on a une autre langue ... Merci Fabrice!
Italian is also on its way, and if someone would like to add his mother tongue (apart from English, German, French, Italian), just mail me.
#53 ralphb OFFLINE
ralphb
    Dragonstomper
  • 635 posts
Posted Tue Jul 4, 2017 7:35 AM
Michael, it seems that there is a small bug in the TIMT GPL disassembler.  This statement
MOVE  12,@>8300,G@>7000
generates the byte code
25 00 0C 70 00 00
but your latest TIMT disassembles to
601F: MOVE  >000C BYTES FROM @>8300 TO GRAM@>8370                25 00 0C 70 00
6024: RTN                                                        00
Not sure what happens, but the GROM address takes two bytes, not just >70 (meaning >8370 for CPU addresses).
#54 mizapf OFFLINE
mizapf
  • 3,563 posts
Posted Tue Jul 4, 2017 8:54 AM
You seem to be right. For the lack of GPL code using GRAM destinations, I never fully checked that part of the disassembler.
  • RXB likes this
#55 RXB ONLINE
RXB
  • 3,550 posts
Posted Tue Jul 4, 2017 8:34 PM
You should run the Souce code of RXB GRAM into our GPL Assembler and see if it checks out.
I only use the RYTE DATA GPL Assembler myself.
#56 mizapf OFFLINE
mizapf
  • 3,563 posts
Posted Fri Jun 8, 2018 3:36 PM
Abbiamo un'altra lingua in TIImageTool! Many thanks to Ciro (ti99iuc) for his translation.
You can download the latest release from Whtech or http://www.mizapf.eu...tiimagetool.zip
#57 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,391 posts
Posted Sat Mar 9, 2019 4:11 PM
Hi Michael, when I "view files as text" with TIImageTool, it seems that two periods are displayed for each period in the file.  I first noticed this oddity while viewing source COPY directives such as this one:
       COPY "HDS1..DU1..EQUATES"
       COPY "HDS1..DU1..DSKU-MAIN"
       COPY "HDS1..DU1..COMPARE"
       COPY "HDS1..DU1..FILE-COMP"
       COPY "HDS1..DU1..COPY-BACK"
       COPY "HDS1..DU1..COPY-BIT"
This effect is not limited to source files.  I am reviewing some files on an old XP machine so perhaps this issue is specific to some OS versions?
