Jeffrey Bouchard Posted September 22, 2016 Share Posted September 22, 2016 Has anybody used Launchbox with JZINTV? I have tried to set it up on my computer, however, it does not seem to do anything. I had it running in the past but unfortuntly, something happened to it. Would really like to have this running as this seems like a good compromise until/if the LTO Flash GUI can be used as a launcher. Thank you very much for your time. Quote Link to comment Share on other sites More sharing options...
+fdr4prez Posted September 23, 2016 Share Posted September 23, 2016 I use the Windows GUI for jzintv. Works well enough for me. You can get it here: http://www.intellivision.us/intvgames/jzintv/jzintv.php That contains the GUI and an older version of jzintv, so after you install it then you can go and grab the latest "Current Stable Dev Version" from Joe's site: http://spatula-city.org/~im14u2c/intv/ Just unzip the files and overwrite the ones that were installed with the GUI. Quote Link to comment Share on other sites More sharing options...
Jeffrey Bouchard Posted September 23, 2016 Author Share Posted September 23, 2016 Thank you very much. I have tried that in the past, hopefully, I can make it work again. Quote Link to comment Share on other sites More sharing options...
+fdr4prez Posted September 23, 2016 Share Posted September 23, 2016 I am using Win7 64-bit. I don't know if any other members have tried anything newer. Quote Link to comment Share on other sites More sharing options...
mr_me Posted September 23, 2016 Share Posted September 23, 2016 (edited) Has anybody used Launchbox with JZINTV? I have tried to set it up on my computer, however, it does not seem to do anything. I had it running in the past but unfortuntly, something happened to it. Would really like to have this running as this seems like a good compromise until/if the LTO Flash GUI can be used as a launcher. Thank you very much for your time.Yes, it works. Do you have exec.bin and grom.bin in the jzintv\rom folder? Check if your game rom files or jzintv has moved since you last set it up. Check the jzintv command options for things like an invalid keyboard hackfile. Edited September 23, 2016 by mr_me Quote Link to comment Share on other sites More sharing options...
mr_me Posted September 23, 2016 Share Posted September 23, 2016 I am using Win7 64-bit. I don't know if any other members have tried anything newer. Jzintv seems to have a minor issue with Windows 10. When you switch from full screen to window or window to full screen (its one or the other not both) it crashes. Quote Link to comment Share on other sites More sharing options...
Utopia Posted September 23, 2016 Share Posted September 23, 2016 Jzintv seems to have a minor issue with Windows 10. When you switch from full screen to window or window to full screen (its one or the other not both) it crashes. Interesting, My Windows 10 installation does not have a option to go full screen. Quote Link to comment Share on other sites More sharing options...
mr_me Posted September 23, 2016 Share Posted September 23, 2016 Interesting, My Windows 10 installation does not have a option to go full screen. Some laptops remap the function keys so by default F9 might do something else. Quote Link to comment Share on other sites More sharing options...
Jeffrey Bouchard Posted September 23, 2016 Author Share Posted September 23, 2016 The files were moved since last I set it up. All works now except my kbdhackfile. Any help would be appreciated. Thank you. Quote Link to comment Share on other sites More sharing options...
mr_me Posted September 23, 2016 Share Posted September 23, 2016 Use LaunchBox Manage Emulators to check that the keyboard hackfile is being specified in the command-line parameters (ie. "--kbdhackfile=c:\jzintv\kbdhackfile.kbd" ). If it is than tell us what button mappings aren't working. Quote Link to comment Share on other sites More sharing options...
+fdr4prez Posted September 23, 2016 Share Posted September 23, 2016 Interesting, My Windows 10 installation does not have a option to go full screen. F9 should toggle between window mode and full screen mode. If you aren't interested in toggling, but want full screen mode, then in the GUI you can click on the full screen checkbox: If you are not using the GUI, then you can put -x1 in the command line. The GUI adds this after the -z1 (or whatever resolution you set): Quote Link to comment Share on other sites More sharing options...
