sometimes99er Posted August 29, 2016 Share Posted August 29, 2016 And his kind of optimization needs to wait until the very last steps. Yes, you have to find flexibility that suits you. I draw and rearrange characters in graphic oriented programs (like Magellan) and export to XB. I then go back to the graphic file for any changes. I ran your program. Made a memory dump using F10 in Classic99. Imported the graphics and exported XB code as you saw it. 1 Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted August 29, 2016 Share Posted August 29, 2016 (edited) Not my fault, his patterns are scattered all around. Ideally you'd want to stack your patterns in a more efficient manner, which as he's indicated, is something for the future. Well, my fault then for rearranging his patterns then. Oh, I didn't. Not my fault TI chose to have DATA as a token but not CALL CHAR. Edited August 29, 2016 by sometimes99er 1 Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted August 29, 2016 Author Share Posted August 29, 2016 LOL, Yeah guys. First, I had to be very careful, I nearly ran out of char codes and sprite numbers for that matter, then I realized I needed numbers so I have to split my char codes up to open up a gap to leave the numbers alone. Oh it was crazy. Here's a breakdown of some of the things that I keep in a running "reference" file as I code... sprites used up = 1 to 25 (PUSHING 27 WITH 2 FOR MELEE ATTACKS) - 28 max. L1-YP=9 (START) Hole spr#2 L2-33 Hole spr#3 - 2/3 - 10/11 L3-57 Hole spr#4 - 4/5 - 12/13 L4-81 Hole spr#5 - 6/7 - 14/15 L5-105 Hole spr#6 - 8/9 - 16/17 L6-129 Hole spr#7 - 10/11 - 18/19 L7-153 Hole spr#8 - 12/13 - 20/21 G-177 - No Hole Location GRND-3,(HLE*+1 OR = LastHLE - 14/15 - 22/23 Level Pixel borders = 7 and 240 display at (22,15):xp CAL #2-#8 - holes tHIS IS HOW THE CHARS NEED TO BE 33-38 rr = 6 patterns 39-43 sjr = 5 pat 44 = idle 64-67 jr = 4 pat 68-69 lr = 2 pat 70-75 rl = 6 pat 76-80 sjl = 5 pat 81-84 jl = 4 pat 85-86 ll = 2 pat (0-9)=48-57 dim default(91) for deflt=33-124 get pat( LO0T(2,14) CHAR SPRITE# z3d=(2,14) for ms=-4 to -50 call sound(20,ms,0) next ms char codes and color groups in use 33-43 & 57-73:running jumping man. Color groups:1,2 & 5,6,7 FOR CHRR=33-38/1 !setup for creating running characters right FOR CHSR=39-43/1,2 !setup for creating stop and jump characters right FOR CHJR=64-67/5 !setup for creating jumping characters right *FOR CHLR=68-69/5 !setup for creating landing characters right left running*********************** FOR CHRL=76-80/6,7 !setup for creating running characters left FOR CHSL=81-80/6 !setup for creating stop and jump characters left FOR CHJL=81-84/7 !setup for creating jumping characters left FOR CHLL=85-86/7 !setup for creating landing characters left 44=idle CG:2 45=MAN MELEE ATTACK 46=MAN RANGED LEFT 47=MAN RANGED RIGHT nUMBER 0-9 = 48-57 = 3,4 88:heart. Color groups:8 COLOR:7 96:zombie. color groups:9 (up to 8 zombies difficulties) COLOR:4 104:bad girder. Color groups:10 color 15 105:girder. color group 10 color 15 106:the hole. color group 10 color 1 assigned via callsprite 107:the exit. Color groups:10 color 15 112:melee weapon. Color groups:11 COLOR:8 113:ranged weapon. Color groups:11 COLOR:8 DELETE 33-39: Numbers 0-6 Color Group 1 Color: 12 DELETE 128-130: numbers 7-9 Color Group 13 Colot:12 120-122: score char color group 12 color 12 123: X for hearts, melee and ranged. color group 12 color 12 124:EXit char. 11 8 142:BULLET 143:Melee weapon attack 16,12 ********Sprites****** #1 - MAN #2-#8 - holes #9 - exit #10-#23 OLDSLOT (loot) #24/27 for melee weapon atttack or #26 for bullet. Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted August 29, 2016 Author Share Posted August 29, 2016 (edited) Maybe one of you advanced programmers could make a notepad++ plugin that copy/insert all lines that start with ! to their matching line numbers in a second document? Pushing down the existing contents starting from top and going down.Basically, an automatic way to reinsert comments when you have two docs open side by side. The line numbers I refer to above are the internal line numbers of notepad++ not XB line numbers that have been resequenced. That's basically what I'm doing right now, manually, line by line. It's very tedious and time consuming and monotonous. Edited August 29, 2016 by Sinphaltimus Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted August 30, 2016 Share Posted August 30, 2016 (edited) Note, I use UltraEdit, but understand (googling) that Notepad++ can do the same.1. In column mode insert a special word before all lines in the program file. Do a column mode selection of the entire contents of the program file (you should see a rectangular area). Copy.2. Add space characters to the end of the first line of the comment file until it is longer than the longest line in that file. Paste (the above) after the spaces added.3. Replace the special word with the escape code(s) for "newline". Done.You will need to set the "Search Mode" to "Extended", so that Notepad++ honors escape codes. "\r\n" is the escape code for carriage-return, the standard for new lines in Windows. Unix-style systems use simply \n (newline). Most IDEs, Notepad++ included, will understand both styles and portray them each with new lines, but core Windows utilities do not understand \n as being equivalent to \r\n, so the latter is usually the most appropriate if the file is intended to be used in Windows environments.Example using UltraEdit Edited August 30, 2016 by sometimes99er 1 Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted August 30, 2016 Author Share Posted August 30, 2016 (edited) Note, I use UltraEdit, but understand (googling) that Notepad++ can do the same. 1. In column mode insert a special word before all lines in the program file. Do a column mode selection of the entire contents of the program file (you should see a rectangular area). Copy. 2. Add space characters to the end of the first line of the comment file until it is longer than the longest line in that file. Paste (the above) after the spaces added. 3. Replace the special word with the escape code(s) for "newline". Done. You will need to set the "Search Mode" to "Extended", so that Notepad++ honors escape codes. "\r\n" is the escape code for carriage-return, the standard for new lines in Windows. Unix-style systems use simply \n (newline). Most IDEs, Notepad++ included, will understand both styles and portray them each with new lines, but core Windows utilities do not understand \n as being equivalent to \r\n, so the latter is usually the most appropriate if the file is intended to be used in Windows environments. Example using UltraEdit Wow, OK, I'm going to have to get this going ASAP! EDIT upon closer inspection, I'm not so sure this would work. In your example, it's every other line and the left side is all comments and the right is all code. For me, it would be left side is code and comments (not as clean as every other line) and the right side is code no comments. What I'm looking for is a pluggin type function that could scan the left doc and locate all lines starting with ! then insert them over to the right side text to the appropriate location and carriage return. Here's how I see it working line by line. Code starts at left, line 1 = blank = skip line 2 does not start with !, skip line 3 has exclamation, copy line 3, insert at beginning of line 3 right side text document, carriage return at end of inserted line. Return to document on left and continue. Edited August 30, 2016 by Sinphaltimus Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted August 31, 2016 Share Posted August 31, 2016 (edited) Gave it some thought. One could do as you suggest (plugin, macro, script or something) but it looks like a bit of a time-consuming detour for me, but perhaps also a nice learning experience. Anyways ... If the comments are important, then I suggest a working routine with changes made to the source text-file (no typing in XB). Any change (one line or a chunk) copied to Classic99. Of course Classic99 already having the latest version (either by pasting all of the source or having loaded a previously saved version). Well, that's how I do it with XB. Edited August 31, 2016 by sometimes99er Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted August 31, 2016 Author Share Posted August 31, 2016 (edited) Yeah, I ventured in to their plugin building and went through their existing plugins. Not very helpful on the first run but there are plugins with comparison features that highlight differences. I'm thinking I might be able to play with something like that then edit it. I just need to find out what kind of code is used to identify certain parts and then figure out if there are any copy paste commands and how much and what kind of control is available for that sort of function. When I get bored. I made a lot of progress last night in getting ranged weapons to work. So I'm more focused on getting this game done than plugins. Edited August 31, 2016 by Sinphaltimus Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted August 31, 2016 Share Posted August 31, 2016 You could write an XB program. Have two input files and one output open at the same time. Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted August 31, 2016 Author Share Posted August 31, 2016 You could write an XB program. Have two input files and one output open at the same time. Not there yet. My experience keeps me contained in one simple xb program. The disk controller manual gave me a head ache trying to understand opening files for input and such. I know it's relatively simple for most but I'm not there yet. Someday... Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted August 31, 2016 Author Share Posted August 31, 2016 I just killed my first Zombie with a ranged weapon. It was great. I screamed like a lunatic. I need to test more but a new version is coming shortly. Hopefully tonight some time. 1 Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted August 31, 2016 Author Share Posted August 31, 2016 (edited) NEW VERSION 0.33 - >>CLICK HERE<< TO GET IT! *Zip file contains BASIC code in text (with comments) and Classic99 disk file. GAME IS CURRENTLY EARLY ACCESS ALPHA version. No ETA on Beta. How To Play: About: This is meant to be a semi casual zombie survival game to escape a skyscraper. Play for high score. Combat: A melee attack is a swing attack that covers the space directly in front and behind the player. You get one attack per inventory item. Joystick down = ranged attack. ZEDS: Will grab you and attack you. Hold a direction to escape, try hitting with melee, break away as fast as you can. DODGE: You can attempt to dodge zeds by jumping past them (joystick button or J) LOOTING: Will slow you down, jump past it to dodge the loot if you need to (for future versions when Zombies run) Controls: X=Quit, R=Reset, J and Controller Button = Jump, Joystick Left/Right moves left/right, Joystick up = melee attack - Notes: Melee attacks will destroy loot including hearts. Don't mash the jump button, press and hold. It is possible to run over holes or run past loot without picking it up. Technically it's a COINC detection issue. I call it a feature. Looting while running? You're gonna miss a thing or two. Running over a hole? It's just a high risk jump. The crumbling floor on each side of the hole? Be careful of loose gravel, you can slip and fall. Backstory: It's the zombie apocalypse. Hordes of the living dead are roaming the streets, you hear a helicopter and climb the tallest building level by crumbling level. You get to the roof and just as you make it to the end, the roof door is barred and you hear the helicopter motors fading in to the distance. Then you hear another sound. The sound of the dead creeping in and closer. They must have followed you. Now, it's time to get out. Escape to the ground floor street level. Good Luck. V033 changes: Added ranged weapon attacks Added more sounds Add to Notes: Don't spam the jump button, just hold it down. Cleaned up all code comments and recoded an bunch of mistakes. To Do Next: Replace temp zombi health with per sprite health. right now they share 2hps and it gets reset to 2 at each death. Create basic zombie AI and animate. Session high score display between level progressions and at end of game. Regain sprite by not using sprite for level exit. Adjust range of ranged weapon to not hit at close range. Rely on melee for that. KNOW ISSUES: There are no known bugs at time of upload. There are performance issues. The code is bloated. A lot of fluff and stuff. I needed it this way to hunt bugs. I will optimize the code in a later version. Not all functionality or game mechanics have been developed as of this version. To Do Long Term: Title screen. Sounds Music. Loot balancing with board progression. (game balancing) zombie difficulty linked to board progression. At least 2 more types of ever more difficult zombies. A lot of code optimizing. 100 SCORE=0000 :: HEALTH=10 :: BOARD=1 :: HSCORE=0 !weapons inventory 110 MELEE=0 :: RANGED=0::bull=8 120 CALL SCREEN(2) 130 CALL COLOR(10,15,1):: CALL COLOR(12,12,1):: CALL COLOR(3,12,1):: CALL COLOR(4,12,1) 140 CALL COLOR(8,7,1):: CALL COLOR(11,8,1):: CALL COLOR(14,12,1):: HCLR=1 150 CALL CLEAR !running patterns right 160 DATA 1818101010101018,1818183C1C142630,181A3C5E1A334060,18197E981C724100,18197E9818147243,1818385E581C2436 !stop and jump right 170 DATA 1818101010101018,000C1C3058081018,00000C1C305C1C18,0000060E183C0C18,0003070C18081018 !jumping right 180 DATA 0303040609081010,1818141810106000,1818103810180C00,1818503010180404 !landing right 190 DATA 0018183050180818,1818101038501018 !running patterns left 200 DATA 1818080808080818,1818183C3828640C,18583C7A58CC0206,18987E19384E8200,18987E1918284EC2,18181C7A1A38246C !stop and jump left 210 DATA 1818080808080818,0030380C1A100818,000030380C3A3818,00006070183C3018,00C0E03018100818 !jumping left 220 DATA C0C0206090100808,1818281808080600,1818081C08183000,18180A0C08182020 !landing right 230 DATA 0018180C0A181018,181808081C0A0818 !setup for creating running characters right 240 FOR CHRR=33 TO 38 250 READ PAT$ 260 CALL CHAR(CHRR,PAT$) 270 NEXT CHRR !setup for creating stop and jump characters right 280 FOR CHSR=39 TO 43 290 READ PAT$ 300 CALL CHAR(CHSR,PAT$) 310 NEXT CHSR !setup for creating jumping characters right 320 FOR CHJR=64 TO 67 330 READ PAT$ 340 CALL CHAR(CHJR,PAT$) 350 NEXT CHJR !setup for creating landing characters right 360 FOR CHLR=68 TO 69 370 READ PAT$ 380 CALL CHAR(CHLR,PAT$) 390 NEXT CHLR ! left running*********************** !setup for creating running characters left 400 FOR CHRL=70 TO 75 410 READ PAT$ 420 CALL CHAR(CHRL,PAT$) 430 NEXT CHRL !setup for creating stop and jump characters left 440 FOR CHSL=76 TO 80 450 READ PAT$ 460 CALL CHAR(CHSL,PAT$) 470 NEXT CHSL !setup for creating jumping characters left 480 FOR CHJL=81 TO 84 490 READ PAT$ 500 CALL CHAR(CHJL,PAT$) 510 NEXT CHJL !setup for creating landing characters left 520 FOR CHLL=85 TO 86 530 READ PAT$ 540 CALL CHAR(CHLL,PAT$) 550 NEXT CHLL !BAD girder for level HOLE creation 560 BGIR$="3C4426D999A5C3FF" !GIRDER FOR LEVELS 570 GIR$="FFC3A59999A5C3FF" !girder for level creation 580 CALL CHAR(104,BGIR$,105,GIR$) !THE HOLE 590 GRAV$="FFFFFFFFFFFFFFFF" :: CALL CHAR(106,GRAV$) !THE EXIT 600 EXT$="1F1111111D11111F" :: CALL CHAR(107,EXT$) !THE HEART 610 HRT$="66FFFFFF7E7E3C18" :: CALL CHAR(88,HRT$) !THE ZED 620 ZED$="3C2418FF9918183C" :: CALL CHAR(96,ZED$) !MELEE 630 MLE$="C0E0703A1E0C1A01" :: CALL CHAR(112,MLE$) !RANGED WEAPONS 640 RNG$="000000FF7F1E1606" :: CALL CHAR(113,RNG$) !Word Score 650 SCTXT1$="70808063141414E3" :: SCTXT2$="00000000334A4A32" :: SCTXT3$="00000000993C2118" 660 CALL CHAR(120,SCTXT1$):: CALL CHAR(121,SCTXT2$):: CALL CHAR(122,SCTXT3$) ! the letter X remain for GUI 670 EXTXT$="0044442810284444" :: CALL CHAR(123,EXTXT$) ! EX TEXT IN GUI 680 LVLTXT$="E0E080E9EF86EFE9" :: CALL CHAR(124,LVLTXT$) !***IDLE MAN 690 IDLE$="3838107CBA38286C" :: CALL CHAR(44,IDLE$) ! MELEE & l/r RANGED ATTACKS 700 MMELE$="3C3C18FF7E3C183C" :: MRNGL$="0C0C04FC4C3C286C" :: MRNGR$="3030203F323C1436" !WEAPONS FIRE 710 MWA$="002418FF1824" :: BULET$="0000008" !ZED IDLE&WALK LEFT 720 ZDI$="3C2418FF9918183C" :: ZDA$="3CA5DB7E1818183C" :: ZWL1$="3C2C18F81838246C" :: ZWL2$="3C2C18F818181838" !ZED WALK RIGHT 730 ZWR1$="3C34181F181C2436" :: ZWR2$="3C34181F1818181C" !MAN ATTTACKS 740 CALL CHAR(45,MMELE$,46,MRNGL$,47,MRNGR$) !WEAPONS FIRE 750 CALL CHAR(143,MWA$,142,BULET$) 760 RANDOMIZE !STARTING SPRITE NUMBER FOR LOOT and more 770 SLOT=10 780 OPTION BASE 1 !LOOT DISTRIBUTION AND COLLISION. 790 DIM LO0T(3,14) !LOOT ARRAY COORDS COL 800 LTN=1 !LOOT ARRAY COORDS ROW 810 LAB=1 !START ground level on top girder (YP+8pixels), LEVEL AND SPRITE HOLE # 820 SHL=2 :: GRND=17 !start pos,vel,controller run speed 830 LVL=3 :: YP=9 :: XP=8 :: RS=0 :: CS=16 :: RSPD=2.0 :: RSPDD=3.3 !default health of zombies start of game 840 ZHELTH=2 !*******************************Create Level 850 GOSUB 1960 !***************************************Create Sprite Idle******** !**********wall collision checks 860 CALL SPRITE(#1,44,6,YP,XP):: GOSUB 5160 !check for joystick input 870 CALL JOYST(1,JX,JY):: 880 CALL KEY(1,K,S):: IF K=0 AND S=-1 THEN 7300 885 IF K=6 THEN 890 ELSE 900 890 CALL DELSPRITE(ALL):: RESTORE 160 :: GOTO 100 ! check for combat 900 IF JY=0 THEN 920 ELSE 910 ! goto combat 910 GOSUB 7210 920 IF JX=0 THEN 960 !**********wall collision checks 930 GOSUB 5160 940 CALL COINC(ALL,C):: IF C=0 THEN 960 !****************************collision checks 950 GOSUB 2170 !no kb pressed check for joyst 960 CALL KEY(1,K,S):: IF K<>18 AND K<>74 AND K<>106 THEN 1500 ! ********jump routine check******** 970 CALL MOTION(#1,0,0) 980 IF CS<>-16 THEN 1020 !get new position for next sprite 990 CALL POSITION(#1,YP,XP) ! goto jump left 1000 GOSUB 1060 1010 GOTO 860 1020 IF CS<>16 THEN 1500 1030 CALL POSITION(#1,YP,XP) !get new position for next sprite !goto jump right************************** 1040 GOSUB 1280 1050 GOTO 860 !*************jump left routine********* !joystick button pressed so STOP running 1060 CS=0 :: CALL MOTION(#1,0,CS) !recreate sprite1 as stop and jump characters 1070 CALL SPRITE(#1,CHSL,6,YP,XP) !setup stop and jump animation lef 1080 FOR PT=76 TO 80 1090 CALL SOUND(1,191-PT,5) !ANIMATE 1100 CALL PATTERN(#1,PT) !continue animating the stop and jump until done 1110 NEXT PT !get new postion for animating the jumping 1120 CALL POSITION(#1,YP,XP) 1130 IF XP<=24 THEN 1210 !jumping left 1140 CS=-20 :: YP=YP-3 :: RS=0 :: CALL SPRITE(#1,CHJL,6,YP,XP,RS,CS) 1150 FOR PT=81 TO 84 1160 CALL PATTERN(#1,PT):: CALL SOUND(1,110+PT,5) 1170 NEXT PT !stop motion at end of jumping animation to begin landing animation. 