unebonnevie Posted August 25, 2016 Share Posted August 25, 2016 (edited) Hi, I would like to construct a cartridge board so that I can press a button to reset the 5200. Is that possible? (I realize that I can hook up a button to the 6502C's /RESET pin, but I am not looking that route.) I read the below from http://www.atarimuseum.com/videogames/consoles/5200/conv_to_5200.html, but I am kind of not getting it. So, I put a digital 1 (5V) on the two interlock pins to do a reset system and digital 0 (0V) is not to reset the system? The cartridge ROM can be 32K bytes long and resides in memory from $4000 to $BFFF. Figure 4 shows the pinout of thecartridge slot. The two interlock connectors are wiredtogether on a cartridge board. The 5200 uses this as aswitch for the cartridge's power connections and as a Resetsignal. Therefore, a cartridge may be safely removed orinserted while the 5200 is powered on. D0 1 36 InterlockD1 2 35 A11D2 3 34 A12D3 4 33 A10D4 5 32 A13D5 6 31 A9D6 7 30 Audio In (2 port)D7 8 29 A8Enable 80-8F 9 28 Not ConnectedEnable 40-7F 10 27 A7Not Connected 11 26 +5V DCGround 12 25 GroundGround 13 24 Ground (Video In on 2 port)Ground (System Clock02 on 2 port) 14 23 GroundA6 15 22 A4A5 16 21 A3A2 17 20 A1Interlock 18 19 A0 Thanks! Edited August 25, 2016 by unebonnevie Quote Link to comment Share on other sites More sharing options...
Rybags Posted August 25, 2016 Share Posted August 25, 2016 The CI1 and CI2 pins are simply joined by a trace on a cartridge, having a switch that opens that circuit would perform the same function as removing the cart. Not sure though if that's a reset, might be more like a power down. You can trawl through this schematic, it's got the circuit around upper left corner: Quote Link to comment Share on other sites More sharing options...
Bryan Posted August 27, 2016 Share Posted August 27, 2016 The 5200 has a soft-power circuit that enables 5V to the board when the power button is pressed. This requires that the two interlock pins be joined by a cartridge. All you can do by breaking them is turn the console off. Quote Link to comment Share on other sites More sharing options...
