ColecoVision Motherboard replacement
colecovision motherboard F18a
50 replies to this topic
#1 Bmack36 OFFLINE
Bmack36
    Dragonstomper
  • 670 posts
Posted Thu Aug 11, 2016 5:50 PM
I am looking to put together a motherboard replacement and wanted to get some opinions on  a few things.
In order to keep costs low and reduce board size, the controller ports would be moved to the expansion port area. Ideally the SGM features could be impletemented, but if not an expansion port could be done internally and a SGM could be installed inside the system.
This board would only be F18a compatible so only VGA output would be available (although an off the shelf converter would fit inside with the extra room to convert to HDMI).
The board would include new power reset switch functionality.
The attached picture shows a rough first pass at the PCB, Some stock images from the motherboard have been superimposed to give a general idea of where components would go.
Is not Having the expansion port in the front a deal breaker for most or does this seem like it could be a solution for those looking for a replacement.
All feedback is welcome.
Thanks
#2 Jinks OFFLINE
Jinks
  • 4,678 posts
Posted Thu Aug 11, 2016 6:50 PM
Yup thats all I need. Can fit in a stock housing? Price 200 or less. I will buy 2.
#3 Bmack36 OFFLINE
Bmack36
    Dragonstomper
  • 670 posts
Posted Thu Aug 11, 2016 6:58 PM
This is still very early in the development so it will be a little while before something is available. I really just wanted to get some feedback on moving the controller ports to the front and whether people would like that or if it would be a deal breaker.
The idea of the motherboard was to be a drop in replacement with no modification to the case.
#4 fiddlepaddle OFFLINE
fiddlepaddle
  • 2,520 posts
Posted Thu Aug 11, 2016 7:55 PM
Be nice to be able to use simpler power supply than CV stock.
#5 Bmack36 OFFLINE
Bmack36
    Dragonstomper
  • 670 posts
Posted Thu Aug 11, 2016 7:59 PM
The new board would use a standard 5V power supply.
#6 phattyboombatty OFFLINE
phattyboombatty
  • 1,184 posts
Posted Thu Aug 11, 2016 10:52 PM
Adding a native cpu pause switch would be highly desirable. Of course, I wish there were a way to signal it via the hand controller.
#7 Pixelboy OFFLINE
Pixelboy
  • 8,213 posts
Posted Fri Aug 12, 2016 3:50 AM
Well, if you're going to move the ports to the front, perhaps you could just make a custom casing for it, instead of making it a replacement board. Then you'd have more control over where the TV output and power plug would be located. Also, including the SGM's components may not sit well with Opcode Games...
Nice project, though. :)
#8 Bmack36 OFFLINE
Bmack36
    Dragonstomper
  • 670 posts
Posted Fri Aug 12, 2016 4:17 AM
SGM wouldn't be included unless authorized by opcode, which is unlikely. Putting a legit full SGM inside the case would be the more likely outcome for SGM support. A new casing would be nice, but molds are expensive.
#9 Bmack36 OFFLINE
Bmack36
    Dragonstomper
  • 670 posts
Posted Fri Aug 12, 2016 5:21 AM
The board would support a pause button input. It might also use the reset button for pause functionality as well.
I think there could be a way to implement the pause or reset over controller but would either require a modded controller or losing super action controller functionality. Maybe a switch could be installed to go from super action control to reset mode.
#10 TPR OFFLINE
TPR
  • 2,215 posts
Posted Fri Aug 12, 2016 10:02 AM
For me personally, this is what I would be looking for....
 - A new motherboard that easily drops in place of the current one.
 - Has all the same functionality as the current board but with the following new features:
 - F18A compatibility (either built right in or easily added to the board without soldering)
 - New power supply
 - VGA output (for use with the F18A)
I would prefer to keep the controller ports and expansion ports in the same place.
Again, this is just my personal preferences, and I don't expect anyone to make something based around this, so I'm open to seeing what ends up being developed!
#11 Ikrananka OFFLINE
Ikrananka
  • 3,040 posts
Posted Mon Aug 15, 2016 4:32 PM
 - New power supply
I'm in agreement with TPR here.  I would want something that can replace an existing board without losing functionality in a standard CV case, e.g. keep controller ports in same location and keep the expansion port.  Losing RF is not a problem for me.  VGA out via the F18A is a big bonus :)
Is a +5V only supply going to be enough for allowing the Roller Controller to still be powered?  I can't remember what voltages it need.