1180 CS=0 :: CALL MOTION(#1,0,CS) !get new position for starting landing animation. 1190 CALL POSITION(#1,YP,XP) !RESET YP TO BE GROUND. 1200 YP=YP+3 1210 CALL SPRITE(#1,CHLL,6,YP,XP) !setup landing animation left 1220 FOR PT=85 TO 86 1230 CALL PATTERN(#1,PT):: CALL SOUND(1,200-PT,5) ! continue landing animation until last frame 1240 NEXT PT !get new position for next sprite 1250 CALL POSITION(#1,YP,XP) 1260 CS=-16 1270 RETURN !*************jump right routine****** !joystick button pressed so STOP running right 1280 CS=0 :: CALL MOTION(#1,0,CS) !recreate sprite1 as stop and jump characters right 1290 CALL SPRITE(#1,CHSR,6,YP,XP) !setup stop and jump animation right 1300 FOR PT=39 TO 43 1310 CALL SOUND(1,191-(PT+37),5) 1320 CALL PATTERN(#1,PT) !continue animating the stop and jump until done right 1330 NEXT PT !get new postion for animating the jumping right 1340 CALL POSITION(#1,YP,XP) 1350 IF XP>=224 THEN 1430 !jumping right 1360 CS=20 :: YP=YP-3 :: CALL SPRITE(#1,CHJR,6,YP,XP,RS,CS) !setup jumping characters right 1370 FOR PT=64 TO 67 1380 CALL PATTERN(#1,PT):: CALL SOUND(1,110+(PT+13),5) 1390 NEXT PT !stop motion at end of jumping animation to begin landing animation. 1400 CS=0 :: CALL MOTION(#1,0,CS) !get new position for starting landing animation. 1410 CALL POSITION(#1,YP,XP) 1420 YP=YP+3 1430 CALL SPRITE(#1,CHLR,6,YP,XP) !setup landing animation 1440 FOR PT=68 TO 69 1450 CALL PATTERN(#1,PT):: CALL SOUND(1,191-(PT+11),5) ! continue landing animation until last frame 1460 NEXT PT !get new position for next sprite 1470 CALL POSITION(#1,YP,XP) 1480 CS=16 1490 RETURN ! **************Check Joyst Options************ 1500 IF JX<>0 THEN 1530 1510 CALL MOTION(#1,0,0) 1520 GOTO 860 ! ********running check*************** 1530 IF JX<>-4 THEN 1550 1540 GOSUB 1770 1550 IF JX<>4 THEN 860 1560 GOSUB 1580 !after RETURN goto joyst check 1570 GOTO 860 ! ************run right routine******** !create the runner and send running 1580 CALL POSITION(#1,YP,XP):: CS=16 :: CALL SPRITE(#1,CHRR,6,YP,XP,0,JX*RSPD) !setup for animating the run right 1590 FOR PT=33 TO 38 STEP 2 1600 CALL PATTERN(#1,PT):: CALL SOUND(1,-2,5) !jump 1610 CALL KEY(1,K,S):: IF K=18 OR K=74 OR K=106 THEN 970 !check for joystick input 1620 CALL JOYST(1,JX,JY) !**********wall collision checks 1630 GOSUB 5160 !collision actions 1640 CALL COINC(ALL,C):: IF C=0 THEN 1650 1645 CALL MOTION(#1,0,(JX*RSPD)/RSPDD):: GOSUB 2170 1650 IF JY=0 THEN 1670 ELSE 1660 1660 GOSUB 7210 !not joy pressed keep running 1670 IF JX<>0 THEN 1690 ELSE 1680 1680 CALL POSITION(#1,YP,XP):: CALL MOTION(#1,0,0):: CALL SPRITE(#1,44,6,YP,XP):: RETURN 1690 CALL JOYST(1,JX,JY) 1700 IF JX=4 THEN 1720 1710 IF JX=-4 THEN 1760 1720 CALL MOTION(#1,0,JX*RSPD) 1730 NEXT PT 1740 IF JX=4 THEN 1590 !check position and store before stopping motion 1750 CALL POSITION(#1,YP,XP) 1760 RETURN !**********run left routine************** !create the runner and send running 1770 CALL POSITION(#1,YP,XP):: CS=-16 :: CALL SPRITE(#1,CHRL,6,YP,XP,0,JX*RSPD) !setup for animating the run left 1780 FOR PT=70 TO 75 STEP 2 1790 CALL PATTERN(#1,PT):: CALL SOUND(1,-2,5) !jump 1800 CALL KEY(1,K,S):: IF K=18 OR K=74 OR K=106 THEN 970 !check for joystick input 1810 CALL JOYST(1,JX,JY) !**********wall collision checks 1820 GOSUB 5160 !collision actions 1830 CALL COINC(ALL,C):: IF C=0 THEN 1840 1835 CALL MOTION(#1,0,(JX*RSPD)/RSPDD) 1837 GOSUB 2170 1840 IF JY=0 THEN 1860 ELSE 1850 1850 GOSUB 7210 !not joy pressed keep running 1860 IF JX<>0 THEN 1880 1870 CALL POSITION(#1,YP,XP):: CALL MOTION(#1,0,0):: CALL SPRITE(#1,44,6,YP,XP):: RETURN 1880 CALL JOYST(1,JX,JY) 1890 IF JX=-4 THEN 1910 1900 IF JX=4 THEN 1950 1910 CALL MOTION(#1,0,JX*RSPD) 1920 NEXT PT 1930 IF JX=-4 THEN 1780 !check position and store for next sprite 1940 CALL POSITION(#1,YP,XP) 1950 RETURN !*************************************************************************level creation************************ !*************************gui creation****** 1960 GOSUB 5230 1970 HLE=INT((RND*15)+5) 1980 FOR LVL=1 TO 8 1990 IF LVL=1 THEN 2010 !*************************************GOSUB********LOOT DS********** 2000 GOSUB 4810 !LEFT WALL 2010 CALL VCHAR(1,1,105,24) !RIGHT WALL 2020 CALL VCHAR(1,32,105,24) !LEFT SIDE GIRDERS 2030 CALL HCHAR(LVL*3,1,105,HLE-1) !HOLE PROPER 2040 IF LVL=8 THEN 2060 2045 CALL SPRITE(#SHL,106,HCLR,GRND-8,(HLE* +1) !ADVANCE SPRITE # 2050 SHL=SHL+1 !RIGHT SIDE Girders 2060 LASTHLE=(HLE* +1 :: CALL HCHAR(LVL*3,HLE+3,105,32-(HLE+3)) !CRUMBLE LEFT SIDE 2070 IF LVL=8 THEN 2130 2075 CALL HCHAR(LVL*3,HLE,104) !crumble right side 2080 CALL HCHAR(LVL*3,HLE+2,104) 2090 GRND=GRND+24 !NEW LOCATION FOR HOLE 2100 HOL=INT((RND*15)+5) !NOT EQUAL TO PREVIOUS HOLE 2110 IF HOL=HLE THEN 2100 !SET PROPER HOLE VARIABLE 2120 HLE=HOL !GO CREATE NEXT LEVEL 2130 NEXT LVL ! THE EXIT 2140 CALL SPRITE(#9,107,15,22*8,30* !THE FLOOR 2150 CALL HCHAR(24,1,105,31) 2160 RETURN ! *********************************collision detection routines******* !**********wall collision checks 2170 GOSUB 5160 2180 CALL POSITION(#1,YP,XP) ! top level 1 2190 IF YP<>9 THEN 2220 2200 CALL COINC(#1,#2,8,C) !check for hole level 1 2210 IF C=0 THEN RETURN ELSE 4780 !level 2 2220 IF YP<>33 THEN 2570 2230 CALL POSITION(#3,HY,HX):: LOOT=LO0T(1,1) 2240 CALL POSITION(#1,YP,XP) 2250 IF XP<=HX THEN 2260 ELSE 2400 2260 CALL COINC(#1,#10,8,C) 2270 IF C<>0 THEN 2310 2280 CALL COINC(#1,#3,8,C) !check for hole level 2 2290 IF C<>0 THEN 4780 2300 RETURN 2310 DET=10 2320 IF LOOT<>88 THEN 2340 !do heart 2330 GOTO 4740 2340 IF LOOT<>96 THEN 2360 !do zed 2350 GOTO 4710 2360 IF LOOT<>112 THEN 2380 !do melee 2370 GOTO 4680 2380 IF LOOT<>113 THEN RETURN ! do ranged 2390 GOTO 4650 2400 LOOT=LO0T(1,2) 2410 CALL POSITION(#1,YP,XP) 2420 IF XP>HX THEN 2430 ELSE RETURN 2430 CALL COINC(#1,#11,8,C) 2440 IF C<>0 THEN 2480 2450 CALL COINC(#1,#3,8,C) !check for hole level 2 2460 IF C<>0 THEN 4780 2470 RETURN 2480 DET=11 2490 IF LOOT<>88 THEN 2510 !do heart 2500 GOTO 4740 2510 IF LOOT<>96 THEN 2530 !do zed 2520 GOTO 4710 2530 IF LOOT<>112 THEN 2550 !do melee 2540 GOTO 4680 2550 IF LOOT<>113 THEN RETURN ! do ranged 2560 GOTO 4650 !level 3 2570 IF YP<>57 THEN 2920 2580 CALL POSITION(#4,HY,HX):: LOOT=LO0T(1,3) 2590 CALL POSITION(#1,YP,XP) 2600 IF XP<=HX THEN 2610 ELSE 2750 2610 CALL COINC(#1,#12,8,C) 2620 IF C<>0 THEN 2660 2630 CALL COINC(#1,#4,8,C) !check for hole level 3 2640 IF C<>0 THEN 4780 2650 RETURN 2660 DET=12 2670 IF LOOT<>88 THEN 2690 !do heart 2680 GOTO 4740 2690 IF LOOT<>96 THEN 2710 !do zed 2700 GOTO 4710 2710 IF LOOT<>112 THEN 2730 !do melee 2720 GOTO 4680 2730 IF LOOT<>113 THEN RETURN ! do ranged 2740 GOTO 4650 2750 LOOT=LO0T(1,4) 2760 CALL POSITION(#1,YP,XP) 2770 IF XP>HX THEN 2780 ELSE RETURN 2780 CALL COINC(#1,#13,8,C) 2790 IF C<>0 THEN 2830 2800 CALL COINC(#1,#4,8,C) !check for hole level 3 2810 IF C<>0 THEN 4780 2820 RETURN 2830 DET=13 2840 IF LOOT<>88 THEN 2860 !do heart 2850 GOTO 4740 2860 IF LOOT<>96 THEN 2880 !do zed 2870 GOTO 4710 2880 IF LOOT<>112 THEN 2900 !do melee 2890 GOTO 4680 2900 IF LOOT<>113 THEN RETURN ! do ranged 2910 GOTO 4650 !level 4 2920 IF YP<>81 THEN 3270 2930 CALL POSITION(#5,HY,HX):: :: LOOT=LO0T(1,5) 2940 CALL POSITION(#1,YP,XP) 2950 IF XP<=HX THEN 2960 ELSE 3100 2960 CALL COINC(#1,#14,8,C) 2970 IF C<>0 THEN 3010 2980 CALL COINC(#1,#5,8,C) !check for hole level 4 2990 IF C<>0 THEN 4780 3000 RETURN 3010 DET=14 3020 IF LOOT<>88 THEN 3040 !do heart 3030 GOTO 4740 3040 IF LOOT<>96 THEN 3060 !do zed 3050 GOTO 4710 3060 IF LOOT<>112 THEN 3080 !do melee 3070 GOTO 4680 3080 IF LOOT<>113 THEN RETURN ! do ranged 3090 GOTO 4650 3100 LOOT=LO0T(1,6) 3110 CALL POSITION(#1,YP,XP) 3120 IF XP>HX THEN 3130 ELSE RETURN 3130 CALL COINC(#1,#15,8,C) 3140 IF C<>0 THEN 3180 3150 CALL COINC(#1,#5,8,C) !check for hole level 4 3160 IF C<>0 THEN 4780 3170 RETURN 3180 DET=15 3190 IF LOOT<>88 THEN 3210 !do heart 3200 GOTO 4740 3210 IF LOOT<>96 THEN 3230 !do zed 3220 GOTO 4710 3230 IF LOOT<>112 THEN 3250 !do melee 3240 GOTO 4680 3250 IF LOOT<>113 THEN RETURN ! do ranged 3260 GOTO 4650 !level 5 3270 IF YP<>105 THEN 3620 3280 CALL POSITION(#6,HY,HX):: LOOT=LO0T(1,7) 3290 CALL POSITION(#1,YP,XP):: 3300 IF XP<=HX THEN 3310 ELSE 3450 3310 CALL COINC(#1,#16,8,C) 3320 IF C<>0 THEN 3360 3330 CALL COINC(#1,#6,8,C) !check for hole level 5 3340 IF C<>0 THEN 4780 3350 RETURN 3360 DET=16 3370 IF LOOT<>88 THEN 3210 !do heart 3380 GOTO 4740 3390 IF LOOT<>96 THEN 3410 !do zed 3400 GOTO 4710 3410 IF LOOT<>112 THEN 3430 !do melee 3420 GOTO 4680 3430 IF LOOT<>113 THEN RETURN ! do ranged 3440 GOTO 4650 3450 LOOT=LO0T(1, 3460 CALL POSITION(#1,YP,XP) 3470 IF XP>HX THEN 3480 ELSE RETURN 3480 CALL COINC(#1,#17,8,C) 3490 IF C<>0 THEN 3530 3500 CALL COINC(#1,#6,8,C) !check for hole level 5 3510 IF C<>0 THEN 4780 3520 RETURN 3530 DET=17 3540 IF LOOT<>88 THEN 3560 !do heart 3550 GOTO 4740 3560 IF LOOT<>96 THEN 3580 3570 GOTO 4710 !do zed 3580 IF LOOT<>112 THEN 3600 !do melee 3590 GOTO 4680 3600 IF LOOT<>113 THEN RETURN ! do ranged 3610 GOTO 4650 !level 6 3620 IF YP<>129 THEN 3970 3630 CALL POSITION(#7,HY,HX):: LOOT=LO0T(1,9) 3640 CALL POSITION(#1,YP,XP) 3650 IF XP<=HX THEN 3660 ELSE 3800 3660 CALL COINC(#1,#18,8,C) 3670 IF C<>0 THEN 3710 3680 CALL COINC(#1,#7,8,C) !check for hole level 6 3690 IF C<>0 THEN 4780 3700 RETURN 3710 DET=18 3720 IF LOOT<>88 THEN 3740 !do heart 3730 GOTO 4740 3740 IF LOOT<>96 