Cat Quest 2600 (WIP)
furry adventure rpg catgirl
27 replies to this topic
#1 Alp OFFLINE
Alp
    Space Invader
  • 45 posts
Posted Sat Oct 1, 2016 6:26 PM
Lately, I've had the idea of porting a cancelled NES game of mine, to the Atari 2600, just for fun.
I'm perfectly capable of coding this game in ASM, but unfortunately, the Stella emulator hates my computer (Open GL), so this will be Art / Design Notes, for now. No ROM tests, unfortunately. :(
After some reading, I've opted to use the "venetian blinds" interlacing technique, to potentially minimize sprite flickering. This also works surprisingly well with what I've designed for screens!
This is the current look of the title screen, though I've apparently made the text a few pixels too wide? I'll fix that, when I have some free time, to do so.
The visual design of the dungeons is heavily inspired by the Legend of Zelda. Slay Monsters, find Keys, unlock Doors, and kill a Boss enemy. You know, the basics.
I'm not sure how well this boss would work at the moment. But it would ideally function similarly to the Giant Snake boss, from StarTropics. Even leaving it's bones in the "Triforce Room", when it's slain.
(It sits in the doorway, wiggling it's body segments, occasionally spitting a fireball, to attack.)
The outdoors have barely been started, but I had fun with making this first dungeon! The visual theme is a castle, with a moat. Can you see how the colors are used?
Lastly, the caves in the world, will be dark without a lamp. They'll be traversable as you can see, but the monsters will be completely invisible! It's best not to get caught, stumbling around in the dark.
At the moment, I have 8-byte background "tiles" defined, with a multi-color option, that doubles the data size. These tiles are 32x32 blocks, with each color row defined in a single nibble.
I have some basic data structures defined, in an attempt to write fast tile-mapping, on this hardware.
Colors are swapped out, every other scanline, to allow for 2-color map screens. Potentially more, if a screen has sectors defined (such as the castle moat, in my mock-up, for example.)
I'm not really sure what would need to be cut back for this project. But for now, it's just a fun distraction from a NSFW RPG that I'm developing, with a friend of mine! :P
Thoughts are welcomed. Tear this ambitious idea to shreds, yo!
#2 Papa OFFLINE
Papa
    Dragonstomper
  • 751 posts
Posted Sat Oct 1, 2016 6:42 PM
WOW!  That game looks fabu..uh.. Really awesome!
These are just mock up screens right?  Is this playable?
I've been thinking of a Zelda-like game for some time using the DPC+ kernel in VisualBatariBasic and I like what this looks like a lot!   I don't think I would be nudging or prodding you at all to still do my own above head game as mine is quite a departure from The Legend of Zelda and also not a kyewt kitteh 'venture!
So you've got your graphics in binary externally?  This reminds me of what might be done with TinyBasic.
OH...and on thoughts about what could be done different:
1. nothing
2. maybe two sprites overlapping for a couple more colors!?!
Edited by Papa, Sat Oct 1, 2016 6:44 PM.
#3 Shawn OFFLINE
Shawn
    As Above
  • 18,852 posts
  • So Below
Posted Sat Oct 1, 2016 6:54 PM
This game would be much better suitedf for the Atari 7800 (please) :grin:
#4 Papa OFFLINE
Papa
    Dragonstomper
  • 751 posts
Posted Sat Oct 1, 2016 7:12 PM
But it would totally blow peoples minds on the VCS!
On the 7800 it could be done BETTER (* begins briskly walking away while reaching into coat pocket...)
THAN on the NES!!   :thumbsup:
#5 TrekMD OFFLINE
TrekMD
  • 3,938 posts
Posted Sat Oct 1, 2016 8:41 PM
That looks fantastic!  Very impressive.
#6 ZackAttack OFFLINE
ZackAttack
    Dragonstomper
  • 761 posts
Posted Sat Oct 1, 2016 9:31 PM
The venetian blinds will work fine for the background graphics (PF) but for the sprites it may impose too many limitations. Repositioning the sprite each scanline can only be done via HMOVE and that can only shift the position 7 or 8 pixels.
I'd also be concerned about getting that much data to the TIA. Asymmetric PF is 6 PF? writes. Both sprites will need the move, graphics, and color registers set. That's 6 more register writes. Move strobe brings the total to 13 and I probably missed something. So 76 cycles to update 13+ registers. The only way that could work is to use LDA immediate and STA ZP pairs. 13 * (2 + 3) = 65 cycles.
The next problem would be address space. Each scanline would consume 13 * (2 + 2) + 11 = 63 bytes. 192 * 63 = 12096 bytes of RAM to hold the entire screen. That's 6 2K RAM pages. Looks like those remaining 11 cycles will be used to bank switch to the next RAM page.
