WIP Battle Pong- Questions, Comments, Snide Remarks Welcome
67 replies to this topic
#51 BNE Jeff OFFLINE
BNE Jeff
    Moonsweeper
  • 320 posts
Posted Sun Feb 26, 2017 6:25 AM
Here's what I've come up with for the title screen 48 pixel image.  How's it look?
#52 TheHoboInYourRoom OFFLINE
TheHoboInYourRoom
    Moonsweeper
  • 361 posts
  • Whackadoo thingamajig
Posted Sun Feb 26, 2017 11:16 AM
Snazzy.
#53 BNE Jeff OFFLINE
BNE Jeff
    Moonsweeper
  • 320 posts
Posted Mon Feb 27, 2017 5:06 PM
So here it is in the title screen.  I wonder if its big enough.
Edited by BNE Jeff, Mon Feb 27, 2017 5:07 PM.
#54 SpiceWare OFFLINE
SpiceWare
    Draconian
  • 11,881 posts
  • Medieval Mayhem
Posted Mon Feb 27, 2017 5:11 PM
Looks good to me :thumbsup:
#55 TheHoboInYourRoom OFFLINE
TheHoboInYourRoom
    Moonsweeper
  • 361 posts
Posted Tue Feb 28, 2017 12:38 AM
I wonder if the logo might not be more visually imposing if you did it in a two-line kernel, to make the pixels more square like in your Excel screenshot.
But the one-line resolution looks good too in any case.
#56 BNE Jeff OFFLINE
BNE Jeff
    Moonsweeper
  • 320 posts
Posted Tue Feb 28, 2017 4:54 AM
That sounds good..  And I also think its good as is.  I think just having something up there is good for now because I still need to add other things.  I still need to add a little menu to select one or two players and maybe some other flair.  Speaking of that Excel spreadsheet, seeing it that big, I think converting this to PF graphics would look good too.
Darrell..  I noticed in Medieval Mayhem, you had to re-write a lot of the code for each individual 48 pixel graphic.  Why did you have to do that and not use a subroutine?  Was it because the graphics were different heights?
#57 SpiceWare OFFLINE
SpiceWare
    Draconian
  • 11,881 posts
  • Medieval Mayhem
Posted Tue Feb 28, 2017 9:21 AM
It's a dynamic menu, the extra code is determining things like which of the MORE indicators to display, such as bottom only:
Both:
Top only:
which options are shown (the menu scrolls), the color of the text (selected option & value are colored differently), and the value for each option. After each of those are figured out and prepped for, the Show48graphic subroutine is called to display it. Additionally paddle readings are taken during the menu.
Note: the "more" indicators are always displayed, they're just colored black when they're not needed:
#58 TheHoboInYourRoom OFFLINE
TheHoboInYourRoom
    Moonsweeper
  • 361 posts
Posted Tue Feb 28, 2017 10:13 AM
Of course. Better to get the functional stuff out of the way first.
#59 funkheld OFFLINE
funkheld
    Chopper Commander
  • 214 posts
Posted Thu Mar 23, 2017 7:12 AM
Why is this message coming?
greeting
#60 BNE Jeff OFFLINE
BNE Jeff
    Moonsweeper
  • 320 posts
Posted Sat Mar 25, 2017 5:23 AM
Hmm not sure, but it looks like you are trying to load the wrong file.  You need to load a .bin file-  BP1.bin.
#61 BNE Jeff OFFLINE
BNE Jeff
    Moonsweeper
  • 320 posts
Posted Sat Mar 25, 2017 5:41 AM
Thanks, I'll have to look at that..  but  I wasn't specific enough.  I'm referring to parts like this:
	lda #<Fireballs
        sta G48
	lda #>Fireballs
	sta G48+1
	lda #<(Fireballs+19)
        sta G48+2
	lda #>(Fireballs+19)
	sta G48+3
	lda #<(Fireballs+38)
        sta G48+4
	lda #>(Fireballs+38)
	sta G48+5
	lda #<(Fireballs+57)
        sta G48+6
	lda #>(Fireballs+57)
	sta G48+7
	lda #<(Fireballs+76)
        sta G48+8
	lda #>(Fireballs+76)
	sta G48+9
	lda #<(Fireballs+95)
        sta G48+10
	lda #>(Fireballs+95)
	sta G48+11
        ldy #18
Each graphic has its own indirect addressing setup like this.  Is there a way that "Fireballs" and the other names could be switched to a variable so this routine could be called for each graphic, not rewritten each time for Fireballs, etc?
#62 SpiceWare OFFLINE
SpiceWare
    Draconian
  • 11,881 posts
  • Medieval Mayhem
Posted Sat Mar 25, 2017 8:40 AM
Aha!
Looks like that's from an earlier build, that no longer exists in the latest source code for Medieval Mayhem.
I suspect that's from before the menu scrolled up/down and those instructions are being run while the menu is being drawn, so speedy performance would have been a requirement.  All of those values are pre-calculated by DASM, so every LDA takes just 2 cycles, while every STA takes 3, or 60 cycles (less than a scanline of processor time) to set all of them.   Any other option would take the 6507 longer to run (ie: a second scanline of time).
#63 BNE Jeff OFFLINE
BNE Jeff
    Moonsweeper
  • 320 posts
Posted Sun Mar 26, 2017 2:14 AM
Here's the latest version with a functioning start menu, and the 2 player version of the game functions as well.  Game can be selected with the joystick, and started by pressing fire or the reset switch.
I want to add music or sound as well.  Any suggestions?
  • Attached File  BP6.bin   4KB   37 downloads
Edited by BNE Jeff, Sun Mar 26, 2017 3:17 AM.
#64 tschak909 OFFLINE
tschak909
  • 2,126 posts
Posted Sun Mar 26, 2017 2:58 AM
This is easily turning into one of the most gonzo games i've ever seen. :)
-Thom
#65 BNE Jeff OFFLINE
BNE Jeff
    Moonsweeper
  • 320 posts
Posted Sat Apr 1, 2017 7:03 AM
Strange issue..  In Stella, the main menu works only the first time.  If I close Stella and then re-launch the game, it skips the menu and goes straight to the game.  Is there an issue with CLEAN_START or Stella?  Surely its not my code :)
#66 BNE Jeff OFFLINE
BNE Jeff
    Moonsweeper
  • 320 posts
Posted Sat Apr 1, 2017 7:18 AM
Hmm.  just discovered something:  I have .bin associated with Stella in Windows so I can just double click a bin and Stella launches.  That is where the issue appears.  If I run Stella and load the .bin from it, the problem doesn't happen.
#67 SpiceWare OFFLINE
SpiceWare
    Draconian
  • 11,881 posts
  • Medieval Mayhem
Turn off the randomize settings in Stella, found at the at the bottom of the TIA and I/O tabs.  If the problem clears up you're most likely missing a # somewhere.  See reply #17 for more info.
#68 BNE Jeff OFFLINE
BNE Jeff
    Moonsweeper
  • 320 posts
Posted Sat Apr 1, 2017 7:32 AM
Thanks- TIA random was off already.  I/O was on so I turned it off but that had no effect.  I'll have to start checking for missing #s.
Now I found this- When I re-launch the game via the associated .bin and the issue occurs, if I hit F3 and reload the ROM, it starts properly at the menu screen.