THEN 3760 !do zed 3750 GOTO 4710 3760 IF LOOT<>112 THEN 3780 !do melee 3770 GOTO 4680 3780 IF LOOT<>113 THEN RETURN ! do ranged 3790 GOTO 4650 3800 LOOT=LO0T(1,10) 3810 CALL POSITION(#1,YP,XP) 3820 IF XP>HX THEN 3830 ELSE RETURN 3830 CALL COINC(#1,#19,8,C) 3840 IF C<>0 THEN 3880 3850 CALL COINC(#1,#7,8,C) !check for hole level 6 3860 IF C<>0 THEN 4780 3870 RETURN 3880 DET=19 3890 IF LOOT<>88 THEN 3910 !do heart 3900 GOTO 4740 3910 IF LOOT<>96 THEN 3930 !do zed 3920 GOTO 4710 3930 IF LOOT<>112 THEN 3950 !do melee 3940 GOTO 4680 3950 IF LOOT<>113 THEN RETURN ! do ranged 3960 GOTO 4650 !level 7 3970 IF YP<>153 THEN 4320 3980 CALL POSITION(#8,HY,HX):: LOOT=LO0T(1,11) 3990 CALL POSITION(#1,YP,XP) 4000 IF XP<=HX THEN 4010 ELSE 4150 4010 CALL COINC(#1,#20,8,C) 4020 IF C<>0 THEN 4060 4030 CALL COINC(#1,#8,8,C) !check for hole level 7 4040 IF C<>0 THEN 4780 4050 RETURN 4060 DET=20 4070 IF LOOT<>88 THEN 4090 !do heart 4080 GOTO 4740 4090 IF LOOT<>96 THEN 4110 !do zed 4100 GOTO 4710 4110 IF LOOT<>112 THEN 4130 !do melee 4120 GOTO 4680 4130 IF LOOT<>113 THEN RETURN ! do ranged 4140 GOTO 4650 4150 LOOT=LO0T(1,12) 4160 CALL POSITION(#1,YP,XP) 4170 IF XP>HX THEN 4180 ELSE RETURN 4180 CALL COINC(#1,#21,8,C) 4190 IF C<>0 THEN 4230 4200 CALL COINC(#1,#8,8,C) !check for hole level 7 4210 IF C<>0 THEN 4780 4220 RETURN 4230 DET=21 4240 IF LOOT<>88 THEN 4260 !do heart 4250 GOTO 4740 4260 IF LOOT<>96 THEN 4280 !do zed 4270 GOTO 4710 4280 IF LOOT<>112 THEN 4300 !do melee 4290 GOTO 4680 4300 IF LOOT<>113 THEN RETURN ! do ranged 4310 GOTO 4650 !level 8 ground floor 4320 IF YP<>177 THEN RETURN 4330 HX=LASTHLE :: LOOT=LO0T(1,13) 4340 CALL POSITION(#1,YP,XP) 4350 IF XP<=HX THEN 4360 ELSE 4490 4360 CALL COINC(#1,#22,8,C) 4370 IF C<>0 THEN 4400 4380 CALL COINC(#1,#9,4,C) !****collision check against exit 4390 IF C<>0 THEN 4800 ELSE RETURN 4400 DET=22 4410 IF LOOT<>88 THEN 4430 !do heart 4420 GOTO 4740 4430 IF LOOT<>96 THEN 4450 !do zed 4440 GOTO 4710 4450 IF LOOT<>112 THEN 4470 !do melee 4460 GOTO 4680 4470 IF LOOT<>113 THEN RETURN ! do ranged 4480 GOTO 4650 4490 LOOT=LO0T(1,14) 4500 CALL POSITION(#1,YP,XP) 4510 IF XP>HX THEN 4520 ELSE RETURN 4520 CALL COINC(#1,#23,8,C) 4530 IF C<>0 THEN 4560 4540 CALL COINC(#1,#9,4,C) !****collision check against exit 4550 IF C<>0 THEN 4800 ELSE RETURN 4560 DET=23 4570 IF LOOT<>88 THEN 4590 !do heart 4580 GOTO 4740 4590 IF LOOT<>96 THEN 4610 !do zed 4600 GOTO 4710 4610 IF LOOT<>112 THEN 4630 !do melee 4620 GOTO 4680 4630 IF LOOT<>113 THEN RETURN ! do ranged 4640 GOTO 4650 !**********ranged 4650 SCORE=SCORE+5 :: IF RANGED<10 THEN RANGED=RANGED+1 4655 CALL SOUND(1,1000,5):: CALL SOUND(1,1200,2) !*************************gui UPDATE***** 4660 GOSUB 5230 4670 GOTO 4760 !*********melee 4680 SCORE=SCORE+3 :: IF MELEE<10 THEN MELEE=MELEE+1 4685 CALL SOUND(1,1500,5):: CALL SOUND(1,1600,2) !*************************gui UPDATE****** 4690 GOSUB 5230 4700 GOTO 4760 ! *************zed 4710 CALL SOUND(100,-4,0,110,0,1000,0):: HEALTH=HEALTH-1 :: IF HEALTH<=0 THEN 5280 !*************************gui UPDATE****** 4720 GOSUB 5230 4730 RETURN ! *************HEART 4740 SCORE=SCORE+8 :: CALL SOUND(1,500,5):: CALL SOUND(1,600,2):: IF HEALTH<10 THEN HEALTH=HEALTH+1 !*************************gui UPDATE****** 4750 GOSUB 5230 4760 IF DET=O THEN 4770 4765 CALL DELSPRITE(#DET):: RETURN 4770 RETURN !*************FALL******** 4780 FOR FALL=1 TO 24 :: YP=YP+1 :: CALL SOUND(1,666-(FALL*10),5):: CALL SPRITE(#1,44,6,YP,XP):: NEXT FALL 4790 RETURN ! *****************************************************BOARD**Progression************ 4800 CALL DELSPRITE(ALL):: BOARD=BOARD+1 :: RESTORE 160 :: IF SCORE>HSCORE THEN HSCORE=SCORE 4805 GOTO 120 !**********************LOOT DISTRIBUTION SYSTEM****** 4810 LOOTL=INT(RND*4)+1 4820 LOOTR=INT(RND*4)+1 4830 IF LOOTL<>1 THEN 4870 !HEART 88 4840 CALL SPRITE(#SLOT,88,7,GRND-9,((HLE+1)* -40):: SLOT=SLOT+1 4850 LO0T(LAB,LTN)=88 :: LAB=LAB+1 4860 LO0T(LAB,LTN)=SLOT-1 :: LAB=1 :: LTN=LTN+1 4870 IF LOOTL<>2 THEN 4910 !ZED 96 4880 CALL SPRITE(#SLOT,96,4,GRND-9,((HLE+1)* -40):: SLOT=SLOT+1 4890 LO0T(LAB,LTN)=96 :: LAB=LAB+1 4900 LO0T(LAB,LTN)=SLOT-1 :: LAB=1 :: LTN=LTN+1 4910 IF LOOTL<>3 THEN 4950 !MELEE 112 4920 CALL SPRITE(#SLOT,112,8,GRND-9,((HLE+1)* -40):: SLOT=SLOT+1 4930 LO0T(LAB,LTN)=112 :: LAB=LAB+1 4940 LO0T(LAB,LTN)=SLOT-1 :: LAB=1 :: LTN=LTN+1 4950 IF LOOTL<>4 THEN 4990 !RANGED 113 4960 CALL SPRITE(#SLOT,113,14,GRND-9,((HLE+1)* -40):: SLOT=SLOT+1 4970 LO0T(LAB,LTN)=113 :: LAB=LAB+1 4980 LO0T(LAB,LTN)=SLOT-1 :: LAB=1 :: LTN=LTN+1 4990 IF LOOTR<>1 THEN 5030 !HEART 88 5000 CALL SPRITE(#SLOT,88,7,GRND-9,((HLE+1)* +40):: SLOT=SLOT+1 5010 LO0T(LAB,LTN)=88 :: LAB=LAB+1 5020 LO0T(LAB,LTN)=SLOT-1 :: LAB=1 :: LTN=LTN+1 5030 IF LOOTR<>2 THEN 5070 !ZED 96 5040 CALL SPRITE(#SLOT,96,4,GRND-9,((HLE+1)* +40):: SLOT=SLOT+1 5050 LO0T(LAB,LTN)=96 :: LAB=LAB+1 5060 LO0T(LAB,LTN)=SLOT-1 :: LAB=1 :: LTN=LTN+1 5070 IF LOOTR<>3 THEN 5110 !MELEE 112 5080 CALL SPRITE(#SLOT,112,8,GRND-9,((HLE+1)* +40):: SLOT=SLOT+1 5090 LO0T(LAB,LTN)=112 :: LAB=LAB+1 5100 LO0T(LAB,LTN)=SLOT-1 :: LAB=1 :: LTN=LTN+1 5110 IF LOOTR<>4 THEN 5150 !RANGED 113 5120 CALL SPRITE(#SLOT,113,14,GRND-9,((HLE+1)* +40):: SLOT=SLOT+1 5130 LO0T(LAB,LTN)=113 :: LAB=LAB+1 5140 LO0T(LAB,LTN)=SLOT-1 :: LAB=1 :: LTN=LTN+1 5150 RETURN ! **********cOLLISION cHECK WALLs 5160 CALL POSITION(#1,YP,XP) 5170 IF XP<=12 THEN 5180 ELSE 5200 5180 CALL LOCATE(#1,YP,13):: CALL MOTION(#1,0,0) 5190 CALL JOYST(1,JX,JY):: IF JX=-4 THEN 5180 ELSE RETURN 5200 IF XP>=240 THEN 5210 ELSE RETURN 5210 CALL LOCATE(#1,YP,239):: CALL MOTION(#1,0,0) 5220 CALL JOYST(1,JX,JY):: IF JX=4 THEN 5210 ELSE RETURN !********************GUI Update*********** !Output GUI 5230 DISPLAY AT(1,3):SCORE :: DISPLAY AT(1,10):BOARD :: DISPLAY AT(1,15):HEALTH :: DISPLAY AT(1,21):MELEE :: DISPLAY AT(1,26):RANGED !score text gui 5240 CALL VCHAR(1,3,120):: CALL VCHAR(1,4,121):: CALL VCHAR(1,5,122) !Xs gui 5250 CALL VCHAR(1,12,123):: CALL VCHAR(1,17,123):: CALL VCHAR(1,23,123):: CALL VCHAR(1,28,123) !BOARD,hearts,melee,ranged gui 5260 CALL VCHAR(1,11,124):: CALL VCHAR(1,16,88):: CALL VCHAR(1,22,112):: CALL VCHAR(1,27,113) 5270 RETURN ! ******************************YOU ARE DEAD*********************** 5280 CALL MOTION(#1,0,0):: CALL DELSPRITE(ALL):: CALL SCREEN(10) 5290 DATA 89,0044442810101010,79,007C44444444447C,85,0044444444444438 5300 DATA 65,003844447C444444,82,0078444478504844,69,007C40407840407C 5310 DATA 68,0078242424242478 5320 FOR YAD=1 TO 7 5330 READ YADC,YADP$ 5340 CALL CHAR(YADC,YADP$) 5350 NEXT YAD 5360 CALL CLEAR !YOU 5370 CALL VCHAR(12,10,89):: CALL VCHAR(12,11,79):: CALL VCHAR(12,12,85):: CALL VCHAR(12,13,32) !ARE 5380 CALL VCHAR(12,14,65):: CALL VCHAR(12,15,82):: CALL VCHAR(12,16,69):: CALL VCHAR(12,17,32) !DEAD 5390 CALL VCHAR(12,18,68):: CALL VCHAR(12,19,69):: CALL VCHAR(12,20,65):: CALL VCHAR(12,21,68) 5400 FOR CLRS=1 TO 13 :: CALL COLOR(CLRS,16,1):: NEXT CLRS 5410 CALL SCREEN(2) 5420 GOSUB 5230 5430 CALL KEY(1,K,S):: IF K=0 AND S=-1 THEN 7300 5435 IF K=6 THEN 5440 ELSE 5450 5440 CALL DELSPRITE(ALL):: RESTORE 160 :: GOTO 100 5450 CALL JOYST(1,JX,JY):: IF JX=0 THEN 5430 5455 IF JY=0 THEN 5430 ELSE 5440 !*******************MAN MELEE ATTACK !melee attack pattern 5460 CALL PATTERN(#1,45) !right attack 5470 CALL SPRITE(#24,143,12,YP,XP+ :: CALL SOUND(125,-5,0) !MELLE HIT DETECTION RIGHT 5480 GOSUB 7320 5490 CALL DELSPRITE(#24) !left attack 5500 CALL SPRITE(#25,143,12,YP,XP- :: CALL SOUND(125,-6,0) !MELEE HIT DETECTION LEFT 5510 GOSUB 7370 5520 CALL DELSPRITE(#25) 5530 CALL PATTERN(#1,44):: CALL COLOR(#DET,4):: RETURN !MAN MELEE ATTACK 5540 CALL PATTERN(#1,45) 5550 CALL SPRITE(#24,143,12,YP,XP+ :: CALL SOUND(125,-5,0) !right attack 5560 GOSUB 7320 !MELLE HIT DETECTION RIGHT 5570 CALL DELSPRITE(#24) 5580 CALL SPRITE(#25,143,12,YP,XP- :: CALL SOUND(125,-6,0) !left attack 5590 GOSUB 7390 !MELEE HIT DETECTION LEFT 5600 CALL DELSPRITE(#25) 5610 CALL PATTERN(#1,44):: CALL COLOR(#DET,4):: RETURN 5620 CALL MOTION(#1,0,0):: CALL POSITION(#1,YP,XP) !******************************************************************MAN RANGED ATTACK 5630 IF RANGED<=0 THEN CALL SOUND(100,-6,0) else 5635 5632 return 5635 ranged=ranged-1:: GOSUB 5230 !