The "perfect" Lynx....
Level42
I wonder if c39 was helping to buffer the power rail before. Maybe without it your have too much draw?
Sent from my SAMSUNG-SM-G935A using Tapatalk
LOL....in fact I figured it wouldn't hurt to leave it in so I kept it on the board.....if it doesn't help, it's not in the way either.....at worst it will act as an extra filter for any AC....draw shouldn't be a problem. I measured 700mA max. by the Lynx with McWill screen, the Visaton _and_ the frequency mod at max frequency. I have since removed the frequency mod (for now....) so it should be less. The Powerboost 1000C is capable of 1000mA so there is a pretty high margin....so I don't think it can be the draw....
Mmmmmmmm...well I opened the Lynx again and sound is normal....must be something physical....actually quite happy about that, the audio amp is still fine.
While checking the LCD and former LCD "pins" for shorts, I also measured the voltage again.
I was quite surprised to measure only 4.3V when it was running on battery !!!
This shouldn't be happening....but even so....the Lynx works 100% on that voltage, even the LCD works as normal.
Now this is the even stranger thing:
When I hook up the AC adapter the voltage is about 5.15V....exactly as expected. Then,,when I remove the AC adapter connection, the voltage stays at 5.15V..............however, when I then power down the Lynx with the button, and turn it on again, the voltage is only 4.3V !
That's now how it should be IMHO...
But again....the Lynx actually doesn't seem to mind....it works fine, thanks to its CMOS nature I guess.
Anyway the voltage doesn't have any influence on the LCD.....
Going to post about this on the Adafruit forum...they respond very quickly there....
Edited by Level42
Oh noes! the dreaded Insert Game screen. I always found it odd they included an Insert Game message that only shows when the game is dirty. Because without a game, you cannot power on at all. :P
Also I'd love to see pick of the components you gutted out if you haven't tossed them yet. ;-)
Weird about that 4.3V thingy. The difference between it and nominal 5V is about the expected .6-.8V range for a silicon diode junction.
I wondered about insert game message since it only shows when the cart is inserted but is dirty or defective. Was that an original design before someone ran 5v line through 2 pins to make it act like power enable where disconnecting the cart would cut off power and prevent battery for draining?
is the battery pack I opened. 10k mAh PNY brand, and it appears to be 4 batteries in parallel with charging circuit in between 2 of them. The 5v input is on the bottom right side of the picture and the output are on right side. My idea was to carefully rearrainge those batteries so they'd fit inside my Lynx, remove the original power jack, mount the micro USB where the original power jack was, alter the shell to accomodate the mini USB plug, and run the 5v output to where the 5v regulator normally is.
The only issue would be low power warning, unless I can figure that out I could just play Lynx until it shuts down unexpectedly. Since the output isn't supposed to go below 5v, the low battery flashing LED on Lynx II probably won't happen. Those chips are frickin' tiny and even with 10x magnifying glass I can't read the number. Or I could hack Lynx shell and move the 5 LED plus status button from the pack so I could check at the press anytime and start charging when it shows low.
Edited by 7800fan
It is possible the power design circuit was added after the firmware was finalized. Someone decided it was a good idea to make a system that could not turn on without the power rail present on the cart connectors.
As for low battery indicator, the Li-Ion battery pack outputs 3.7V or a multiple thereof, so a step up DC-DC transformer/regulator IC provides 5V. The voltage on the Li-Ion battery will droop somewhat before it fails to provide sufficient amps. This also occurs with any battery technology, rechargeable or throwaway. Therefore a low battery indicator needs to source the voltage level from the Li-Ion battery pack, not VCC. It's up to the controller whether it cuts the juice cold turkey or slowly browns out as the battery fails to provide adequate current. It is better for long term life expectancy not to allow Li-Ion batteries to deep discharge so most modern controllers use cut-off as opposed to brown out. Also brown out won't damage components but can cause data corruption on smart devices which rely on rewriteable storage. This is a non issue for embedded systems that do not rely on non-volitale storage.
Personally I've found it fascinating to watch the failure modes of portable game consoles as the batteries die. Each subsystem goes out at a different time. For my backlight modded DMG gameboy, the red LED fades slowly, then the screen disappears but the audio and CPU continue to run. Finally there's a pop from the speakers indicating final death but the lime green backlight continues to glow long after the system is dead.
For Lynx I, The screen starts turning green, and I bump the contrast. It turns more green until the graphics fade, then audio starts getting distorted because the driver can't keep up, followed by a "pop" and the system goes nite-nite.
Well......they couldn't have put :
"Please remove the cartridge, get some 96% alcohol and Q-tips, dip a Q-tip in the alcohol and rub the contacts (the metal shiny things on the bottom of the cartridge) with it until all dirt has gone. Get a new Q-tip and repeat if Q-tips stay turning dirty looking. When they stop looking dirty, you're done. Now re-insert the cartridge and power on again !"
on that tiny screen, right ? :D
I thought I had uploaded the pic with all the gutted parts, but it looks like I didn't, so here it is:
Well it was a fantastic arcade game weekend at Eurocade 2016 in Oldenburg Germany. The most impressive moment for the weekend for me was while we played a Quadrapong table with friends........ maybe the most simple of video games ever, but even so, playing it with 4 guys (and a bit of alcohol in the blood) was totally AWESOME !!!
