HOME AUTOMATION Posted November 3, 2018 Share Posted November 3, 2018 Some notes on the above... buffer writes go upwards from >3700, too much data may overwrite DEF table and continue writes upward from >4000!!!(DSR space)Use: Load(OLD) or RUN "DSK1.PHRASE"... at prompt enter text...at next prompt use FCTN 4 to BREAK the program. C$ and D$ containLPC data... D$ is compatible with CALL SAY... "CALL SAY(,D$)"use command CON to process more data. Use: Load(OLD) or RUN "DSK1.TABLE". G$(1) thru G$(127) contain LPC data of all allophones. Database takes 1 1/2 minutes to load... Requires 32K, Disk System, XB. Quote Link to comment Share on other sites More sharing options...
