the_crayon_king Posted August 5, 2016 Share Posted August 5, 2016 Does anybody need this ? http://i.imgur.com/edTly1f.jpg So cut the traces where the red lines are and remove the two resistors circled. The blue circle is where the ends of the 620 ohm resistors go. I can make a full tutorial if needed but this is just an addition to the per-existing NES controller mod as everything not shown here is the same. Why not just use a Genesis controller ? Because that's too easy. Quote Link to comment Share on other sites More sharing options...
0078265317 Posted August 5, 2016 Share Posted August 5, 2016 There was already a guy doing that here many years ago. And I already use nes unmodified controllers on a 2600 with a series of adapters. Now if 2600 controllers can work on a 7800 then its all good. But I don't have a 7800 yet. Quote Link to comment Share on other sites More sharing options...
walter_J64bit Posted August 6, 2016 Share Posted August 6, 2016 You should make a full tutorial! Quote Link to comment Share on other sites More sharing options...
the_crayon_king Posted August 6, 2016 Author Share Posted August 6, 2016 YOU NEED THUS CABLE: https://www.amazon.com/Extension-Atari-2600-7800-Joystick-Controller/dp/B008H5V11C/ref=as_li_ss_tl?ie=UTF8&linkCode=ll1&tag=atariage&linkId=a598e5c6d6e043b136f8401127381e6b Quote Link to comment Share on other sites More sharing options...
Andromeda Stardust Posted August 9, 2016 Share Posted August 9, 2016 Dogbones use surface mount chip unlike the rectangular NES which uses through hole. There's also a lot less space inside the controller. So the mod would be much more difficult to perform on a Dog Bone. Also Dog Bones are fairly uncommon and getting pricier, so I would rather see someone convert the old rectangle. Quote Link to comment Share on other sites More sharing options...
FireTiger Posted August 9, 2016 Share Posted August 9, 2016 I have a pair of these. (modded already) Quote Link to comment Share on other sites More sharing options...
the_crayon_king Posted August 10, 2016 Author Share Posted August 10, 2016 Dogbones use surface mount chip unlike the rectangular NES which uses through hole. There's also a lot less space inside the controller. So the mod would be much more difficult to perform on a Dog Bone. Also Dog Bones are fairly uncommon and getting pricier, so I would rather see someone convert the old rectangle. Ive done both back to back (dogbone and regular nes) one is not harder than the other. I only harvest controllers that otherwise do not work. I have like 5 dogbones are they that rare ? Also it has a few SMD resistors but the chip on both is through hole. Quote Link to comment Share on other sites More sharing options...