*********************************Shoot Right 5637 IF CS<>16 THEN 6150 5640 CALL SPRITE(#1,47,6,YP,XP) 5650 IF YP<>33 THEN 5730 5660 IF LO0T(1,1)<>96 THEN 5680 5670 ZED1=1 :: CALL POSITION(#10,YZ1,XZ1):: CALL POSITION(#1,YP,XP):: DET1=LO0T(2,1)::IF XP>=XZ1 THEN ZED1=0 5675 GOTO 5690 5680 ZED1=0 5690 IF LO0T(1,2)<>96 THEN 5720 5710 ZED2=1 :: CALL POSITION(#11,YZ2,XZ2):: CALL POSITION(#1,YP,XP):: DET2=LO0T(2,2)::IF XP>=XZ2 THEN ZED2=0 5715 GOTO 6670 5720 ZED2=0 :: GOTO 6670 5730 IF YP<>57 THEN 5800 5740 IF LO0T(1,3)<>96 THEN 5760 5750 ZED1=1 :: CALL POSITION(#12,YZ1,XZ1):: CALL POSITION(#1,YP,XP):: DET1=LO0T(2,3)::IF XP>=XZ1 THEN ZED1=0 5755 GOTO 5770 5760 ZED1=0 5770 IF LO0T(1,4)<>96 THEN 5790 5780 ZED2=1 :: CALL POSITION(#13,YZ2,XZ2):: CALL POSITION(#1,YP,XP):: DET2=LO0T(2,4)::IF XP>=XZ2 THEN ZED2=0 5785 GOTO 6670 5790 ZED2=0 :: GOTO 6670 5800 IF YP<>81 THEN 5870 5810 IF LO0T(1,5)<>96 THEN 5830 5820 ZED1=1 :: CALL POSITION(#14,YZ1,XZ1):: CALL POSITION(#1,YP,XP):: DET1=LO0T(2,5)::IF XP>=XZ1 THEN ZED1=0 5825 GOTO 5840 5830 ZED1=0 5840 IF LO0T(1,6)<>96 THEN 5860 5850 ZED2=1 :: CALL POSITION(#15,YZ2,XZ2):: CALL POSITION(#1,YP,XP):: DET2=LO0T(2,6)::IF XP>=XZ2 THEN ZED2=0 5855 GOTO 6670 5860 ZED2=0 :: GOTO 6670 5870 IF YP<>105 THEN 5940 5880 IF LO0T(1,7)<>96 THEN 5900 5890 ZED1=1 :: CALL POSITION(#16,YZ1,XZ1):: CALL POSITION(#1,YP,XP):: DET1=LO0T(2,7)::IF XP>=XZ1 THEN ZED1=0 5895 GOTO 5910 5900 ZED1=0 5910 IF LO0T(1, <>96 THEN 5930 5920 ZED2=1 :: CALL POSITION(#17,YZ2,XZ2):: CALL POSITION(#1,YP,XP):: DET2=LO0T(2, ::IF XP>=XZ2 THEN ZED2=0 5925 GOTO 6670 5930 ZED2=0 :: GOTO 6670 5940 IF YP<>129 THEN 6010 5950 IF LO0T(1,9)<>96 THEN 5970 5960 ZED1=1 :: CALL POSITION(#18,YZ1,XZ1):: CALL POSITION(#1,YP,XP):: DET1=LO0T(2,9)::IF XP>=XZ1 THEN ZED1=0 5965 GOTO 5980 5970 ZED1=0 5980 IF LO0T(1,10)<>96 THEN 6000 5990 ZED2=1 :: CALL POSITION(#19,YZ2,XZ2):: CALL POSITION(#1,YP,XP):: DET2=LO0T(2,10)::IF XP>=XZ2 THEN ZED2=0 5995 GOTO 6670 6000 ZED2=0 :: GOTO 6670 6010 IF YP<>153 THEN 6080 6020 IF LO0T(1,11)<>96 THEN 6040 6030 ZED1=1 :: CALL POSITION(#20,YZ1,XZ1):: CALL POSITION(#1,YP,XP):: DET1=LO0T(2,11)::IF XP>=XZ1 THEN ZED1=0 6030 GOTO 6050 6040 ZED1=0 6050 IF LO0T(1,12)<>96 THEN 6070 6060 ZED2=1 :: CALL POSITION(#21,YZ2,XZ2):: CALL POSITION(#1,YP,XP):: DET2=LO0T(2,12)::IF XP>=XZ2 THEN ZED2=0 6065 GOTO 6670 6070 ZED2=0 :: GOTO 6670 6080 IF YP<>177 THEN return 6090 IF LO0T(1,13)<>96 THEN 6110 6100 ZED1=1 :: CALL POSITION(#22,YZ1,XZ1):: CALL POSITION(#1,YP,XP):: DET1=LO0T(2,13)::IF XP>=XZ1 THEN ZED1=0 6105 GOTO 6120 6110 ZED1=0 6120 IF LO0T(1,14)<>96 THEN 6140 6130 ZED2=1 :: CALL POSITION(#23,YZ2,XZ2):: CALL POSITION(#1,YP,XP):: DET2=LO0T(2,14):: IF XP>=XZ2 THEN ZED2=0 6135GOTO 6670 6140 ZED2=0 :: GOTO 6670 !*******************************************Shoot Left 6150 IF CS<>-16 THEN return 6160 CALL SPRITE(#1,46,6,YP,XP) 6170 IF YP<>33 THEN 6250 6180 IF LO0T(1,1)<>96 THEN 6200 6190 ZED1=1 :: CALL POSITION(#10,YZ1,XZ1):: CALL POSITION(#1,YP,XP):: DET1=LO0T(2,1):: IF XP<=XZ1 THEN ZED1=0 6195 GOTO 6210 6200 ZED1=0 6210 IF LO0T(1,2)<>96 THEN 6240 6230 ZED2=1 :: CALL POSITION(#11,YZ2,XZ2):: CALL POSITION(#1,YP,XP):: DET2=LO0T(2,2):: IF XP<=XZ2 THEN ZED2=0 6235 GOTO 6940 6240 ZED2=0 :: GOTO 6940 6250 IF YP<>57 THEN 6315 6260 IF LO0T(1,3)<>96 THEN 6280 6270 ZED1=1 :: CALL POSITION(#12,YZ1,XZ1):: CALL POSITION(#1,YP,XP)::DET1=LO0T(2,3):: IF XP<=XZ1 THEN ZED1=0 6275GOTO 6290 6280 ZED1=0 6290 IF LO0T(1,4)<>96 THEN 6310 6300 ZED2=1 :: CALL POSITION(#13,YZ2,XZ2):: CALL POSITION(#1,YP,XP):: DET2=LO0T(2,4):: IF XP<=XZ2 THEN ZED2=0 6305 GOTO 6940 6310 ZED2=0 :: GOTO 6940 6315 IF YP<>81 THEN 6380 6320 IF LO0T(1,5)<>96 THEN 6340 6330 ZED1=1 :: CALL POSITION(#14,YZ1,XZ1):: CALL POSITION(#1,YP,XP):: DET1=LO0T(2,5):: IF XP<=XZ1 THEN ZED1=0 6335 GOTO 6350 6340 ZED1=0 6350 IF LO0T(1,6)<>96 THEN 6370 6360 ZED2=1 :: CALL POSITION(#15,YZ2,XZ2):: CALL POSITION(#1,YP,XP):: DET2=LO0T(2,6):: IF XP<=XZ2 THEN ZED2=0 6365 GOTO 6940 6370 ZED2=0 :: GOTO 6940 6380 IF YP<>105 THEN 6450 6390 IF LO0T(1,7)<>96 THEN 6410 6400 ZED1=1 :: CALL POSITION(#16,YZ1,XZ1):: CALL POSITION(#1,YP,XP):: DET1=LO0T(2,7):: IF XP<=XZ1 THEN ZED1=0 6405 GOTO 6420 6410 ZED1=0 6420 IF LO0T(1, <>96 THEN 6440 6430 ZED2=1 :: CALL POSITION(#17,YZ2,XZ2):: CALL POSITION(#1,YP,XP):: DET2=LO0T(2, :: IF XP<=XZ2 THEN ZED2=0 6435 GOTO 6940 6440 ZED2=0 :: GOTO 6940 6450 IF YP<>129 THEN 6520 6460 IF LO0T(1,9)<>96 THEN 6480 6470 ZED1=1 :: CALL POSITION(#18,YZ1,XZ1):: CALL POSITION(#1,YP,XP):: DET1=LO0T(2,9):: IF XP<=XZ1 THEN ZED1=0 6475 GOTO 6490 6480 ZED1=0 6490 IF LO0T(1,10)<>96 THEN 6510 6500 ZED2=1 :: CALL POSITION(#19,YZ2,XZ2):: CALL POSITION(#1,YP,XP):: DET2=LO0T(2,10):: IF XP<=XZ2 THEN ZED2=0 6505 GOTO 6940 6510 ZED2=0 :: GOTO 6940 6520 IF YP<>153 THEN 6590 6530 IF LO0T(1,11)<>96 THEN 6550 6540 ZED1=1 :: CALL POSITION(#20,YZ1,XZ1):: CALL POSITION(#1,YP,XP):: DDET1=LO0T(2,11):: IF XP<=XZ1 THEN ZED1=0 6545 GOTO 6560 6550 ZED1=0 6560 IF LO0T(1,12)<>96 THEN 6580 6570 ZED2=1 :: CALL POSITION(#21,YZ2,XZ2):: CALL POSITION(#1,YP,XP):: DET2=LO0T(2,12):: IF XP<=XZ2 THEN ZED2=0 6575 GOTO 6940 6580 ZED2=0 :: GOTO 6940 6590 IF YP<>177 THEN RETURN 6600 IF LO0T(1,13)<>96 THEN 6620 6610 ZED1=1 :: CALL POSITION(#22,YZ1,XZ1):: CALL POSITION(#1,YP,XP):: DET1=LO0T(2,13):: IF XP<=XZ1 THEN ZED1=0 6615 GOTO 6630 6620 ZED1=0 6630 IF LO0T(1,14)<>96 THEN 6650 6640 ZED2=1 :: CALL POSITION(#23,YZ2,XZ2):: CALL POSITION(#1,YP,XP):: DET2=LO0T(2,14):: IF XP<=XZ2 THEN ZED2=0 6645 GOTO 6940 6650 ZED2=0 :: GOTO 6940 6660 RETURN !***************************************Bullet fire right 6670 IF ZED1=0 AND ZED2=0 THEN 6910 6671 IF ZED1=1 AND ZED2=0 THEN 6770 6672 IF ZED1=0 AND ZED2=1 THEN 6810 6673 IF ZED1=1 AND ZED2=1 THEN 6770 !Kill ZED1 6770 CALL SOUND(100,-6,0):: CALL SPRITE(#26,142,6,YP,XP+8,0,16) 6775 call coinc(#26,#DET1,bull,c) 6777 IF C<>1 THEN 6780 ELSE 6775 !*****gui UPDATE****** 6780 CALL COLOR(#DET1,7):: ZHELTH=ZHELTH-2 :: IF ZHELTH>=1 THEN 7110 6785 Score=Score+10::CALL DELSPRITE(#26):: CALL DELSPRITE(#det1):: GOSUB 5230 6800 GOTO 7110 !KILL ZED2 6810 CALL SOUND(100,-6,0):: CALL SPRITE(#26,142,6,YP,XP+8,0,16) 6815 call coinc(#26,#DET2,bull,c) 6820 IF C<>0 THEN 6830 ELSE 6815 !gui UPDATE 6830 CALL COLOR(#DET2,7):: ZHELTH=ZHELTH-2 :: IF ZHELTH>=1 THEN 7110 :: Score=Score+10::CALL DELSPRITE(#26):: CALL DELSPRITE(#det2):: GOSUB 5230 6840 GOTO 7110 !NO ZED KILLS 6910 CALL SOUND(100,-6,0):: CALL SPRITE(#26,142,6,YP,XP+8,0,16) 6915 CALL POSITION(#26,YB,XB) 6920 IF XB>=238 THEN 6930 ELSE 6915 6930 CALL DELSPRITE(#26):: GOTO 7110 !****************************************Bullet fire left 6940 IF ZED1=0 AND ZED2=0 THEN 7100 6942 IF ZED1=1 AND ZED2=0 THEN 6975 6945 IF ZED1=0 AND ZED2=1 THEN 7005 6947 IF ZED1=1 AND ZED2=1 THEN 6975 !Kill ZED1 6975 CALL SOUND(100,-6,0):: CALL SPRITE(#26,142,6,YP,XP-8,0,-16) 6980 call coinc(#26,#DET1,bull,c) 6985 IF C<>0 THEN 6990 ELSE 6980 !*****gui UPDATE***** 6990 CALL COLOR(#DET1,7):: ZHELTH=ZHELTH-2 :: IF ZHELTH=1 THEN 7110 6995 Score=Score+10::CALL DELSPRITE(#26):: CALL DELSPRITE(#det1)::GOSUB 5230 7000 GOTO 7110 !KILL ZED2 7005 CALL SOUND(100,-6,0):: CALL SPRITE(#26,142,6,YP,XP-8,0,-16) 7010 call coinc(#26,#DET2,bull,c) 7015 IF C<>0 THEN 7020 ELSE 7010 !gui UPDATE 7020 CALL COLOR(#DET2,7):: ZHELTH=ZHELTH-2 :: IF ZHELTH>=1 THEN 7110 7025 Score=Score+10::CALL DELSPRITE(#26):: CALL DELSPRITE(#det2)::GOSUB 5230 7030 GOTO 7110 !NO ZED KILLS 7100 CALL SOUND(100,-6,0):: CALL SPRITE(#26,142,6,YP,XP-8,0,-16) 7102 CALL POSITION(#26,YB,XB) 7104 IF XB<=17 THEN 7106 ELSE 7102 7106 CALL DELSPRITE(#26):: GOTO 7110 ! attack ranged again or end **********************************************NEEDS WORK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! 7110 CALL JOYST(1,JX,JY):: IF jy=0 THEN RETURN 7115 IF JY-4 THEN 7120 ELSE RETURN 7120 gosub 5630 7130 return !ZED COINC BEHAVIOR !ZED ATTACK !JOYS Combat choice 7140 CALL MOTION(#1,0,0):: CALL POSITION(#1,YP,XP) !UPDATE GUI 7150 MELEE=MELEE-1 :: GOSUB 5230 !MELEE ATTACK 7160 GOSUB 5540 7170 RETURN !*****************ZED COINC BEHAVIOR************* !****************ZED ATTACK****************** !*****JOYS Combat choice***** 7210 IF JY=4 AND MELEE>=1 THEN 7230 7212 if JY=4 and melee<=0 then 7220 7214 if jy=-4 then 7215 ELSE return 7215 gosub 5630 7217 return 7220 CALL SOUND(100,-3,0):: RETURN 7230 CALL MOTION(#1,0,0):: CALL POSITION(#1,YP,XP) !*******UPDATE GUI 7240 MELEE=MELEE-1 :: GOSUB 5230 !PERFORM MELEE ATTACK 7250 GOSUB 5460 7260 RETURN 7270 IF JY=-4 THEN 7280 ELSE CALL SOUND(100,-6,0) 7275 RETURN 7280 GOSUB 5630 7290 RETURN !***quit game 7300 CALL CLEAR :: END !************************mELEE collision check against LOOT********************* 7320 FOR DET=10 TO 23 7330 CALL COINC(#24,#DET,7,C) 7340 IF C<>0 THEN 7420 ELSE 7350 7350 NEXT DET 7360 RETURN !MELEE LEFT 7370 FOR DET=10 TO 23 7380 CALL COINC(#25,#DET,7,C) 7390 IF C<>0 THEN 7420 ELSE 7400 7400 NEXT DET 7410 RETURN 7420 TLOOP1=DET-9 !heart 7430 IF LO0T(1,TLOOP1)<>88 THEN 7440 ELSE 7520 !zed - ALL ALPHA TEMP CODE 7440 IF LO0T(1,TLOOP1)<>96 THEN 7490 7450 CALL COLOR(#DET,7):: ZHELTH=ZHELTH-1 :: IF ZHELTH>=1 THEN 7530 7460 SCORE=SCORE+10 :: ZHELTH=2 !*****gui UPDATE****** 7470 GOSUB 5230 7480 GOTO 7520 !melee 7490 IF LO0T(1,TLOOP1)<>112 THEN 7510 7500 GOTO 7520 !range 7510 IF LO0T(1,TLOOP1)<>113 THEN 7530 7520 CALL DELSPRITE(#DET):: RETURN 7530 RETURN !do melee 7540 GOTO 4680 Edited August 31, 2016 by Sinphaltimus Quote Link to comment Share on other sites More sharing options...