The final problem would be updating 12KB of RAM in overscan/vblank. Only the immediate value needs to be updated so it's only 13 bytes per scanline. 192*13=2496. The best thing to do here is just draw a black screen and dedicate all CPU resources to updating the screen buffer for a couple of frames.
With the 3E bank scheme I think this project could be feasible. You would just have to be very careful about where sprites can and can't go.
#7 Thomas Jentzsch OFFLINE
Thomas Jentzsch
    Thrust, Jammed, SWOOPS!, Boulder Dash, THREE·S, Star Castle
  • 23,972 posts
  • Always left from right here!
Posted Sun Oct 2, 2016 4:04 AM
I'm perfectly capable of coding this game in ASM, but unfortunately, the Stella emulator hates my computer (Open GL)...
icon_idea.gif Try TAB/Video Settings/Render = Software or Direct3D
#8 atari181 OFFLINE
atari181
  • 3,458 posts
Posted Sun Oct 2, 2016 8:21 AM
Looks amazing. Great job!
#9 Alp OFFLINE
Alp
    Space Invader
  • 45 posts
Posted Mon Oct 3, 2016 12:20 PM
1. nothing
Yeah. This project is just carefully constructed mockups for now. (and some rough code in a text file)
The graphics are indeed stored in a file! They look like this, in my document:
(I typed everything out in hexadecimal, for legibility.)
On the VCS, overlaid sprites would be overkill. I'd rather spend that space on the monsters and items.
I had actually experimented with multicolor sprites, to see how it would look while prioritizing depth/volume. It looks okay, I guess. But I'm not sure I like it. I may just stick with monochrome sprites.
Coincidentally, I had planned 2 Cat Quest games for the NES, and their eventual sequel, to be 16-bit (for obvious reasons) The console for the 3rd game was never decided on.
The 1st? A Legend of Zelda clone, utilizing the bare bones the NES has to offer (NROM Mapper), while presenting a much larger game! Suck it Nintendo! :P
It was a little more than half done, when I scrapped the project. I decided that the NES homebrew community are butts, and that I'd rather not waste my time with the likes of them.
The 2nd? A Wonderboy clone, with an Zelda II-like Overworld, a marriage of elements from both games.
...and the 3rd was planned to be a straight clone of A Link to the Past. Of course! :P
If the scale of my cancelled NES game blew people's minds, just imagine what I could do on the VCS! :D
I have no doubt that it would look nicer on the 7800. Though, I have no experience with that machine. Coding, or otherwise. My only Atari experience was with the 2600, when I was a child.
Hmm... venetian blinds are less ideal then? Alright, I can always revert the sprites back to solid color.
Honestly though, I kind of liked how it made the sprites match the style of the background. >.>
...and a mockup of the Dragon boss in action, because why not? :P
I've been carefully planning out a display kernel, that's as unrolled as I can get it, for speed purposes.
I'd ultimately be fine with adding some RAM for this game, but I'd otherwise rather stick with stock hardware, just for fun.
I could possibly lower the vertical resolution a tad, without losing too much detail? I may try that.
Yeah. Drawing colors over a black screen, is exactly what I had in mind, when I made the background color universally black. I do that with my 8-bit pixel art as well, to squeeze out more detail, with less.
I have no problem with restricting sprite location, I had planned for the game to be a bit slower paced.
Huh, I'm not sure what you mean? Stella throws up a display error, and closes, without even opening a window!
I found the Z26 emulator, and that seems to work. But it's severely out of date? Hmm...
#10 Thomas Jentzsch OFFLINE
Thomas Jentzsch
  • 23,972 posts
Posted Mon Oct 3, 2016 12:24 PM
Then try this command line parameter:
-video <direct3d|opengl|opengles2|opengles|software>
#11 Papa OFFLINE
Papa
    Dragonstomper
  • 751 posts
Posted Mon Oct 3, 2016 2:08 PM
Z26 is fun but won't support games made with the DPC+ kernel.  I use it on older systems sometimes.
#12 Janzl OFFLINE
Janzl
    Chopper Commander
  • 197 posts
Posted Mon Oct 3, 2016 2:39 PM
Looks really promising! :)
#13 Kitty OFFLINE
Kitty
    Combat Commando
  • 1 posts
Posted Tue Oct 4, 2016 4:57 AM
Looks lovely, It's a shame you abandoned the NES version, the screens looked so lovely icon_tears.gif
Edited by Kitty, Tue Oct 4, 2016 8:28 AM.
#14 Gemintronic OFFLINE
Gemintronic
    Jason S. - Lead Developer & CEO
  • 9,314 posts
Posted Wed Oct 5, 2016 3:38 PM
What works in hardware is sometimes completely different from initial concept art.  I'd consider getting your display kernel up and going.  If only to prove to yourself the time investment is worth it.
