Help: Dumping Cartridges for dummies
28 replies to this topic
#26 santosp OFFLINE
santosp
    Dragonstomper
  • 755 posts
Posted Wed May 23, 2018 8:19 PM
I made a video to show how its done
Nir
Nir your video not appear anymore online. I hope to not reported as illegal from some heat head!
Edited by santosp, Wed May 23, 2018 8:19 PM.
#27 Marsupilami OFFLINE
Marsupilami
    Chopper Commander
  • 125 posts
  • looking 4 Atari FR/DE/BX/IT software
Posted Wed May 23, 2018 9:48 PM
I convert the .rom file to .car, and load it on eclaireXL within cartridge loader.
The cartridge load normally, and choosing the "I" option I see in my screen "Gerat nicht angeschlossen - Prufen!" message.
Not some error.
Thanks @santop. That's the "error" message it should gives (the one with the real cartridge on a real 800xl).
But it's not the message i have in Altirra so i guess Altirra (windows version) is a bit sensitive with the .ROM file.
At least your test shows that my dump is good :)
Edited by Marsupilami, Wed May 23, 2018 9:56 PM.
#28 phaeron OFFLINE
phaeron
  • 2,458 posts
Posted Wed May 23, 2018 10:30 PM
The crash with the garbage at the bottom appears to be a bug in the cartridge that manifests if you have the H: device enabled in the emulator and have also enabled the non-default option to also install it as D:.
The bug is that the cartridge's init routine checks for a D: device, and if it finds one, attempts to patch it. Problem is, it revectors D: in HATABS to garbage in the middle of the ROM, which causes a crash. This is done at the same time that E: is patched, so it was probably a remnant of an early attempt at putting DOS on-cart. If you boot DOS off of a disk, this doesn't happen because DOS adds the D: device after cartridge init has occurred. But if it's already there... kaboom.
#29 ndary OFFLINE
ndary
    Moonsweeper
  • 499 posts
Posted Wed May 23, 2018 10:45 PM
not sure why the link changed.. here is the new link:
Nir