#12 Bmack36 OFFLINE
Bmack36
    Dragonstomper
  • 670 posts
Posted Mon Aug 15, 2016 4:47 PM
After some discussions, I think I am going to split this into 2 projects. The first would be a full size replacement with built in F18a and additional mods. The second would be a miniCV that would either fit in a flashback or custom case, although some extra funding would be necessary for a new case as the injection molding could run $5K+.
The roller controller runs off of 5V. The Roller controller would still plug into the standard power port and pull power from the new power supply. The only other voltage the could be used is 12V for the expansion module, but I am still going back and forth over whether to add support since it would need a seperate video output anyways.
#13 Ikrananka OFFLINE
Ikrananka
  • 3,040 posts
Posted Mon Aug 15, 2016 4:54 PM
The expansion module can be upgraded to output S-video using an Atari 2600 video mod board.  I just completed this for one of my Exp. Mod #1 units.
#14 Bmack36 OFFLINE
Bmack36
    Dragonstomper
  • 670 posts
Posted Mon Aug 15, 2016 4:56 PM
Yeah I was thinking that would work or a new board could be made to supply the power and clock signals to the EM1 through an edge connector interface similar to what the coleco is supplying.
#15 Bmack36 OFFLINE
Bmack36
    Dragonstomper
  • 670 posts
Posted Thu Aug 25, 2016 12:13 PM
I have been making some good progress. Getting close to ordering first prototype.
#16 Ikrananka OFFLINE
Ikrananka
  • 3,040 posts
Posted Thu Aug 25, 2016 1:48 PM
Thanks for the update.  Did you drop the 12V and clock signals to the expansion port?
#17 Bmack36 OFFLINE
Bmack36
    Dragonstomper
  • 670 posts
Posted Thu Aug 25, 2016 1:52 PM
Right now the 12V isn't implemented, but i will connect the 12V line from the original power connector in case I want to add a composite mod for EM1. The issue with EM1 for me is that it will no longer be a drop in replacement and will require a mod to the case to get the video out.
The expansion port should be fully wired (assuming the schematic is correct).
#18 Bmack36 OFFLINE
Bmack36
    Dragonstomper
  • 670 posts
Posted Thu Aug 25, 2016 1:54 PM
Right now this is just a first prototype to verify the standard colecovision functionality. The final board will have more features.
#19 Glen's Retro Show OFFLINE
Glen's Retro Show
    Chopper Commander
  • 210 posts
Posted Fri Aug 26, 2016 5:09 AM
Glad to see how nice its progressing
#20 Bmack36 OFFLINE
Bmack36
    Dragonstomper
  • 670 posts
Posted Fri Aug 26, 2016 6:33 PM
First prototype board has been ordered. Should get it in about 2 weeks.
#21 Jinks OFFLINE
Jinks
  • 4,678 posts
Posted Fri Aug 26, 2016 8:10 PM
That was fast.
#22 Unibonger420 OFFLINE
Unibonger420
    Combat Commando
  • 2 posts
Posted Sun Aug 28, 2016 6:53 PM
I'd be very interested in this if the price isn't horrible.   I love the idea of a board to fit into a flashback also.
My wishlist would be:
Sockets, sockets, sockets.  Things that can be replaced or wear out like the rom, or the controller chips, etc.
f18a support or built in
memory mod built in
pause button support or built in
I am in need of the expansion, though.  No VCS or SGM addons can be used,  and that is a kind of a dealbreaker on such a versatile console...
If we can build in the SGM internally it would be ok, i guess.
#23 ColecoDan OFFLINE
ColecoDan
  • 1,832 posts
Posted Sun Aug 28, 2016 8:07 PM
memory mod built in
I would think it would not be worth adding in SGM, just keep expansion support because if Opcode does come out with newer version of SGM then it wouldn't help that you build in the SGM and don't have an expansion port to use the new version.
#24 Bmack36 OFFLINE
Bmack36
    Dragonstomper
  • 670 posts
Posted Sun Aug 28, 2016 9:20 PM
Currently the plan is to include the expansion port, although EM1 may not be supported as that would require a mod to the colecovision case to output a second video connector.
#25 Ikrananka OFFLINE
Ikrananka
  • 3,040 posts
Posted Mon Aug 29, 2016 9:22 AM
Why do you need to output a second video connector from the CV case?  I have s-video modded one of my EM1 modules and drilled a hole for the video out in the EM1.
Also tagged with one or more of these keywords: colecovision, motherboard, F18a