Opry99er Posted September 2, 2016 Share Posted September 2, 2016 Man, just use TIdBiT.... Game changer... Life changer... Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted September 2, 2016 Author Share Posted September 2, 2016 (edited) Man, just use TIdBiT.... Game changer... Life changer... I can't. I don't know how. What I mean is, I learned how to use TI basic with line numbers. My brain breaks when I try to not do that. I can code without line numbers in GML because I learned GML that way. IN GML i can use switch statements. In XB I cannot they don't exist. I get that I can replace goto and gosub with sub and such But I don't know the acceptable syntax for tidbit that will accurately translate it toTI XB. Trust me, I want to. Here's a small example of GM code I have in another game: I wouldn't know how to do the same for TI XB. os_powersave_enable(false); //disables device's power saving features // The following 4 lines are for Android tilt control - rem them out for PC testing // Taking control of static gravity for Troom 13 pinball game with "IF" statement - see also this objects END step event. if room != rm_Troom13 { var gx,gy; gx=device_get_tilt_x()*grav_tilt*(-1); gy=device_get_tilt_y()*grav_tilt; physics_world_gravity(gx,gy); } //Creates paddle under players finger if game is not paused. if global.gameMode = 1 then global.GEnergy = global.maxGEnergy; if mouse_check_button_pressed(mb_left) && !instance_exists(obj_pause_bkgrnd) && global.GEnergy >0 { if room != rm_Score && room != rm_Troom13 && !instance_exists(obj_falsePaddle){instance_create(mouse_x,mouse_y,obj_falsePaddle);if !instance_exists(obj_touchSparks) instance_create(mouse_x,mouse_y,obj_touchSparks);} } else { if mouse_check_button_pressed(mb_left) && !instance_exists(obj_touchSparks) && room != rm_Troom13 {instance_create(mouse_x,mouse_y,obj_touchSparks);} } if global.GEnergy < 1 then global.GEnergy = 0; if global.sound_toggle == 1 { if !instance_exists(obj_paddle) && !instance_exists(obj_falsePaddle)then audio_stop_sound(snd_ElectroBuzz); if !instance_exists(obj_paddle) && !instance_exists(obj_falsePaddle)then audio_stop_sound(snd_ElectroPop); } if(mouse_check_button_released(mb_left)) { if instance_exists(obj_falsePaddle) with (obj_falsePaddle){instance_destroy();} if instance_exists(obj_paddle) with (obj_paddle){instance_destroy();} if !instance_exists(obj_touchSparks) && room != rm_Troom13 && room != rm_levels then instance_create(mouse_x,mouse_y,obj_touchSparks); } Edited September 2, 2016 by Sinphaltimus Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted September 6, 2016 Author Share Posted September 6, 2016 (edited) So I check SIZE and found 602 bytes free.Cleaned up just the first few lines of code and now I'm over 2k free. After "running" the program then quitting and checking size, I end up with 1.5k. So there's still some room to work with and I still have a lot of optimizing to do. Here's what the cleaned up code looks like so far. You can compare if you like or update the version you have if you like. No other changes as I'm not ready to release the next version.My next huge challenge right now is zombie conic. I have to determine how many zombies there are and to a coinc for left right boundaries as well as a coinc for the hole, for each, on every cycle separate from the player character..I'm really concerned about the performance hit I'm going to take and the amount of code it's going to take to do all this. 100 SCORE=0000 :: HEALTH=10 :: BOARD=1 :: HSCORE=0 :: MELEE=0 :: RANGED=0 :: BULL=8 :: CALL SCREEN(2) 110 CALL COLOR(10,15,1,3,12,1,4,12,1,11,12,1,12,12,1):: HCLR=1 :: CALL CLEAR !running,stopping,jumping,left and right patterns 160 CALL CHAR(33,"18181010101010181818183C1C142630181A3C5E1A33406018197E981C724100") 165 CALL CHAR(37,"18197E98181472431818385E581C24361818101010101018000C1C3058081018") 170 CALL CHAR(41,"00000C1C305C1C180000060E183C0C180003070C18081018") 180 CALL CHAR(64,"030304060908101018181418101060001818103810180C001818503010180404") 190 CALL CHAR(68,"0018183050180818181810103850101818180808080808181818183C3828640C") 200 CALL CHAR(72,"18583C7A58CC020618987E19384E820018987E1918284EC218181C7A1A38246C") 210 CALL CHAR(76,"18180808080808180030380C1A100818000030380C3A381800006070183C3018") 220 CALL CHAR(80,"00C0E03018100818C0C020609010080818182818080806001818081C08183000") 230 CALL CHAR(84,"18180A0C081820200018180C0A181018181808081C0A0818") 240 CALL CHAR(104,"3C4426D999A5C3FFFFC3A59999A5C3FFFFFFFFFFFFFFFFFF1F1111111D11111F") 610 CALL CHAR(88,"66FFFFFF7E7E3C18",96,"3C2418FF9918183C") 630 CALL CHAR(112,"C0E0703A1E0C1A01000000FF7F1E1606") 650 CALL CHAR(120,"70808063141414E300000000334A4A3200000000993C21180044442810284444") 680 CALL CHAR(124,"E0E080E9EF86EFE9",142,"0000008000000000002418FF1824") 690 CALL CHAR(44,"3838107CBA38286C3C3C18FF7E3C183C0C0C04FC4C3C286C3030203F323C1436") 720 CALL CHAR(97,"3C2C18F81838246C3C2C18F8181818383C34181F181C24363C34181F1818181C") 760 RANDOMIZE 770 SLOT=10 780 OPTION BASE 1 790 DIM LO0T(3,14) 800 LTN=1::LAB=1::SHL=2 :: GRND=17::ZHELTH=2 830 LVL=3 :: YP=9 :: XP=8 :: RS=0 :: CS=16 :: RSPD=2.0 :: RSPDD=3.3 840 CHRR=33::CHSR=39::CHJR=64::CHLR=68::CHRL=70::CHSL=76::CHJL=81::CHLL=85:: Edited September 6, 2016 by Sinphaltimus Quote Link to comment Share on other sites More sharing options...
matthew180 Posted September 9, 2016 Share Posted September 9, 2016 (edited) I can't. I don't know how. What I mean is, I learned how to use TI basic with line numbers. My brain breaks when I try to not do that. Sadly, learning line-number BASIC means you have a lot to un-learn when you move to any other language. Back when I was moving from BASIC to any other language, I remember not understanding how to make a program repeat something (like a game loop) without using GOTO. Since BASIC / XB do not have any looping constructs (DO/WHILE, WHILE/WEND, REPEAT/UNTIL, etc.) other than FOR/NEXT, stepping away from line numbers was a huge expansion of my understanding. Interestingly, the original BASIC language as created by John G. Kemeny and Thomas E. Kurtz does not have line numbers, and *does* have many of the constructs missing from line-number BASICs. Still, BASIC made home computers easily accessible for many people and probably started many careers (like my own). Using TidBit is easy. Start writing code just like you normally would, but leave out the line numbers. Any time you would normally want to use a line number in a GOTO, GOSUB, or THEN, just use a label. Heck, use labels like _250, _1000, etc. if that helps you (just don't start a label with a number). You can use C/C++ style comments in TidBit and they will all get stripped out, so you can combine your notes right in with your code and stop the madness. I can code without line numbers in GML because I learned GML that way. IN GML i can use switch statements. In XB I cannot they don't exist. Unfortunately, most of the ROM BASIC dialects that existed in the home computers are missing these constructs. You can simulate SWITCH in XB, but that would just add overhead. If your variable is numeric you can use ON GOTO or ON GOSUB in a very SWITCH-ish kind of way. But the old BASICs are limited and you certainly have to change your way of thinking to work with them efficiently. Any language is like that though. The syntax is easy part, but learning how to use the language in the way it was intended is what takes time. But the lack of indentation and complications of editing code with line numbers are the main reasons I wrote TidBit. I get that I can replace goto and gosub with sub and such But I don't know the acceptable syntax for tidbit that will accurately translate it toTI XB. Trust me, I want to. It seems you think TidBit is doing more than it really is. You are still writing BASIC or XB, that does not change. You can try it out on my web site here: http://codehackcreate.com/archives/237 There is even a quick simple example. You can even begin by using your existing code, since TidBit will not replace any line numbers you already have. So, if you just want to use it to comment your code, you can do that. Then you can start to replace line numbers in your code with labels where you need them. For example: Code in: // The quintessential Hello World program. 100 CALL CLEAR 200 PRINT "HELLO WORLD" Code out: 100 CALL CLEAR 200 PRINT "HELLO WORLD" Here is another example that mixes line-number XB with code that will get line-numbers assigned. While you can do this, you have to be careful since TidBit can get confused and won't stop you from overwriting lines if the auto-generated lines run into a line number you force. But I think you will get the idea: Code in: // Zombie Attack. 100 CALL CLEAR 200 PRINT "ZOMBIE ATTACK" PRINT "This line will get an auto line number from TidBit" GOSUB collision_detection GOSUB 2000 GOSUB zombie_ai END // Collision detection subroutine 1000 // This line number will force this subroutine to start on line 1000. collision_detection: PRINT "Do collision detection" RETURN // Some other routine, the line number is forced and TidBit will not over-write it. 2000 PRINT "Another sub routine" 2010 RETURN // Zombie AI - this routine will start on whatever line number follows from the previous code. // But we don't care what line number is gets assigned, since the GOSUB above uses the label // "name" instead of a hard-coded line number. zombie_ai: PRINT "BRAINS!" RETURN Code out: 100 CALL CLEAR 200 PRINT "ZOMBIE ATTACK" 210 PRINT "This line will get an auto line number from TidBit" 220 GOSUB 1000 230 GOSUB 2000 240 GOSUB 2020 250 END 1000 PRINT "Do collision detection" 1010 RETURN 2000 PRINT "Another sub routine" 2010 RETURN 2020 PRINT "BRAINS!" 