Even greater was it that my 14 year old son was there too, and on many, many games it was me and him staying playing until the last moment......and in all modesty....I won most games.......then again, I was the one with the (ahem) most experience with Pong games (= I was the oldest bloke there).
Anyway, playing against a human being, and especially some good friends is simply BRILLIANT ! :)
(That's why we need an internet adaption of Comlynx !).
Edited by Level42
OK, the screen is still the same and I guess I will take McWill's offer to ship it to him to have a look....
In the mean time, I saw a cheap Lynx I on offer on Marktplaats and offered an even lower price since it was a "restoration project". Obviously the screen glass was missing and the battery cover was gone too. This didn't matter for me since I wanted the shell only....and of course I'd keep the PCB for spare parts (f.i., the pot I needed :) )
So for 15 euro's I picked it up today. The case is in very very nice condition, even the stickers on the backside.
The reason I needed is because a long time ago......I put the long screws in on the wrong side....and if you screw far/hard enough.......you get two of those nice "bumps" on the left side of the Lynx......which I really do not like ;)
Also....I'm currently running some tests to see what the Lipo battery really is.
I am charging the Lynx with a power bank. The capacity of this powerbank is about 2500mAh I guess, so I knew it would take several times to charge the Lynx fully.
I'm measuring the total mAh with one of those little USB devices....might not be 100% accurate, but I just want to have a rough idea.
The good thing is that it never resets the total time and mAh until you press a button, so you can run multiple charge runs after one another.
So I fully charged the power bank, then charged the Lynx with it until the Powerbank was empty, then charged the powerbank again and so on and so on....
The picture shows the results after the SECOND run so the lipo is not complete full yet !
The charging is running with about 0,60 A. I guess the Raspberry Pi power supply could provide some more amps, but not sure if the Powerboost allows for more charging current.
Oh and of course I'm doing all this with the Lynx constantly powered off.
Now at the third (and I guess last) run....
Anyway, this will give an idea of the real capacity of the Lipo.
Nice!
I got to play 4-player 2600 Warlords for the first time in several years at this year's Davis Atari Party. Warlords would be a great title for ComLynx action.
But before we start preaching to the choir about ComLynx-to-Internet, let's settle first on getting the emulators supporting ComLynx-to-USB!
  • 2 months later...
Great job, Level42! It's exactly what I had in mind. I have two Lynx MKII's waiting to go through similar makeover. I have noticed the power section is a bit different than on MKI though. Which parts do you think I could butcher off the board?
One of the lynxes gave up on me after a recap, but luckily it still works if I pipe 5V directly on C41. So I'm thinking if I gut everything ftom there back to the power input, nothing could go wrong, right? :)
  • 3 months later...
That was CowDog's plan, at least he mentioned that a few time in this thread. It would be awesome. We could add some features like external LEDs.
I guess the hard part is designing the PCB. Production can be done in the far east for little money these days ;)
It will never be a "dead easy" mod though. Tracks will have to be cut, (some) components will have to be removed. But it shouldn't be much harder than installing a McWill LCD.
The big problem is the cart connector in this idea.
Haha, no.....although.......hah....well who needs a cartridge connector if you could incorporate the SD-card hardware onto that brand new main PCB ;)
Wow. A brand new PCB, all Lynx hardware in FPGA, McWill's screen incorporated....damn would be sweet. But also expensive and a lot of work to develop and produce. Would cost a lot and.....oh well, it's nice to dream a bit ;)
No, the idea was to develop a small PCB that would incorporate a Powerboost 1000C and some on/off circuitry to keep using the original buttons and maybe one or more simple extra features....
You'd need to somewhere break-up the original power circuit, there were the 9V line ends and the 5V "starts" (but we don't really know if there is a good (single) spot for that to be honest, that's why I removed all those parts ;)) You'd insert the output of the designed PCB there..... but it will always require to cut tracks at least to use the original power on/off buttons. Oh and I'm only talking Lynx I....I haven't got a clue how the same idea would work out in a Lynx 2....
  • 2 years later...
I'm in the process of designing an all in one board for this mod. Using the schematics of the powerboost 1000c I was wondering if I could ditch the whole usb output side and stick to 5.0V and GND only?
I know the usb output uses some resistors on its D- and D+ connections but isn't this only of importance when connecting a usb device to it like a tablet or a phone? I'd like to strip as much away as possible from the original powerboost board to keep it small in size and to make space for an LTC2950 and an inverter.
  • 1 month later...
  • 10 months later...
This thread reminded me of watching a film where the ending was cut from it. What happened?  I kept reading hoping for a more detailed step-by-step how-to, possibly one for an amateur like me.  Really, I am right now doing the 5v usb power mod out of necessity because I cannot power up my lynx ii without it, but I would love to figure out how to use the power and restart buttons.
However, I am curious how this thread/mod would've developed now with so many power banks out their.  A lot of the powerbanks, I think, have circuit boards that are more full, if that's the right word, than the powerboost 10000.  And there are a lot of modules like the 10000.  Still, I'd be perfectly happy if I can just get my power buttons to work. Any assistance would be appreciated.   By the way, kind of new to this forum as well as lynx and modding in general.
