MegaSpeedy Operations?
35 replies to this topic
#26 Bikerbob OFFLINE
Bikerbob
    Dragonstomper
  • 630 posts
Posted Mon Apr 24, 2017 9:53 PM
I see the config.rom was updated as well? or at least it has a current date on the PC file system?
Also I did ask.. would it be hard to put the Bibodos 7 (english) in the SPEEDY BIBODOS? Anyone want to volunteer?
James
#27 HiassofT OFFLINE
HiassofT
  • 1,057 posts
Posted Wed Apr 26, 2017 10:03 AM
No need to update config.rom. The only thing that's changed in there is the embedded version date.
so long,
Hias
Edited by HiassofT, Wed Apr 26, 2017 10:04 AM.
#28 Bikerbob OFFLINE
Bikerbob
    Dragonstomper
  • 630 posts
Posted Thu Apr 27, 2017 12:26 AM
Well Hias, I have done the things I did before and now it writes fine,
If you have test suggestions please pass them along, but as far as I can tell your fixes work.
James
#29 HiassofT OFFLINE
HiassofT
  • 1,057 posts
Posted Thu Apr 27, 2017 12:17 PM
Thanks a lot for the feedback!
As for testing: try normal operations, the tools bootable from the Speedy (BiboDos, HSS copy), the tools from the Speedy system disk (eg here: http://ftp.pigwa.net...fo/1050 Speedy/ ) other DOSes and OSes with integrated highspeed SIO code (U1MB, SDX, ...) etc. If something doesn't work with the updated Speedy ROM please also check if this fails (or works) with the original (Mega-)Speedy version.
so long,
Hias
Edited by HiassofT, Thu Apr 27, 2017 12:18 PM.
#30 Bikerbob OFFLINE
Bikerbob
    Dragonstomper
  • 630 posts
Posted Sun Apr 30, 2017 1:47 AM
So far all things seem to run well. I am having no more issues that I can find so far.
Attached the faceplate I had done from Tiger Ducks file. I think the company I had do it.. through an online service. Was cheap but I dont think they printed this with enough care.
I needed to do some dremel work.. but its on!
#31 Dropcheck OFFLINE
Dropcheck
  • 1,231 posts
Posted Sun Apr 30, 2017 8:41 AM
Jamesattachicon.gif20170430_013935.jpgattachicon.gif20170430_014011.jpgattachicon.gif20170430_014022.jpg
   The company should have verified that the straight lines were straight.  It's a common failure with some combination of printers and filament (particularly ABS that you get warping of large prints. Sometimes you can mitigate it with changing the surface that lays flat on the build plate, other times it is the build plate itself that is not flat.... it bows in the middle.  I see it in the first pic, the top of the faceplate kinda bows down, assuming the pic was taken level with the drive.  I ended up having to put a glass plate on top of my build plate for that same reason.
     My print turned out almost as good.  But the tabs for the screws were not strong enough to handle any pressure and broke when I was trying to dig support structure out of the holes.  Next time I will either up the infill per cent and/or use some kind of strengthing sealer on them.
     Over all yours doesn't look bad at all.  :)
#32 Bikerbob OFFLINE
Bikerbob
    Dragonstomper
  • 630 posts
Posted Sat Jun 17, 2017 10:47 PM
Thanks a lot for the feedback!As for testing: try normal operations, the tools bootable from the Speedy (BiboDos, HSS copy), the tools from the Speedy system disk (eg here: http://ftp.pigwa.net...fo/1050 Speedy/ ) other DOSes and OSes with integrated highspeed SIO code (U1MB, SDX, ...) etc. If something doesn't work with the updated Speedy ROM please also check if this fails (or works) with the original (Mega-)Speedy version.so long,Hias
Hello again Hias, not sure if you remember, but when I was testing this before with the sio2pc it was not with the atarimax version, mine was not working so I was using an original Nick Kennedy design.
when we did the code changes, it seems to work great with the Nick Kennedy version. BUT I am not getting operation with the atarimax version. I have sent notes to Steve, but unfortunatly he is slow to respond. Not sure if its anything you want to look at.. since it is an issue with his device.
James
#33 HiassofT OFFLINE
HiassofT
  • 1,057 posts
Posted Sun Jun 18, 2017 3:24 AM
I can't quite follow you. What is working with the nick kennedy SIO2PC but not working with the Atarimax SIO2PC? How is this related to the MegaSpeedy?
so long,
Hias
#34 _The Doctor__ OFFLINE
_The Doctor__
  • 4,310 posts
Posted Sun Jun 18, 2017 8:05 PM
and what dos?
#35 Bikerbob OFFLINE
Bikerbob
    Dragonstomper
  • 630 posts
Posted Thu Nov 9, 2017 9:02 PM
Sorry guys, something I just ran into and cant find it in any of the texts, manuals or a search here on AA..
What is mode "SL"
I put a DD 80track disk in 360K and there is a beep and the display switches to SL - it is the one side of this one floppy.
James
Edited by Bikerbob, Thu Nov 9, 2017 9:07 PM.
#36 HiassofT OFFLINE
HiassofT
  • 1,057 posts
Posted Fri Nov 10, 2017 3:35 AM
What is mode "SL"
This is not a mode but a status message output by the Speedy ROMs.
Usually the Speedy displays the current track number 00-39.
If you insert a fresh, not formatted disk you'll get "nF" ("not formatted").
And if the Speedy detects there's something on the disk but it isn't a standard Atari format - which could mean eg some copy protected disk - the drive is put into slow mode (i.e. track buffer disabled, it behaves almost like a stock 1050) and "SL" (for "slow") is displayed.
so long,
Hias