#15 Jinroh OFFLINE
Jinroh
    Dragonstomper
  • 697 posts
  • Catgirl Maid Lover
Posted Wed Oct 5, 2016 8:01 PM
Mockups look really great. :) Nice to see more kitties on the VCS.
#16 Alp OFFLINE
Alp
    Space Invader
  • 45 posts
Posted Thu Oct 6, 2016 4:18 PM
Eh... Nintendo Age sucks, I'll say that much!
I've considered porting the cancelled NES version to Windows, relatively unchanged, but I don't really have the time, right now.
I'm also working on a NSFW parody of Hydlide, on the NES. We're keeping the "bumping" mechanics, if you were curious! :P
I'm way ahead of you there!
I'm already knee deep in the dead code, setting up my playfield line-drawing routine. It's going to be really ugly, but I think it'll work!
This isn't the first time I've needed to write fast, scanline-timed code. I've done "impossible" parallax scrolling on the NES, too! :P
The object-code, for updating everything in this game (including the player) is already finished-- at a mere 10 lines of ASM! :o
Yes! Cats are just awesome. This particular feline is my mascot of-sorts, in the furry community.
She originated in an Elder Scrolls-like RPG, from back in the day, as the default female build.
#17 TheHoboInYourRoom OFFLINE
TheHoboInYourRoom
    Moonsweeper
  • 416 posts
  • Whackadoo thingamajig
Posted Fri Oct 7, 2016 4:41 PM
Ooh, neat. This looks like a project worth following.
#18 Shawn OFFLINE
Shawn
    As Above
  • 18,852 posts
  • So Below
Posted Fri Oct 7, 2016 4:55 PM
Isn't that much on the screen at once gonna be a flicker-fest on the 2600?
#19 SpiceWare OFFLINE
SpiceWare
    Draconian
  • 12,684 posts
  • Medieval Mayhem
Posted Fri Oct 7, 2016 6:09 PM
"venetian blinds" work for specific cases, such as video chess where the pieces don't move around:
or in stampede where the legs on the horse don't move independently from each other:
But they're not useful for arbitrary sprites that move around on their own.
you could add the missiles and ball to turn a 48 pixel display into 51. The missiles will be in triplicate though, so would need to be hidden behind the playfield (set playfield to have priority, then color it black). Alternatively, if you accept the use of flicker you can make the title screen much wider:
Your status line is going to be ticky, will probably have to make some concessions there.
Your playfields with the alternating scanline colors work well with the limitations of the Atari. You can also make use of adjacent rows to simulate a 3rd color - the platforms on this level of Timmy! are drawn using Purple and Green, but they come across as something else:
I don't see that many moveable objects in the mockups, shouldn't be any worse than Ms. Pacman.
#20 Lazycow OFFLINE
Lazycow
    Space Invader
  • 13 posts
Posted Sat Oct 8, 2016 12:44 PM
Very promising mockups!
What about reducing the amount of black lines, e.g. like this:
Also, I think some of the figures have too many color changes. The cat (?) at the bottom is perfect, though.
#21 InsertCoin25 OFFLINE
InsertCoin25
    Space Invader
  • 39 posts
Posted Tue Oct 11, 2016 11:09 AM
This looks amazing Alp!! Please see this game through. Leaving it on the 2600 is wise, in my humble opinion. Great work so far!!
#22 iesposta OFFLINE
iesposta
  • 3,889 posts
  • Retro-gaming w/my VCS
Posted Sat Oct 22, 2016 8:34 AM
I don't understand where there are too many color changes, unless you mean running out of line cycles to change other registers? The 2600 is great at different color every new scan line.
The Playfield pixels mirrored use less cycles, or is it just less time critical when the write is made? I know asymmetric involves changing PlayField data mid-scanline.
#23 TheHoboInYourRoom OFFLINE
TheHoboInYourRoom
    Moonsweeper
  • 416 posts
Posted Sat Oct 22, 2016 10:29 AM
Less time-critical, if it isn't asymmetric.
Edited by TheHoboInYourRoom, Sat Oct 22, 2016 10:30 AM.
#24 iesposta OFFLINE
iesposta
  • 3,889 posts
Posted Sat Oct 22, 2016 10:36 AM
But don't you also save cycles by not having to point to / load different PF data? (I really need to learn basic kernel techniques. )
#25 TheHoboInYourRoom OFFLINE
TheHoboInYourRoom
    Moonsweeper
  • 416 posts
Posted Sat Oct 22, 2016 10:37 AM
Yeah, you do. I misinterpreted your meaning a bit.
Also tagged with one or more of these keywords: furry, adventure, rpg, catgirl
