Jag CD Asteroids
rhcocker
Here are the files from the site. Well, mostly. Iirc, I updated cdrecord.exe and cygwin1.dll in this archive for compatibility. And you'll have to run scanbus to edit the burn.bat for your setup but compiling this worked for me.
asteroidsencryptedstopcd.zip
Also, here's a backup I made of the encrypted disk using Alcohol 120%, if it's of use.
Asteroids (encrypted).zip
If nothing else, you can grab the .bin file from this post and run it through JiFFI for a similar result. Considering it's the same version you had.
Hope that helps.
