ColecoVision Motherboard replacement
colecovision motherboard F18a
50 replies to this topic
#26 Bmack36 OFFLINE
Bmack36
    Dragonstomper
  • 669 posts
Posted Mon Aug 29, 2016 11:27 AM
If a mod is made to take the video out of the EM1 itself, then the EM1 would be supported as well.
#27 Ikrananka OFFLINE
Ikrananka
  • 3,040 posts
Posted Mon Aug 29, 2016 11:30 AM
This is probably the simplest solution and one that is representative of the original CV/EM1 design.
So does that mean that you're now including 12V to the expansion port?
#28 Bmack36 OFFLINE
Bmack36
    Dragonstomper
  • 669 posts
Posted Mon Aug 29, 2016 11:44 AM
I haven't decided how I want to handle it yet. I could just wire up the 12V from the original power connector to the expansion port, or build in a boost circuit to get 12V from the new 5V input. Right now I am leaning towards using the original cv power for the 12V, but could be convinced otherwise.
#29 Ikrananka OFFLINE
Ikrananka
  • 3,040 posts
Posted Mon Aug 29, 2016 1:30 PM
Right now I am leaning towards using the original cv power for the 12V, ...
I think this is probably the best option.
#30 Bmack36 OFFLINE
Bmack36
    Dragonstomper
  • 669 posts
Posted Mon Aug 29, 2016 1:33 PM
Only down side to that implementation would be that you would have to disconnect the new 5V supply when you were using the EM1, since 5V from the new supply is going out to the original power connector to power the roller controller.
#31 TPR OFFLINE
TPR
  • 2,215 posts
Posted Mon Aug 29, 2016 10:30 PM
Is doing an AV out of the back of the CV unit for the EM1 a mod that you can offer a service for?
#32 Bmack36 OFFLINE
Bmack36
    Dragonstomper
  • 669 posts
Posted Tue Aug 30, 2016 7:23 AM
Yes I could offer that service. Might be able to do a DIY where all someone would need to do is drill the hole and plug in an adapter board. That might be a little cheaper then shipping the console back and forth.
#33 Ikrananka OFFLINE
Ikrananka
  • 3,040 posts
Posted Tue Aug 30, 2016 9:04 AM
To get the best video out of the EM1 it is necessary to tap directly into the video outputs from the Coleco clone TIA chip in the EM1.  These outputs do not reach the expansion port connector and so connections need to be made to the TIA directly.  This is why I am placing my s-video out from the side of the EM1.
I have found, on my modern displays that taking the video from the EM1 via the expansion port, and converting it to composite, results in a truly terrible picture on my modern LCD displays.  That said, there may be some modern displays where the image is better and conversely some where it will be worse.
I have found that using the Atari 2600 mod from electronicsentimentalities, wiring this directly to the clone TIA, and outputting S-Video results in a remarkably good picture and one that is infinitely better than RF and composite.
#34 Bmack36 OFFLINE
Bmack36
    Dragonstomper
  • 669 posts
Posted Mon Sep 5, 2016 1:51 PM
Got the boards in a day early. Lots of work to do now.
#35 Pixelboy ONLINE
Pixelboy
  • 8,213 posts
Posted Mon Sep 5, 2016 2:27 PM
Interesting developments indeed. :)
So what components will you be using for the CPU, the VDP and the sound chip?
#36 Bmack36 OFFLINE
Bmack36
    Dragonstomper
  • 669 posts
Posted Mon Sep 5, 2016 3:56 PM
CPU and sound chip will be NOS or salvaged. VDP is F18a only. F18a will be built into the board in future revisions. This is just a first rev to make sure there are no issues with the actual colecovision schematic before adding other mods.
#37 Bmack36 OFFLINE
Bmack36
    Dragonstomper
  • 669 posts
Posted Tue Sep 27, 2016 4:46 PM
Sorry for the lack of updates. I've been on vacation and had a couple things come up. The first board has been assembled and I am working through a few issues getting it going. I had an issue with the clock circuit and the reset circuit, but both of those have been fixed. Still an issue with the WR and IORQ lines not acting properly.
Edited by Bmack36, Tue Sep 27, 2016 4:55 PM.
#38 NIAD OFFLINE
NIAD
  • 6,242 posts
Posted Tue Sep 27, 2016 7:02 PM
Congrats on getting this far and good luck with completing this very welcome project.
A couple quick suggestions that I don't recall being mentioned:
- I would like to see all the chips socketed for easy replacement if the need arises.
- I would like to see the DB9 ports not soldered directly to the motherboard to remove these stress points when connecting controllers. Drillings 2 holes each to secure the DB9 ports at the end of ribbon cables to the case is easy enough.
I know that these points will add to the overall cost, but i'm sure many amongst us wouldn't mind the added cost or maybe these can be offered as options.
