SpartaDOS - Early Versions
Disk Images ATR Manual PDF Scan
128 replies to this topic
#126 Alfred OFFLINE
Alfred
    Dragonstomper
  • 557 posts
Posted Wed Mar 13, 2019 5:54 PM
BTW, what is the ICD XASM65 assembler, noted in the comments? I don't think I've ever heard of that before. Does it have any relation to the Avocet cross-assembler products?
I don't think so. Best I know, xasm65 is just the assembler that Gustafson wrote for ICD. I seem to have source for three different versions, the last being 1.4. I just noticed that myself when I was looking over your post, which begs the question, what were they using before Mike wrote that assembler ? Anyway, it all works, the assembler and the linker. The linker will produce standard Atari binary files, although oddly it names them with a .ATR extender. I would have thought he would make it default to .COM, but perhaps they used the same linker for building ST products and wanted an easy method of distinguishing the binaries.
I suppose 3.5 could be fixed, but why bother ? It doesn't offer anything over normal SpartaDos.
#127 MrFish ONLINE
MrFish
  • 5,474 posts
Posted Wed Mar 13, 2019 6:16 PM
OK, maybe just coincidence about using the same name.
So, an ICD in-house development tool. I'd love to have a look at that. Have you actually used it much yourself?
Good question ("what were they using before XAsm65?")... Mac/65?
I don't use SpartaDOS (any variety), and have no plans to in the future. I barely need any DOS for what I do, and
when I do, DOS 2.5 or whatever is sufficient. I'm mainly interested in it for preservation and to have a look at
something from a producer of great products. It's kinda like prototype games: some may not be very complete or
even very interesting, but still unique pieces of history for Atari software.
I agree, I don't see much point in rushing to fix 3.5a (although somebody else may think so), but, if a version 3.5
exists that does function properly, then I'd be very interested in checking it out and seeing it preserved. I suppose
being that it's a disk version too, some may be interested in the final disk version for actual use -- seeing that some
favor disk versions of SpartaDOS for their particular setups.
#128 Alfred OFFLINE
Alfred
    Dragonstomper
  • 557 posts
Posted Wed Mar 13, 2019 6:26 PM
No, I have never used it myself. There's no doc for it, since of course Mike would already know. It use an odd (to me) structure where every routine is labelled as a "procedure" like this:
; dir_mode
;    B[7]: 1 = put size and TD and end of line
;    B[6]: 1 = Include attributes after filename
;    B[5]: 1 = Put space between filename and extension
;    B[4]: 1 = Replace above space with a '.'
;    B[3]: 1 = Space over 2 for filename
;    B[2]: 1 = 24 Hour clock
;    B[1]: 1 = skip seconds on time field
;    B[0]: 1 = put # sectors and end of line ('DIR' if dir)
    seg    c_file
;    Create displayable directory entry
; in:
;    dentry    = directory entry to process
;    dir_mode= directory display mode flag
; out:
;    ebuf    = buffer containing directory entry
format_dir_entry: proc
    jsr    clebuf        ; clear output buffer...
    ldy    #0
    lda    #8
    bit    dir_mode
    beq    ..fd1
     lda    dentry+DEsta    ; if to skip first space, then
     and    #DESpro        ;  put protected flag there!
     beq    ..npro
      lda    #'*'
      sta    ebuf,y
..npro     ldy    #2        ; space over 2 for filename
..fd1    ldx    #0
..nam    lda    dentry+DEfnam,x    ; move entry name to buffer
    sta    ebuf,y
    iny
    inx
    cpx    #8        ; at ext pos?
    bne    ..ext        ;  jump if not
    lda    #32
    bit    dir_mode    ; if 0, then no space before ext
    beq    ..ext
     lsr    a
     bit    dir_mode    ; if 0, then insert a space
     beq    ..spc
      lda    #'.'        ; else insert a period
      sta    ebuf,y
..spc     iny
..ext    cpx    #11
    bne    ..nam        ; jump if not at end
    bit    dir_mode    ; if 0, then no attributes in display
    bvc    ..nattr
     iny
     jsr    attributes
..nattr    bit    dir_mode
    bpl    ..nlong        ; if 0, then not long dir listing
     iny
     jmp    size_and_td    ;  else include size and time/date
..nlong    lda    #1
    and    dir_mode
    beq    ..xit
     iny
     jmp    number_sectors
..xit    rts
    endproc
The worse problem is not knowing how the linker works, how the directives for mapping the final object file work etc. So I never bothered.
I can't imagine a working 3.5 exists. I mean, AFAIK there's only three people alive who might still have a copy of the source: Me, Hohman and Gustafson. And I don't think those two have their copies any more.
#129 MrFish ONLINE
MrFish
  • 5,474 posts
Posted Wed Mar 13, 2019 6:38 PM
I wouldn't expect any formal documentation; but, yeah, it seems entirely possible that none ever existed for it.
Still very interesting -- at least to me.
OK, I expected something like that to be the case. Still very cool to see that someone has this orphaned version, at least in some form. Thanks for sharing; it's great information.
Also tagged with one or more of these keywords: Disk Images, ATR, Manual, PDF, Scan
