newcoleco Posted July 14, 2016 Share Posted July 14, 2016 (edited) There are lots of Coleco pictures around into PowerPaint format, some made with original software, some converted from JPEG or BMP files by using a picture converter such as BMP2PP by Marcel deKogel or Dither. These pictures .pp files are size 10K or 40K each and aren't in a format convenient for ColecoVision projects but are used by ADAMites for their Holidays special slideshow disks. You can convert PowerPaint files into Dale Wick's .pc files and use them in Atarimax Coleco Ultimate SD Multicart or view them with a simple viewer on your PC. How to add PP files into ColecoVision projects? Extract PATTERN and COLOR tables from PowerPaint files with this command-line tool. This tool has a lot of options (flags) to deal with each situation, even an integrated splitter to extract PATTERN and COLOR tables to be loaded into VRAM. Download (EXE) Version 1.1 : pp2pc.zip Source code available on demand. (on Dale Wick's SVN server) Edited July 14, 2016 by newcoleco Quote Link to comment Share on other sites More sharing options...