2030 RETURN I went ahead and took part of your code and TidBit-ified it. It no longer relies on line numbers, you can comment the heck out of it, more easily check your structure and program flow, etc. // ******************************************* // Shoot Left // ******************************************* IF CS<>-16 THEN return CALL SPRITE(#1,46,6,YP,XP) IF YP<>33 THEN _6250 IF LO0T(1,1)<>96 THEN _6200 ZED1=1 :: CALL POSITION(#10,YZ1,XZ1):: CALL POSITION(#1,YP,XP):: DET1=LO0T(2,1):: IF XP<=XZ1 THEN ZED1=0 GOTO _6210 _6200: ED1=0 _6210: IF LO0T(1,2)<>96 THEN _6240 ZED2=1 :: CALL POSITION(#11,YZ2,XZ2):: CALL POSITION(#1,YP,XP):: DET2=LO0T(2,2):: IF XP<=XZ2 THEN ZED2=0 GOTO bullet_file_left _6240: ZED2=0:: GOTO bullet_file_left _6250: IF YP<>57 THEN _6315 IF LO0T(1,3)<>96 THEN _6280 ZED1=1 :: CALL POSITION(#12,YZ1,XZ1):: CALL POSITION(#1,YP,XP):: DET1=LO0T(2,3):: IF XP<=XZ1 THEN ZED1=0 GOTO _6290 _6280: ZED1=0 _6290: IF LO0T(1,4)<>96 THEN _6310 ZED2=1 :: CALL POSITION(#13,YZ2,XZ2):: CALL POSITION(#1,YP,XP):: DET2=LO0T(2,4):: IF XP<=XZ2 THEN ZED2=0 GOTO bullet_file_left _6310: ZED2=0:: GOTO bullet_file_left _6315: IF YP<>81 THEN _6380 IF LO0T(1,5)<>96 THEN _6340 ZED1=1 :: CALL POSITION(#14,YZ1,XZ1):: CALL POSITION(#1,YP,XP):: DET1=LO0T(2,5):: IF XP<=XZ1 THEN ZED1=0 GOTO _6350 _6340: ZED1=0 _6350: IF LO0T(1,6)<>96 THEN _6370 ZED2=1 :: CALL POSITION(#15,YZ2,XZ2):: CALL POSITION(#1,YP,XP):: DET2=LO0T(2,6):: IF XP<=XZ2 THEN ZED2=0 GOTO bullet_file_left _6370: ZED2=0:: GOTO bullet_file_left _6380: IF YP<>105 THEN _6450 IF LO0T(1,7)<>96 THEN _6410 ZED1=1 :: CALL POSITION(#16,YZ1,XZ1):: CALL POSITION(#1,YP,XP):: DET1=LO0T(2,7):: IF XP<=XZ1 THEN ZED1=0 GOTO _6420 _6410: ZED1=0 _6420: IF LO0T(1, <>96 THEN _6440 ZED2=1 :: CALL POSITION(#17,YZ2,XZ2):: CALL POSITION(#1,YP,XP):: DET2=LO0T(2, :: IF XP<=XZ2 THEN ZED2=0 GOTO bullet_file_left _6440: ZED2=0:: GOTO bullet_file_left _6450: IF YP<>129 THEN _6520 IF LO0T(1,9)<>96 THEN _6480 ZED1=1 :: CALL POSITION(#18,YZ1,XZ1):: CALL POSITION(#1,YP,XP):: DET1=LO0T(2,9):: IF XP<=XZ1 THEN ZED1=0 GOTO _6490 _6480: ZED1=0 _6490: IF LO0T(1,10)<>96 THEN _6510 ZED2=1 :: CALL POSITION(#19,YZ2,XZ2):: CALL POSITION(#1,YP,XP):: DET2=LO0T(2,10):: IF XP<=XZ2 THEN ZED2=0 GOTO bullet_file_left _6510: ZED2=0:: GOTO bullet_file_left _6520: IF YP<>153 THEN _6590 IF LO0T(1,11)<>96 THEN _6550 ZED1=1 :: CALL POSITION(#20,YZ1,XZ1):: CALL POSITION(#1,YP,XP):: DDET1=LO0T(2,11):: IF XP<=XZ1 THEN ZED1=0 GOTO _6560 _6550: ZED1=0 _6560: IF LO0T(1,12)<>96 THEN _6580 ZED2=1 :: CALL POSITION(#21,YZ2,XZ2):: CALL POSITION(#1,YP,XP):: DET2=LO0T(2,12):: IF XP<=XZ2 THEN ZED2=0 GOTO bullet_file_left _6580: ZED2=0:: GOTO bullet_file_left _6590: IF YP<>177 THEN RETURN IF LO0T(1,13)<>96 THEN _6620 ZED1=1 :: CALL POSITION(#22,YZ1,XZ1):: CALL POSITION(#1,YP,XP):: DET1=LO0T(2,13):: IF XP<=XZ1 THEN ZED1=0 GOTO _6630 _6620: ZED1=0 _6630: IF LO0T(1,14)<>96 THEN _6650 ZED2=1 :: CALL POSITION(#23,YZ2,XZ2):: CALL POSITION(#1,YP,XP):: DET2=LO0T(2,14):: IF XP<=XZ2 THEN ZED2=0 GOTO bullet_file_left _6650: ZED2=0:: GOTO bullet_file_left RETURN // **************************************** // Bullet fire left // **************************************** bullet_file_left: 6940 IF ZED1=0 AND ZED2=0 THEN 7100 6942 IF ZED1=1 AND ZED2=0 THEN 6975 6945 IF ZED1=0 AND ZED2=1 THEN 7005 6947 IF ZED1=1 AND ZED2=1 THEN 6975 Output. Looks almost identical to your original code except where TidBit was numbering by 10 and in a few places you had to slip in a line number incremented by 5. 6150 IF CS<>-16 THEN return 6160 CALL SPRITE(#1,46,6,YP,XP) 6170 IF YP<>33 THEN 6260 6180 IF LO0T(1,1)<>96 THEN 6210 6190 ZED1=1 :: CALL POSITION(#10,YZ1,XZ1):: CALL POSITION(#1,YP,XP):: DET1=LO0T(2,1):: IF XP<=XZ1 THEN ZED1=0 6200 GOTO 6220 6210 ED1=0 6220 IF LO0T(1,2)<>96 THEN 6250 6230 ZED2=1 :: CALL POSITION(#11,YZ2,XZ2):: CALL POSITION(#1,YP,XP):: DET2=LO0T(2,2):: IF XP<=XZ2 THEN ZED2=0 6240 GOTO 6940 6250 ZED2=0:: GOTO 6940 6260 IF YP<>57 THEN 6350 6270 IF LO0T(1,3)<>96 THEN 6300 6280 ZED1=1 :: CALL POSITION(#12,YZ1,XZ1):: CALL POSITION(#1,YP,XP):: DET1=LO0T(2,3):: IF XP<=XZ1 THEN ZED1=0 6290 GOTO 6310 6300 ZED1=0 6310 IF LO0T(1,4)<>96 THEN 6340 6320 ZED2=1 :: CALL POSITION(#13,YZ2,XZ2):: CALL POSITION(#1,YP,XP):: DET2=LO0T(2,4):: IF XP<=XZ2 THEN ZED2=0 6330 GOTO 6940 6340 ZED2=0:: GOTO 6940 6350 IF YP<>81 THEN 6440 6360 IF LO0T(1,5)<>96 THEN 6390 6370 ZED1=1 :: CALL POSITION(#14,YZ1,XZ1):: CALL POSITION(#1,YP,XP):: DET1=LO0T(2,5):: IF XP<=XZ1 THEN ZED1=0 6380 GOTO 6400 6390 ZED1=0 6400 IF LO0T(1,6)<>96 THEN 6430 6410 ZED2=1 :: CALL POSITION(#15,YZ2,XZ2):: CALL POSITION(#1,YP,XP):: DET2=LO0T(2,6):: IF XP<=XZ2 THEN ZED2=0 6420 GOTO 6940 6430 ZED2=0:: GOTO 6940 6440 IF YP<>105 THEN 6530 6450 IF LO0T(1,7)<>96 THEN 6480 6460 ZED1=1 :: CALL POSITION(#16,YZ1,XZ1):: CALL POSITION(#1,YP,XP):: DET1=LO0T(2,7):: IF XP<=XZ1 THEN ZED1=0 6470 GOTO 6490 6480 ZED1=0 6490 IF LO0T(1, <>96 THEN 6520 6500 ZED2=1 :: CALL POSITION(#17,YZ2,XZ2):: CALL POSITION(#1,YP,XP):: DET2=LO0T(2, :: IF XP<=XZ2 THEN ZED2=0 6510 GOTO 6940 6520 ZED2=0:: GOTO 6940 6530 IF YP<>129 THEN 6620 6540 IF LO0T(1,9)<>96 THEN 6570 6550 ZED1=1 :: CALL POSITION(#18,YZ1,XZ1):: CALL POSITION(#1,YP,XP):: DET1=LO0T(2,9):: IF XP<=XZ1 THEN ZED1=0 6560 GOTO 6580 6570 ZED1=0 6580 IF LO0T(1,10)<>96 THEN 6610 6590 ZED2=1 :: CALL POSITION(#19,YZ2,XZ2):: CALL POSITION(#1,YP,XP):: DET2=LO0T(2,10):: IF XP<=XZ2 THEN ZED2=0 6600 GOTO 6940 6610 ZED2=0:: GOTO 6940 6620 IF YP<>153 THEN 6710 6630 IF LO0T(1,11)<>96 THEN 6660 6640 ZED1=1 :: CALL POSITION(#20,YZ1,XZ1):: CALL POSITION(#1,YP,XP):: DDET1=LO0T(2,11):: IF XP<=XZ1 THEN ZED1=0 6650 GOTO 6670 6660 ZED1=0 6670 IF LO0T(1,12)<>96 THEN 6700 6680 ZED2=1 :: CALL POSITION(#21,YZ2,XZ2):: CALL POSITION(#1,YP,XP):: DET2=LO0T(2,12):: IF XP<=XZ2 THEN ZED2=0 6690 GOTO 6940 6700 ZED2=0:: GOTO 6940 6710 IF YP<>177 THEN RETURN 6720 IF LO0T(1,13)<>96 THEN 6750 6730 ZED1=1 :: CALL POSITION(#22,YZ1,XZ1):: CALL POSITION(#1,YP,XP):: DET1=LO0T(2,13):: IF XP<=XZ1 THEN ZED1=0 6740 GOTO 6760 6750 ZED1=0 6760 IF LO0T(1,14)<>96 THEN 6790 6770 ZED2=1 :: CALL POSITION(#23,YZ2,XZ2):: CALL POSITION(#1,YP,XP):: DET2=LO0T(2,14):: IF XP<=XZ2 THEN ZED2=0 6780 GOTO 6940 6790 ZED2=0:: GOTO 6940 6800 RETURN 6940 IF ZED1=0 AND ZED2=0 THEN 7100 6942 IF ZED1=1 AND ZED2=0 THEN 6975 6945 IF ZED1=0 AND ZED2=1 THEN 7005 6947 IF ZED1=1 AND ZED2=1 THEN 6975 Edited September 9, 2016 by matthew180 1 Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted September 9, 2016 Author Share Posted September 9, 2016 Sadly, learning line-number BASIC means you have a lot to un-learn <SNIP> 6940 IF ZED1=0 AND ZED2=0 THEN 7100 6942 IF ZED1=1 AND ZED2=0 THEN 6975 6945 IF ZED1=0 AND ZED2=1 THEN 7005 6947 IF ZED1=1 AND ZED2=1 THEN 6975 MATTHEW, thank you much for all this. I've moved tidbit several notches up my priority list. I guess that's the hard part for me. Getting rid of the line numbers and still writing in xb. Your examples of my code slow me to see the labels and how to write them. The light bulb is beginning to glow. Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted September 9, 2016 Author Share Posted September 9, 2016 On a side note, I've optimized all the code freeing up just over 3k before typing run. I'm now going through all the code again to see where I can replace repetitive routines with something more concise like a sub I can pass arguments to. But I need to know the limitations of that as far as global vs. local variables better. Heading out for some appointments, bringing my Extended BASIC book with me. Quote Link to comment Share on other sites More sharing options...
matthew180 Posted September 9, 2016 Share Posted September 9, 2016 Note: I use the term "BASIC" to refer to any ROM-based line-number BASIC dialect on early 80's home computers. There are modern "BASIC" dialects that are compiled or run very fast on modern computers; I am not talking about those variations. You have to be careful with line-number BASIC of any kind. When you are first learning it is fun because you can do a lot quickly. Then as you expand your code organically, the shortcomings of BASIC really start to come out. The simple lack of indentation prevents you from seeing any structure in your code and it starts to ramble. Soon, using GOTO to jump wherever you need to be in the code causes you to lose any benefit you were getting from trying to use subroutines, etc. It is actually harder, IMO, to write good code in line-number BASIC than in most other languages. Also, because these machines are limited in speed and other resources like memory they are not forgiving. You can't get away with things that you might on a modern computer with gigahertz of speed and gigabytes or RAM. Actions games and BASIC do not mix very well. BASIC makes the machine very accessible, but don't set your performance sights very high or try to make a huge application. Unfortunately reading the XB manual won't give you much insight into making good XB programs. You will know the syntax and what is available, but it does not explain how the language was meant to be used. As I mentioned before, this is the hard part of getting into a new language. You have to start thinking in the way that XB was designed to be used, with all the little quirks and nuances, and that takes a lot of time investment. The sad part is, your reward for the investment will always be less than you hope for (IMO) because of the speed and memory limitations of XB. This is why most people move on to something like Assembly, C, Forth, or Pascal. You do a lot of brute-force problem solving in your code, which is a really good way to dive in an start learning. But you are now at a point where improving the code requires significant effort and time, and it will start to become less fun. My suggestion would to not go there. It will kill your enthusiasm and the fun you are having. More simply, when it is not fun any more, stop. But only you can make that determination. 