RSS Bot Posted August 23, 2016 Share Posted August 23, 2016 A while ago I was working on a project and needed to know where the Atari OS chose to create its graphics modes in memory. I ended up making a tool in BASIC XL that walks the current display list, and describes each ANTIC instruction. The output looks like this below. The example is a dump of the GRAPHICS 2 display list which includes a text window: "Value" is the Display List Instruction. "Gfx Line" counts the number of text or mode lines of actual graphics output by the display list. Blank line, LMS, and Jump instructions do not count as graphics lines. (Yeah, kind of useless. What was I thinking?) "Scan Lines" shows the starting scan line and ending scan line of the instruction as ANTIC outputs scan lines. "TV Scan Lines" reports the starting scan line and ending scan line of the instruction. The reason for the difference is that the Atari's scan line generator doesn't start until the 8th scan line of the television. "Description" is a text explanation of the ANTIC instruction plus any other options added to the instruction. If I were to do this again, I think I would add a screen memory counter to report the physical memory ANTIC outputs with the text or map modes. Here is the BASIC XL listing: And (Gmode<12))) Then Tmode=01130 Graphics Gmode+Tmode1135 Dl=Dpeek($0230)1140 Maxoffset=240*3:Rem MUST BE A LIMIT SOMEWHERE1145 M$="023456789ABCDEF":Rem MODES. $2 = "2"1150 Gline=0:Lastg=0:Rem CURRENT GFX LINE1155 Sline=0:Lasts=0:Rem SCAN LINE1160 Tline=7:Lastt=7:Rem TVSCAN LINE. FIRST ONE REPORTED WILL BE 8.1165 Scanlines=0:Rem SCAN LINES IN CURRENT INSTRUCTION1170 Jvb=0:Rem FLAG THAT JVB WAS SEEN TO END THE LOOP1175 Fname$=Dev$,"GR",Str$(Gmode+Tmode),"DL.TXT"1180 Open #1,8,0,Fname$1185 ? #1;"Disassembled Display List (GR";Str$(Gmode);1190 If (Tmode) Then ? #1;" + ";Str$(Tmode);1195 ? #1;")"1200 ? #1;"to its corresponding graphics line"1205 ? #1;"and Scan Line...":? #1:? #11210 ? #1;"DL Byte Value Gfx Line ";1215 ? #1;"Scan Line(s) ";1220 ? #1;"TV Scan Line(s) Description"1225 ? #1;"======= ===== ======== ";1230 ? #1;"============ ";1235 ? #1;"=============== ============"1240 For Loop=0 To Maxoffset1245 Rem DISPLAY LIST BYTE OFFSET1250 Vla=Loop:Gosub 1665:Rem DOHEX1AS3N31255 ? #1;" ";1260 Rem DISPLAY LIST BYTE VALUE1265 Dla=Dl+Loop1270 B=Peek(Dla)1275 Vla=B:Gosub 1700:Rem DOHEX1AS2N31280 Rem WHEN DUMPING ADDRESS BYTES1285 Rem SKIP THE REST OF THIS ... 1290 If (Dladr>0) Then Goto 1505:Rem SKIP REMAINDER OF PROCESSING1295 ? #1;" ";1300 Rem DISSECT INSTRUCTION1305 Dlins=B&$0f:Rem DL INSTRUCTION1310 Insmod=B&$f0:Rem INSTRUCTION MODIFIER1315 Rem TEST FOR JUMPS1320 If (Dlins=1):Rem PROBABLE JUMP1325 Rem FIELDS UP TO THE DESCRIPTION ARE BLANK.1330 ? #1;" ";1335 If ((B=$01) Or (B=$41)):Rem JUMP1340 Dladr=3:Rem JUMPS ARE 3-BYTE INSTRUCTIONS1345 If (B=$01):Rem DL JUMP TO ADDRESS1350 ? #1;"JMP - Jump To Address";1355 Else :Rem JUMP VERTICAL BLANK1360 ? #1;"JVB - Jump Vertical Blank";1365 Jvb=11370 Endif1375 Else :Rem ILLEGAL INSTRUCTION1380 ? #1;"Illegal Instruction";1385 Endif1390 Else :Rem BLANK LINES OR GFX LINES?1395 Rem TEST FOR BLANK LINES1400 If (Dlins<1):Rem A BLANK LINE INSTRUCTION1405 Rem GFX DATA LINE IS BLANK (OBVIOUSLY, SINCE NO RENDERED PIXELS)1410 ? #1;" ";1415 Scanlines=((Insmod&$70)/16)+1:Gosub 1615:Rem DOSCANLINES1420 Rem DESCRIPTION1425 ? #1;Scanlines;" Blank Line";1430 If (Scanlines>1) Then ? #1;"s";1435 Gosub 1830:Rem DOMODIFIERS1440 Endif1445 Rem DO REGULAR GRAPHICS LINES1450 If (Dlins>1):Rem EVERYTHING $2 TO $F1455 Scanlines=Scl(Dlins)1460 Gosub 1570:Rem DOGFXLINES1465 Rem DESCRIPTION1470 ? #1;"Mode ";M$(Dlins,Dlins);1475 Gosub 1830:Rem DOMODIFIERS1480 ? #1;" (";Scanlines;" Scan Line";1485 If (Scanlines>1) Then ? #1;"s";1490 ? #1;")";1495 Endif1500 Endif1505 ? #11510 If (Dladr>0) Then Dladr=Dladr-1:If (Jvb And (Dladr<1)) Then Loop=Maxoffset1515 Next Loop1520 ? #1:Close #11525 End1530 Rem1535 Rem DOGFXLINES1540 Rem FOR ANY NORMAL GFX MODE USING1545 Rem SCREEN RAM JUST INCREMENT THE1550 Rem LINE COUNTER. A BIT OF CHEATING1555 Rem HERE AS WE FALL THROUGH TO THE1560 Rem DOSCANLINES CODE ...1565 Rem1570 Gline=Gline+11575 Vla=Gline:Gosub 1700:Rem DOHEXAS2N31580 ? #1;" ";1585 Rem1590 Rem DOSCANLINES1595 Rem GIVEN THE NUMBER OF SCAN LINES1600 Rem UPDATE THE SCAN LINE COUNTERS1605 Rem AND PRINT THEM.1610 Rem1615 Sline=Lasts+1:Lasts=Lasts+Scanlines1620 Vla=Sline:Vlb=Lasts:Gosub 1765:Rem DOHEXPAIR1625 Tline=Lastt+1:Lastt=Lastt+Scanlines1630 Vla=Tline:Vlb=Lastt:Gosub 1765:Rem DOHEXPAIR1635 Return1640 Rem1645 Rem DOHEX1AS3N31650 Rem OUTPUT A NUMBER AS 3 DIGIT HEX, 3 DIGIT DEC1655 Rem INPUT = VLA1660 Rem1665 Ha$=Hex$(Vla)1670 Print #1; Using "/$!!! &&&",Ha$(2,4),Vla;1675 Return1680 Rem1685 Rem DOHEX1AS2N31690 Rem OUTPUT A NUMBER AS 2 DIGIT HEX, 3 DIGIT DEC1695 Rem INPUT = VLA1700 Ha$=Hex$(Vla)1705 Print #1; Using "/$!! &&&",Ha$(3,4),Vla;1710 Return1715 Rem1720 Rem DOHEXPAIR1725 Rem OUTPUT ONE OR TWO NUMBERS AS1730 Rem 2 DIGIT HEX, 3 DIGIT DEC1735 Rem IF SECOND NUMBER IS LESS THAN1740 Rem FIRST NUMBER, DO NOT OUTPUT1745 Rem THE SECOND NUMBER.1750 Rem INPUT = VLA1755 Rem INPUT = VLB1760 Rem1765 Ha$=Hex$(Vla)1770 Hb$=Hex$(Vlb)1775 If (Vlb>Vla):Rem OUTPUT BOTH1780 Print #1; Using "/$!! /- /$!! &&& /- &&& ",Ha$(3,4),Hb$(3,4),Vla,Vlb;1785 Else :Rem OUTPUT ONLY THE FIRST1790 Print #1; Using "/$!! &&& ",Ha$(3,4),Vla;1795 Endif1800 Return1805 Rem1810 Rem DOMODIFIERS1815 Rem OUTPUT TEXT OF MODIFIERS IF SET1820 Rem INPUT = INSMOD INSTRUCTION MODIFIERS1825 Rem INPUT = DLINS INSTRUCTION1830 If (Insmod&$80) Then ? #1;" + DLI";1835 If (Dlins>1):Rem REGULAR GRAPHICS1840 If (Insmod&$40) Then ? #1;" + LMS";:Dladr=3:Rem THIS HAS TWO TRAILER BYTES TO PARTIALLY IGNORE1845 If (Insmod&$20) Then ? #1;" + VSCROLL";1850 If (Insmod&$10) Then ? #1;" + HSCROLL";1855 Endif1860 Return1865 Rem1870 Rem HOPE FOR CLEANLINESS.1875 Rem TRAP ERROR AND CLOSE FILE.1880 Poke 82,0:Poke 710,0:Graphics 01885 ? "Trap Error ";Err(0);" at line ";Err(1)1890 List Err(1)1895 Trap 01900 Close #11905 End Below in tar and zip file formats is the source program, and the program's output for all the regular Atari OS text and graphics modes (rename .tar.gz.zip to .tar.gz): Source code: Display List Dumps: ------------------------------------------------------------------------------------------- 1 Corinthians 3:19 For the wisdom of this world is foolishness in God's sight. As it is written: "He catches the wise in their craftiness"; Attached File(s) EXAMDL.tar.gz.zip (5.71KB)Number of downloads: 0 EXAMDL.zip (8.45KB)Number of downloads: 0 DLDUMPS.tar.gz.zip (34.97KB)Number of downloads: 0 DLDUMPS.zip (60.1KB)Number of downloads: 0 http://atariage.com/forums/blog/576/entry-13247-dissecting-atari-display-lists/ 1 Link to comment Share on other sites More sharing options...
