moulinaie Posted August 14, 2016 Share Posted August 14, 2016 Hello! I'm testing the precision of the clock in the Atari TT. It looks like its precision is really bad! I set it precisely one hour ago, and now the difference is 30 seconds! 30 seconds / 1 hour = 0,8% Have you experienced the same or is it my particular TT that has problems? It's not a question of battery as the test has been made with the TT running during the whole hour. Guillaume. Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted August 14, 2016 Share Posted August 14, 2016 I guess that it's question of computer age. Maybe replacing crystal Y400 (32768 Hz) ? Or U402, U401 .. Quote Link to comment Share on other sites More sharing options...
guus.assmann Posted August 14, 2016 Share Posted August 14, 2016 It may very well be that it can be adjusted. On the much older MegaST, there's an adjustable capacitor. And the same on a MegaSTE. For these 2, I have a bare board and had a look. For the TT, I'm not sure. But it can very well be the case. (Check the schematics) If you can't find it, let me know and I'll try to invest some time to find out. And only if this fails, replace the Crystal. (Not 100% riskfree, adjustment = lower risk factor.) BR/ Guus Quote Link to comment Share on other sites More sharing options...
guus.assmann Posted August 15, 2016 Share Posted August 15, 2016 Hello Guilaume, Just now, I've checked the schematics for the TT. It uses the MC146818 clock chip. And an external clock generator, using a 4069 chip, U402. Only 2 gates A and B are used. Using this C-Mos chip gives a lower power consumption than having the MC146818 do the oscillator. (It can) The capacitor C408 is to be made adjustable. Crystal is Y400. BR/ Guus Quote Link to comment Share on other sites More sharing options...
moulinaie Posted August 15, 2016 Author Share Posted August 15, 2016 Thanks for the infos ! By the way, I have another question: on another TT the clock seems to be better. But on this one, when the computer is OFF, the clock and date are saved but don't advance! When I wake up the TT again, I get the time when I powered it off. Can it be a problem of battery this time? Not enough power to make it run ? Guillaume. Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted August 15, 2016 Share Posted August 15, 2016 You did not check battery ? In computer old some 25 years. Omg. Quote Link to comment Share on other sites More sharing options...
moulinaie Posted August 15, 2016 Author Share Posted August 15, 2016 You did not check battery ? In computer old some 25 years. Omg. I did : the old one was dead. I tried to change it with three accumulators 1,2V but I don't know if they are strong enough.. Quote Link to comment Share on other sites More sharing options...
