Turbo Laser Lynx Posted September 11, 2016 Share Posted September 11, 2016 (edited) Hi! I'm trying to add another segment to my new demo-cart built upon pegsolitaire from here: http://atariage.com/forums/topic/256571-learning-lynx-coding-by-hacking-pegsolitaire/ Any help or pointer in the right direction appreciated. Let me know if you need more files 'n' stuff Ok so I made a new folder named maija where my other game demo will recide. At this point I just want to show one 160x102 image. I mimiced everything from pegsolitaire (except pegsolitaire.h), put up all the new stuff in the make files and added maija to lynxcart.cfg directory.s etc. the original segments work, intro and pegsolitaire, but when I try to load in my new segment handy crashes. Again I've tried to mimic everything perfectly. Could the problem be that I get a whole bunch of warnings of duplicate external identifiers? e.g. ld65: Warning: Duplicate external identifier: `_stop_music' ld65: Warning: Duplicate external identifier: `_start_music' etc... I don't think I see anything wrong with the segments here: (I attached cart.map) Segment list: ------------- Name Start End Size Align ---------------------------------------------------- DIRECTORY 000000 000017 000018 00001 EXEHDR 000000 00003F 000040 00001 ZEROPAGE 000000 000019 00001A 00001 EXTZP 00001A 000032 000019 00001 APPZP 000033 000039 000007 00001 BOOTLDR 000200 0002CA 0000CB 00001 INTRO_CODE 000200 0003B8 0001B9 00001 MAIJA_CODE 000200 000373 000174 00001 PEGSOLITAIRE_CODE 000200 0008C8 0006C9 00001 MAIJA_RODATA 000374 00096E 0005FB 00001 INTRO_RODATA 0003B9 001108 000D50 00001 PEGSOLITAIRE_RODATA 0008C9 00308C 0027C4 00001 MAIJA_DATA 00096F 0009AF 000041 00001 MAIJA_BSS 0009B0 0009CD 00001E 00001 INTRO_DATA 001109 001142 00003A 00001 INTRO_BSS 001143 001148 000006 00001 PEGSOLITAIRE_DATA 00308D 00330D 000281 00001 PEGSOLITAIRE_BSS 00330E 00332B 00001E 00001 STARTUP 005C40 005CBC 00007D 00001 INIT 005CBD 005CEB 00002F 00001 CODE 005CEC 007A2D 001D42 00001 RODATA 007A2E 00845D 000A30 00001 DATA 00845E 008576 000119 00001 BSS 008577 0086D5 00015F 00001 In the cart makefile: cart.lnx : \ directory.o \ ../resident/resident.o \ ../resident/soundbs.o \ ../resident/fadein.o \ ../resident/fadeout.o \ ../intro/intro.o \ ../intro/bg.o \ ../intro/title.o \ ../maija/maija.o \ ../maija/bgm.o \ ../maija/track2.o \ ../pegsolitaire/pegsolitaire.o \ ../pegsolitaire/bga.o \ ../pegsolitaire/track2.o \ ../pegsolitaire/square.o \ ../pegsolitaire/bgb.o $(MAKE) -C ../resident $(MAKE) -C ../intro $(MAKE) -C ../maija $(MAKE) -C ../pegsolitaire In lynxcart.cfg __BANK1SIZE__: type = weak, value = $3A40; __BANK7SIZE__: type = weak, value = $5A40; __BANK8SIZE__: type = weak, value = $5A40; ... # Peg solitaire code PEGSOLITAIRE_CODE: load = BANK7, type = ro, define = yes; PEGSOLITAIRE_RODATA: load = BANK7, type = ro, define = yes; PEGSOLITAIRE_DATA: load = BANK7, type = rw, define = yes; PEGSOLITAIRE_BSS: load = BANK7, type = bss, optional = yes; #Maijas data diskette MAIJA_CODE: load = BANK8, type = ro, define = yes; MAIJA_RODATA: load = BANK8, type = ro, define = yes; MAIJA_DATA: load = BANK8, type = rw, define = yes; MAIJA_BSS: load = BANK8, type = bss, optional = yes; ... .import __PEGSOLITAIRE_CODE_LOAD__ .import __PEGSOLITAIRE_CODE_SIZE__ .import __PEGSOLITAIRE_DATA_SIZE__ .import __PEGSOLITAIRE_RODATA_SIZE__ .import __MAIJA_CODE_LOAD__ .import __MAIJA_CODE_SIZE__ .import __MAIJA_DATA_SIZE__ .import __MAIJA_RODATA_SIZE__ ... ; The 2nd entry is the entertainment module that we run at startup entry off0, len0, off1, block1, len1,__INTRO_CODE_SIZE__+__INTRO_RODATA_SIZE__+__INTRO_DATA_SIZE__, __INTRO_CODE_LOAD__ ; The 3rd entry is the 1st game level we want to run. entry off1, len1, off2, block2, len2, __PEGSOLITAIRE_CODE_SIZE__+__PEGSOLITAIRE_RODATA_SIZE__+__PEGSOLITAIRE_DATA_SIZE__, __PEGSOLITAIRE_CODE_LOAD__ ; The 4th entry should come here. It could be the 2nd level to run or data... entry off2, len2, off3, block3, len3, __MAIJA_CODE_SIZE__+__MAIJA_RODATA_SIZE__+__MAIJA_DATA_SIZE__, __MAIJA_CODE_LOAD__ cart.map.txt Edited September 11, 2016 by Turbo Laser Lynx Quote Link to comment Share on other sites More sharing options...
+karri Posted September 12, 2016 Share Posted September 12, 2016 If you want to share start_music() and stop_music() then they should go to the resident directory. If these codes are local you should mark them local: Instead of void stop_music() { write static void stop_music() { then the routine is not exported outside this file and you get no error warnings. Quote Link to comment Share on other sites More sharing options...
Turbo Laser Lynx Posted September 12, 2016 Author Share Posted September 12, 2016 Thanks so much! Will try this tonight. Quote Link to comment Share on other sites More sharing options...
Turbo Laser Lynx Posted September 12, 2016 Author Share Posted September 12, 2016 (edited) Heureka! I finally made it, it only took me 12 years. The whole cart is mine, muhahaha! I'm so going to celebrate this with a Pommac tomorrow! I should send you a bottle too. At least You'll get a free copy of my first released Lynx game-mix when that time comes. Karri allow me to write you a program: 10 Print "THANK YOU!" 20 Goto 10 RUN Edited September 12, 2016 by Turbo Laser Lynx Quote Link to comment Share on other sites More sharing options...
