Is there a verson of this that will work with Android?
7 replies to this topic
#1 Larry OFFLINE
Larry
  • 4,100 posts
Posted Mon Aug 22, 2016 8:33 AM
And I don't mean Bluetooth -- instead, using a USB cable from the tablet or phone or maybe even a Chromebook?
-Larry
#2 Madi OFFLINE
Madi
    Moonsweeper
  • 383 posts
Posted Mon Aug 22, 2016 10:03 AM
There is one program (based on AspeQt) was developed by:greblus
AspeQt for Android (beta)
https://play.google.....example.AspeQt
https://github.com/greblus/aspeqt
madi
#3 Larry OFFLINE
Larry
  • 4,100 posts
Posted Mon Aug 22, 2016 1:20 PM
Thanks, Madi. That would be cool.  Quite a few folks say "I don't want to be tethered to a PC."  If this could work well with an Android phone/tablet and a RS232-USB converter that certainly would reduce the hardware requirements for "SIO2xxx" dramatically. I'll definitely check this out.  The Bluetooth option is nice, but I think this would be very useful and probably more reliable.
-Larry
#4 DrVenkman ONLINE
DrVenkman
  • 3,966 posts
  • Back off, man! I'm a scientist.
Posted Mon Aug 22, 2016 5:54 PM
-Larry
You probably can't beat an Android-based phone or tablet for portability that's for sure. But for my personal long-term solution, I have my RPi2 sitting in a cheapie case and use it for NOTHING except SIO2USB duties. I plan to spend another $85 or so at some point and pick up the Pi Foundation 7" touchscreen and case to mount it in, then set the whole thing right next to my A8 machines full-time, no need for an external monitor, keyboard or mouse.
#5 Larry OFFLINE
Larry
  • 4,100 posts
Posted Tue Aug 23, 2016 3:38 AM
Have any pics of your RPi2 setup?  The first thought that comes to mind with you present setup is how do you know what images are mounted and to which virtual drives? The display sounds like a good addition.
-Larry
#6 DrVenkman ONLINE
DrVenkman
  • 3,966 posts
Posted Tue Aug 23, 2016 5:58 PM
-Larry
For now, the RPi2 is just connected to an old LCD monitor, keyboard and mouse and boots into the usual Raspian X Windows desktop. My SIO2USB device is plugged into a free USB port. When I get the touchscreen and case, the whole thing will be self-contained.
#7 Larry OFFLINE
Larry
  • 4,100 posts
Posted Wed Aug 24, 2016 6:07 AM
I presume that you can now use the RespeQt software version "as-is?"  I.e. you don't have to use any terminal software emulation that I saw in some older threads?  Can this setup run at 3X SIO, or is it restricted to 1X?  I might try this myself -- sounds like it might make a good winter project.  Any useful threads that you would recommend on the current setup?
-Larry
#8 DrVenkman ONLINE
DrVenkman
  • 3,966 posts
Posted Wed Aug 24, 2016 1:56 PM
-Larry
I can't post links at the moment, but there are some posts in this subforum down the page in a thread about RespeQt on Raspberry Pi. Works great. Install the Qt stuff, download the source from Git, compile (about 10 minutes on an RPi2) and you should be good. The commands are even helpfully provided in the thread.
I can run at 3X no problem, and faster most of the time with custom tweaked timing options in the current development branch of the code.
EDIT: here you go.
RespeQt on Raspberry Pi?
https://r.tapatalk.c...75&share_type=t
Edited by DrVenkman, Wed Aug 24, 2016 1:58 PM.
Reply to this topic
