SumerNivek Posted July 30, 2016 Share Posted July 30, 2016 All, I am very (and I mean VERY) new to programming, and have a sort of a newb question. After typing in the game "Blocked" from ANALOG's very first issue, I found that it starts up. But once the joystick's fire button is pushed, the game plays for a split second, but then crashes back to BASIC with an ERROR 12 message. The line in question is line 210. Here it is: 210 X=L1:Y=L2:GOSUB D+20 I am assuming line 410 will also need to be fixed, because it is for player 2's joystick and has the same line, but with R instead of L. Any input on how to correct this error to get the game to play? I understand that the XEGS uses an updated BASIC, so I am curious if the problem stems from that? Any help would be appreciated, and I am sure the answer may be obvious, but like I said, I am brand new to programming and I am trying to figure it out step by step! If you need to view the whole type-in program, it is at AtariMania under their magazine section. It's ANALOG issue #1, page 15 of the magazine (actual page 17 of the PDF). Thanks for any help you provide to this newbie programmer! Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted July 30, 2016 Share Posted July 30, 2016 Analog Computing 01_Jan_Feb_1981.atr Try the program from the atr LIST and compare with your TYPED in version.. 1 Quote Link to comment Share on other sites More sharing options...
Madi Posted July 30, 2016 Share Posted July 30, 2016 (edited) @SumerNivek Since I had no Analog software disk 01-1981, I had to type-in the short listing. The game runs fine with no bugs. I think you made a typo. Check your lines with the typed in attached listing or load the game from the ATR imaged provided by rdea6 . The typed in game is attached as basic LST format, Thank you rdea6 , You are always there when someone needs help. madi BLOCKED.LST Edited July 30, 2016 by Madi Quote Link to comment Share on other sites More sharing options...
SumerNivek Posted July 31, 2016 Author Share Posted July 31, 2016 Thanks to you both! I found it. Line 205...I put a "0" at the end instead of a "D." Thanks again, guys. Plays great now! 2 Quote Link to comment Share on other sites More sharing options...