#39 Bmack36 OFFLINE
Bmack36
    Dragonstomper
  • 669 posts
Posted Tue Sep 27, 2016 9:33 PM
Thanks,
I was planning on using sockets on the final revision, but I wasn't concerned for this rev as it is going to change once I get the main colecovision functionality working.
I was planning on using a standard Right angle DB9 that used either screws or was soldered into the mounting holes to provide the strain relief to the board. That should relieve any stress issues during plugging and unplugging.
I could always provide a seperate connector for remote ports if required.
#40 ten-four OFFLINE
ten-four
    Dragonstomper
  • 916 posts
  • Here i am... again!
Posted Sun Oct 2, 2016 3:19 AM
Like others, I can only support this project.
I feel this project gonna be big.
:-D
When I look at your ColecoVision board, I can not locate the Sound output.
#41 Bmack36 OFFLINE
Bmack36
    Dragonstomper
  • 669 posts
Posted Sun Oct 2, 2016 5:12 AM
This revision is really just a test board to verify the colecovision functionality so it isn't completely finished.
The sound output is actually run to the connector in the bottom left corner that isn't populated.
#42 cdn2a OFFLINE
cdn2a
    Star Raider
  • 72 posts
Posted Wed Oct 5, 2016 11:44 AM
I really like this Idea!
If it were me, I'd add a spot for 2 x 7805's (TO-220) for input power regulation,
(I know, old school) and a 5 to 12v DC-DC converter (simple 4 holes on board) tied to 12v pin on the expansion slot.
​So you could have the possibility of running the whole shebang from one 9-15v powersupply.
​Nice thing is, it could be put on the board and not populated unless the user wanted to enable it,
to keep costs down.
#43 ApolloBoy OFFLINE
ApolloBoy
  • 5,750 posts
Posted Sun Oct 9, 2016 10:51 PM
That's awfully inefficient though, I like Bmack's idea of just running the entire system off a regulated 5V supply and then using a charge pump to get the 12V rail.
#44 Sparkoids OFFLINE
Sparkoids
    Space Invader
  • 20 posts
Posted Mon Oct 10, 2016 5:19 AM
This looks fantastic. Why not use as much surface mount as you can or (preferably) have dual thruhole / smt tracks on the board? It would easily be possible judging but the size of the PCB. I get that you are prototyping which is fine but if the F-18 is due to be possibly directly mounted on your board then it would make a lot of sense. Just a thought.
Great work either way!
#45 cdn2a OFFLINE
cdn2a
    Star Raider
  • 72 posts
Posted Mon Oct 10, 2016 7:54 AM
I agree it's terribly inefficient.
BTW we do agree on making 12v from 5.
I believe the most durable console out there is the NES. Look at the power input circuit. You can feed it almost anything, and people do.
The coleco with it's funny RAM is one of the least durable.
If you have a barrel input, to the console, expecting a regulated input, what happens when someone plugs in something that doesnt belong?
I know its user error, but why make the same mistakes?
I also agree its fantastic work. This will hopefully preserve a few more consoles for future gamers. They're not making em anymore. ;)
Edited by cdn2a, Mon Oct 10, 2016 7:57 AM.
#46 CMR OFFLINE
CMR
    Space Invader
  • 45 posts
Posted Mon Oct 17, 2016 10:02 PM
Cool project.  Are you still planning to make a board that will fit the Flashback console?
#47 Bmack36 OFFLINE
Bmack36
    Dragonstomper
  • 669 posts
Posted Mon Oct 17, 2016 10:10 PM
I think the flashback board would probably be on hold. I would think it would need an integrated atarimax and SGM since there is no cutout for the cartridge or expansion ports. Probably best to stick with the Ultimate CV flashback for the near future.
Motherboard Update:
Working on a new rev of the board. Found a couple of issues that need to be addressed and test points added to make debugging easier.
#48 ApolloBoy OFFLINE
ApolloBoy
  • 5,750 posts
Posted Tue Oct 18, 2016 5:41 PM
You could also go with a mini or micro USB connector. There wouldn't be any problems with plugging in the wrong PSU and you could power it from just about any USB charger or even a power bank.
#49 eightbit OFFLINE
eightbit
  • 3,455 posts
Posted Tue Nov 22, 2016 3:27 PM
Great job so far! But, for the love of all things holy please do not use a microUSB connector for power! They are simply too delicate in my opinion. They are used on other projects (such as the MiST computer) and are prone to breaking quite easily. I never experienced it with that device but other people have (and I have had these break on other devices). Barrel plug all the way....or USB type B if you want to go with something sturdy that people cannot accidentally plug something wrong into. Best of both worlds :)
Edited by eightbit, Tue Nov 22, 2016 3:40 PM.
#50 Bmack36 OFFLINE
Bmack36
    Dragonstomper
  • 669 posts
Posted Wed Nov 30, 2016 6:07 PM
Just an Update:
Motherboard replacement is on hold. A different board is in the works that hopefully will be better ;) . I'll try and give more details when it gets a little further along.
Also tagged with one or more of these keywords: colecovision, motherboard, F18a