2 Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted September 9, 2016 Author Share Posted September 9, 2016 (edited) You do a lot of brute-force problem solving in your code, which is a really good way to dive in an start learning. But you are now at a point where improving the code requires significant effort and time, and it will start to become less fun. My suggestion would to not go there. It will kill your enthusiasm and the fun you are having. More simply, when it is not fun any more, stop. But only you can make that determination. This is part of the fun for me. Never taking any coding instruction, even with GML in GameMaker, I found it difficult to grasp rather simple concepts like arrays and passing arguments to scripts. Coming here and doing TI XB and I learned both concepts and am kind of embarrassed I didn't understand for so long. And now, I want to go and optimize my code. That daunting task is a challenge. When I push through now will certainly give me the motivation to never do that again. And in the end make me bettter. I'm far from being discouraged. Every day is getting more exciting. Here, let me show you something. I wrote my first ever sub program in XB that I actually took the time to plan out. It may not be perfect or as efficient as it can be. But it's a reduction in size from the original code. And if I got this correct and it works, I can easily crunch the heck out of my loot collision detection area simply by passing variables in to the script for processing. All the effort for me is designing that hand off. I know this isn't much, but it's huge to me. Here's the original code that was used from 2 areas of the main program using a gosub 970 call. ! ********jump routine check******** 970 CALL MOTION(#1,0,0)::IF CS<>-16 THEN 1020 990 CALL POSITION(#1,YP,XP)::GOSUB 1060 1010 GOTO 860 1020 IF CS<>16 THEN 1500 !goto jump right************************** 1030 CALL POSITION(#1,YP,XP)::GOSUB 1280 1050 GOTO 860 !*************jump left routine********* !joystick button pressed so STOP running 1060 CS=0 :: CALL MOTION(#1,0,CS)::CALL SPRITE(#1,CHSL,6,YP,XP) 1080 FOR PT=76 TO 80::CALL SOUND(1,191-PT,5)::CALL PATTERN(#1,PT)::NEXT PT 1120 CALL POSITION(#1,YP,XP)::IF XP<=24 THEN 1210 1140 CS=-20 :: YP=YP-3 :: RS=0 :: CALL SPRITE(#1,CHJL,6,YP,XP,RS,CS) 1150 FOR PT=81 TO 84::CALL PATTERN(#1,PT):: CALL SOUND(1,110+PT,5)::NEXT PT 1180 CS=0 :: CALL MOTION(#1,0,CS)::CALL POSITION(#1,YP,XP)::YP=YP+3 1210 CALL SPRITE(#1,CHLL,6,YP,XP)::FOR PT=85 TO 86::CALL PATTERN(#1,PT):: CALL SOUND(1,200-PT,5)::NEXT PT 1250 CALL POSITION(#1,YP,XP)::CS=-16::RETURN !*************jump right routine****** !joystick button pressed so STOP running right 1280 CS=0 :: CALL MOTION(#1,0,CS)::CALL SPRITE(#1,CHSR,6,YP,XP) 1300 FOR PT=39 TO 43::CALL SOUND(1,191-(PT+37),5)::CALL PATTERN(#1,PT)::NEXT PT 1340 CALL POSITION(#1,YP,XP)::IF XP>=224 THEN 1430 1350 CS=20 :: YP=YP-3 :: CALL SPRITE(#1,CHJR,6,YP,XP,RS,CS) 1370 FOR PT=64 TO 67::CALL PATTERN(#1,PT):: CALL SOUND(1,110+(PT+13),5)::NEXT PT 1400 CS=0 :: CALL MOTION(#1,0,CS)::CALL POSITION(#1,YP,XP)::YP=YP+3 1430 CALL SPRITE(#1,CHLR,6,YP,XP)::FOR PT=68 TO 69::CALL PATTERN(#1,PT):: CALL SOUND(1,191-(PT+11),5)::NEXT PT 1470 CALL POSITION(#1,YP,XP)::CS=16::RETURN And here is my optimized version using CALL JUMP(XP,YP,CHSL,CHSR,CHJL,CHJR,CHLL,CHLR) ! ********JUMP ROUTINE CHECK******** 2000 SUB JUMP(XP,YP,CHSL,CHSR,CHJL,CHJR,CHLL,CHLR) 2010 CALL MOTION(#1,0,0)::IF CS<>-16 THEN 2050 2020 CALL POSITION(#1,YP,XP)::G1=CHSL::G2=CHJL::G3=CHLL::N1=76::N2=80::JRD=0::JRD2=0::JCS=-20 2030 GOTO 2090 2040 SUBEXIT 2050 IF CS<>16 THEN subexit 2060 CALL POSITION(#1,YP,XP)::G1=CHSR::G2=CHJR::G3=CHLR::N1=39::N2=43::JRD=20::JRD2=17::JCS=20 2070 GOTO 2090 2080 SUBEXIT 2090 CALL MOTION(#1,0,0)::CALL SPRITE(#1,G1,6,YP,XP) 2100 FOR PT=N1 TO N2::CALL SOUND(1,191-(PT+37),5)::CALL PATTERN(#1,PT)::NEXT PT 2110 CALL POSITION(#1,YP,XP)::IF XP>=224 THEN 2160 2120 YP=YP-3 :: CALL SPRITE(#1,G2,6,YP,XP,RS,JCS) 2130 N1=(PT+1)+JRD::N2=(PT+4)+JRD2 2140 FOR PT=N1 TO N2::CALL PATTERN(#1,PT):: CALL SOUND(1,110+(PT+13),5)::NEXT PT 2150 CS=0 :: CALL MOTION(#1,0,CS)::CALL POSITION(#1,YP,XP)::YP=YP+3 2160 N1=(PT+1)::N2=N2+2 2170 CALL SPRITE(#1,G3,6,YP,XP)::FOR PT=n1 TO n2::CALL PATTERN(#1,PT):: CALL SOUND(1,191-(PT+11),5)::NEXT PT 2180 CALL POSITION(#1,YP,XP)::SUBEND I'm about to test this right now. =Success - not so much. Result.....(brb) I have to copy/paste...tic toc... - For-Next Nesting in 2000. Well, I'm going to get back to this... be back later... Edited September 9, 2016 by Sinphaltimus Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted September 10, 2016 Share Posted September 10, 2016 And now, I want to go and optimize my code. You probably got a plan for what to do or look for. You pick up breadcrumbs here and there. Turning and touching this and that in a learning process. Practice makes master. Program optimizations is, like most things, subjective. Try and quantize, and handpicked costs and benefits, and their weight is, subjective. ref.: https://en.wikipedia.org/wiki/Program_optimization Quote Link to comment Share on other sites More sharing options...
matthew180 Posted September 10, 2016 Share Posted September 10, 2016 This is part of the fun for me. Never taking any coding instruction, even with GML in GameMaker, I found it difficult to grasp rather simple concepts like arrays and passing arguments to scripts. Coming here and doing TI XB and I learned both concepts and am kind of embarrassed I didn't understand for so long. And now, I want to go and optimize my code. That daunting task is a challenge. When I push through now will certainly give me the motivation to never do that again. And in the end make me better. I'm far from being discouraged. Every day is getting more exciting. By all means, carry on! :-) Self learning is the best way, IMO. I think you will find a lot of people here taught themselves to code the same way, and on the same computer. I learned from the blue Beginner's BASIC book that came with the 99/4A, as well as typing in many many programs from computer magazines like COMPUTE!, as well as books. Reading code is one of the best ways to learn and you get to see how other people solve similar problems. Also, after typing in the programs you get curious and start to hack on them, learning the details of how and why they work. I highly recommend you spend some time typing in some programs that other people have written, you will learn more than you imagine. 1 Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted September 10, 2016 Author Share Posted September 10, 2016 (edited) I'm stuck right now. I have a for-next nesting situation with my sub program that I cannot for the life of me figure out. I think it's a gosub call early on, several jumps before the actual call sub that doesn't return until well after the call sub.I may post some new code for review. I think I'm going to need some help on this one. EDIT: Amazing, after a good night's sleep I find the problem in 10 minutes after getting started this morning. I love the human brain but I wish it did't have such lag (sleeping on it)... Edited September 10, 2016 by Sinphaltimus Quote Link to comment Share on other sites More sharing options...
Willsy Posted September 10, 2016 Share Posted September 10, 2016 (edited) I remember fighting an evil bug in some on site in Singapore. Couldn't find the problem. That night in bed in the hotel the solution came to me at three in the morning in a dream! I got dressed, down to the lobby, into a taxi and back to the factory. Had it working in five minutes! Edited September 10, 2016 by Willsy 2 Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted September 10, 2016 Author Share Posted September 10, 2016 (edited) Deconstructing XB for TidBit. OK Matthew180 Here's my original code that ran error free afaik: ZOMBtiV034F.txt My first step was to structure it as best i could in one run with labels. ZOMBtiV034FforTIDBIT_part1.txt After that, I went back in removed all the line numbers I could. The ones I couldn't, I created labels for. ZOMBtiV034_source.txt Then the output from TidBit ZOMBtiV034FforTIDBIT_part3.txt And there are a lot of bugs. So I think I'm going to stick with it. I can work out the bugs from here and easy start to really crunch my code down. Th'ere a lot of weird hings happening right now with some aspects of the game. I'm betting it's some changes i made along the way of stripping it down for TidBit. I was amazed the game ran and worked for the most part. Now I have a free an open source file to work from, without the need for line numbers and a very easy way to move things around and shrink them. Thanks for pushing me to use it. The hours and hours and hours it took me to do this, It's well worth it. It's where I should have started from. But who knew this was going to turn in to a game? I didn't. And now that it is, I'm in a much better position to complete the development and fix the issues thanks to the persistence of the members here. EDIT: Thanks to Matthew, he found some issues with my code pasted in to tidbit and the way tidbit dealt with it. I've cleaned it all up this morning but not in time to post before leaving for work. I'll test the new cleaner code when I get home later today. If all goes well I'll continue optimizing the code to free up more space for more code. Need to do zombie ai and coinc detections. So I'll need a bit of room for that. Edited September 11, 2016 by Sinphaltimus 4 Quote Link to comment Share on other sites More sharing options...
