Replacing 4116 ram with 4164 for reliability
arcadeshopper
I do this mod to Williams arcade boards that use the 4116 ram.. luckily they are all socketed so it's pretty easy..
The 4116 and 4164 chips are nearly identical with two exceptions
so if you cut off pin 1, and bend out pin 8, trim and jumper to pin 9 you have a 4116 replacement that uses less power, lower heat and higher reliability.
comments?
Greg
  • Like 11
I like it. I was thinking it is a shame to waste 48kb (bits) of memory, but the 4164s are likely much easier to find (and I will be looking to upgrade a couple of Commodore REUs,) and maybe with a little extra logic one could make the VDP's 16k space bank-switchable.
  • 3 years later...
  • 2 years later...
http://primrosebank.net/computers/mtx/projects/mavram/RAM%20Pinouts.jpg
http://www.8bit-homecomputermuseum.at/repair/newbrain/small/4116_ram_replace.jpg
comments?
Greg
here's the two pictures again.. either the upgrade or this forum sw sometimes removes photo linksimage.thumb.jpeg.935bbd3292f819e7c3978e0ccfc6ecdc.jpegimage.jpeg.499bc4a7dd0881431c0a70939c9d146b.jpeg
Greg
  • Like 5
